Page 1 of 3 1 2 3 LastLast
Results 1 to 30 of 77
  1. #1
    Gunner Bodhisatwa's Avatar
    Apr 2012
    Berhampore,West Bengal
    Default Need help regarding choosing gpu
    Hi! my cpu configuration is below-
    amd athlon x2 260 3.2 ghz proceesor
    4gb starlite ddr3 1333 ram
    gigabyte 78lmts2p motherboard
    iball lpe223-400 smps
    lg l1515s tft monitor
    my monitor's native resolution is 1024*768..it supports two or three higher resolutions but it is not fitted in the screen or the fonts are not good..
    so i have to play at 1024*768
    i want to buy a good gaming graphics card around rs.5000 ..pls suggest me some..
    i recently upgraded my cpu parts!!
    is my configurations okay?
  2. #2
    Adam young sukesh1090's Avatar
    Aug 2010
    udupi, karnataka
    Default Re: Need help regarding choosing gpu
    buddy you can buy 6670 at around 5k but first you have to change that i ball psu or smps.you may be able to run your system with that smps but it will be very risky.if the smps(chances are more because it is local crap psu with low quality components) dies it may take some of your comp's other parts like gfx card,mobo,HDD....with it.so better increase your budget by about 1.5k and get a FSP saga 350W.
    btw if your native resolution of your monitor is 1024x768 then you can't choose a resolution higher than that.1024x768 is the maximum resolution you can run in that monitor.
    :razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
    " Behind this mask there's more than flesh Mr.creedy, behind this mask there's an Idea and ideas are bulletproof. " - V for Vendetta.
  3. #3
    Apr 2012
    pls tell the market price of 6670 1gb ddr5 in kolkata(not the online price)..
    mention the brand(s) also if possible..
    will my gaming experience be good at 1024*768??
    pls suggest me a suitable psu at about rs.500..i am tight at my budget..i just upgraded my cpu!
  4. #4
    Super Moderator Skud's Avatar
    Jun 2004
    10 light years away
    6670 is around 5-5.5k. There's no good PSU at 500 bucks, but as your card doesn't require additional power, it might just be OK with your PSU as long as you don't OC anything.
    Else Corsair VS450 is around 2.2k.
    Gaming Rig:i7 2600K | N620 | P8Z68 Deluxe | 2x4GB RipjawsX DDR3 1600 | Vertex 3 120GB | Logitech G510 | Logitech G400 | Sapphire 6950 1GB | BenQ G2420HD | Corsair HX750 | Lancool K62
    HTPC Rig: C2D E7400 | EP45-DS3R | 2x2GB DDR2 800 | MS Wireless Desktop 2000 | Gigabyte 5770 | Samsung 32" | Seasonic SII 520W | Silverstone LC10
    Audio Gear: Altec Lansing VS2421 | ASUS Vulcan ANC | HiFiMan RE-0
    Storage: 2x250GB | 3x500GB | 3x1TB | 3x2TB
    Android: Galaxy R | Galaxy Y
  5. #5
    Apr 2012
    is it a ddr5 module?? which brand??
    i will not oc anything.
    pls tell me about the gaming experince at 1024*768
    are all my cpu's other parts ok for gaming?
  6. #6
    Away from Forums, Again! desiJATT's Avatar
    Jan 2012
    Jalandhar, India.
    Your config is just fine for gaming at 1024x768 resolution.
    Review : Samsung Galaxy S3 I9300
    How well will this game run on my Graphics Card
    Gaming Rig
    AMD Phenom X4 960T | Gigabyte GA970A-UD3 | Corsair XMS3 4GB | Gigabyte HD7850 OC | Caviar Blue 500GB | Seasonic S12II 520W | Dell ST2320L | Corsair 300R
  7. #7
    Jun 2004
    10 light years away
    Quote Originally Posted by Bodhisatwa View Post
    Yeah, DDR5 based. Try Sapphire or MSI, both are good. And as regards gaming, it will blast through at your native resolution at highest settings in most games apart from those which are CPU bound.
  8. #8
    Aug 2010
    udupi, karnataka
    as long as your native resolution is 1024x768, you won't have any problem in enjoying the game.you will get crystal clear quality after all it is a HD resolution .btw hold to your i ball psu for now but don't try to mess with it.
  9. #9
    Apr 2012
    should i go for the 6670 2gb ddr3 or 1gb ddr5??
    what are their prices right now in kolkata market??
    what is meant by games which are cpu bound?examples
    do i need to change my monitor?
  10. #10
    Mmmph!!! doomgiver's Avatar
    Nov 2010
    Mmmphhmph Mmphph
    fsp saga II 350W or 400W should be available somewhere.
    get either, it'll be more than sufficient, if you are concerned about your rig.
    Mmmphh-mphhhh-mmphh mhh!!!
  11. #11
    In The Zone dibya_kol's Avatar
    Dec 2011
    kolkata
    1gb is more than enough for u. No need to change ur monitor.
    | i5-2500k With CM Hyper 212 EVO | Biostar TZ68K+ | 8GB(4x2)G.Skill RipjawsX | XFX 5770+240GT PhysX | LG E2240(22'' LED) | Corsair vx 550 | Cooler Master 690 |
  12. #12
    sam
    sam is offline
    Forum Moderator sam's Avatar
    Jan 2010
    Guwahati
    HD6670 can't utilize 1Gb VRAM. Don't be fooled by that 2Gb memory. 1Gb GDDR5 will outperform the 2Gb DDR3 model.
    CPU bound means games that are limited by processing power.
  13. #13
    Mar 2012
    Quote Originally Posted by Skud View Post
    Can that iball PSU able to deliver the power required by HD6670 through 12V rail?
  14. #14
    Gamer
    Jul 2011
    Bhubaneswar
    Yes..
    Gaming Rig:
    AMD Phenom II X6 1075T @ 3Ghz | ASUS M5A97 | Sapphire HD6850 1GB | Corsair CX500V2 | G.Skill RipjawsX 4GB @ 1600Mhz | WD Caviar Blue 500GB | ASUS DRW-24B3ST | Dell IN2030M | Logitech MX518 | Cooler Master Elite 311
  15. #15
    Aug 2007
    Chinchwad Pune
    6670 is very low end card. So it will work fine but a strict NO to Overclocking anything.
    AMD Processors become Power Hogs when OCed. For example a Phenom OCed to 4 GHz draws 250W all by himself when its TDP is 125W. (Same reason even I had to get a HX750 in place of a VX450 which is also a good PSU)
    Phenom II 955 BE | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Kingston v300 SSD 240 GB | Seagate : 1 TB | NZXT Phantom 410 | Sony Experia Neo V
  16. #16
    Apr 2012
    which one is better--xfx ati radeon 6670 1gb ddr5 or xfx ati radeon 6670 1gb ddr3 or sapphire ati radeon 5670 1gb ddr5??
    which brand is better for gpus--sapphire or xfx or his or powercolor??
  17. #17
    Nov 2010
    Mmmphhmph Mmphph
    the 6670 with gddr5 ram, any size
    gddr5>>>>any other kind of ram.
    size does not matter here.
  18. #18
    Human Spambot thetechfreak's Avatar
    Nov 2008
    Guwahati
    Get the Sapphire Hd6670. Although for gaming at 1024x768 the Sapphire 5670 too is enough
  19. #19
    Apr 2012
    my shopkeeper is saying that 6670 1gb ddr5 is available but only of xfx.......
    he can buy that from kolkata..
    but its out of my budget...i want the sapphire one..pls tell me if its availaible in kolkata and mention the price also..
  20. #20
    Jan 2012
    Jalandhar, India.
    SAPPHIRE 6670 1GB DDR5
    Gaming Rig
  21. #21
    Apr 2012
    which brand is better? does the performance vary?
    is 6670 1gb ddr5 future-proof?? how does it vary from 5670 1gb ddr5?
  22. #22
    Aug 2010
    udupi, karnataka
    all the brands are same in performance wise but get sapphire or MSI and don't buy xfx.btw even 7970 is not future proof so then how can you think that 6670 going to be a future proof.only thing i can "guess" it should be able to handle games at least at low settings for next 2-3 years.
  23. #23
    Jan 2012
    Jalandhar, India.
    Not really. My Sapphire HD4350 got obsolete after 6 months of usage. Believe me, low end card like HD6670, won't be able to perform for more than 1-1.5 years, judging by the games coming in the future. IF you intend to game at 1024x768, then it might stay a little bit longer, but that too, only future can tell.
    Gaming Rig
  24. #24
    Apr 2012
    is there a big difference between 6670 1gb ddr3 and ddr5??
  25. #25
    Nov 2008
    Guwahati
    ATI Radeon HD 6670 DDR3 vs DDR5 - Graphics-Cards - Graphic-Displays
    [Solved] HD 6670 GDDR5 vs DDR3? - Graphics-Cards - Graphic-Displays
    Around 10% difference max might be there
  26. #26
    Apr 2012
    i live in Berhampore in west bengal..in the shop xfx 6670 1gb ddr5 @ 5900 is available..its out of my budget..xfx 6670 1gb ddr3 is available @ around 5000...sapphire 5670 1gb ddr5 is available @ 5200..do other brands of 6670 ddr5 cost less?? are they available??
    what should i do??
  27. #27
    Jun 2004
    10 light years away
    Open to buy online? Or possible to get one from Kolkata?
  28. #28
    Apr 2012
    no.. no ..i am bound to buy from shop..i have no experience
  29. #29
    Jun 2004
    10 light years away
    All of us was like that, experience doesn't come out of blue.
    You can go for the 5670, it is also good enough for gaming at your monitor's native res and beyond.
  30. #30
    Aug 2010
    udupi, karnataka
    +1 for sapphire 5670 ddr5.at maximum you will see 15% difference in performance between 5670 and 6670.so go for 5670 rather than 6670 ddr3.5670 will perform better than your GDDR3 version of 6670.
  1. Help Choosing LCD/LED TV for <=30k
    By ZEUSS in forum TVs / Monitors
    Last Post: 03-10-2011, 07:50 PM
  2. help me in choosing
    By satdrbe in forum Cameras and camcorders
    Last Post: 29-04-2011, 03:29 PM
  3. Help me choosing 22'-26' LED TV
    By dreatica in forum TVs / Monitors
    Last Post: 22-01-2011, 04:30 PM
  4. Need help choosing LCD TV
    By hahahari in forum TVs / Monitors
    Last Post: 07-01-2011, 11:54 AM
  5. Help for Choosing LCD
    By rbdhoot in forum TVs / Monitors
    Last Post: 19-08-2008, 12:29 PM
