Page 1 of 2 1 2 LastLast
Results 1 to 30 of 33
  1. #1
    122.26.11.85 Zangetsu's Avatar
    Jan 2008
    Soul Society
    Unhappy Graphic Card Problem HD5770
    My Card is not working
    since yesterday when I boot PC the card LED (green) glows for 1min or less & then turns-off & Red LED glows but the fan of the card keeps spinning
    my rest of the components are working fine I can even hear the windows 7 boot sound.but my display is blank bcoz my mobo doesn't have IGP
    what should I do?
    HTC One V | Nokia 5233 | Nikon D3100 | Apple Ipod Touch 4G | Sound Magic PL21 | Sound Magic ES18
  2. #2
    Gadget Freak Tenida's Avatar
    Aug 2008
    Calcutta
    Default Re: Graphic Card Problem HD5770
    Which graphics card you have? Is it in warranty??
    My Gizmos O_O
    ||Core i7 2600K | MSI Z68A GD80 | MSI GTX560Ti ||
    ||F&D A555U | Roccat Kave | Funbook | LG Optimus L9 (W) ||
  3. #3
    Jan 2008
    Soul Society
    Quote Originally Posted by Tenida View Post
    I already mentioned it in title HD5770.yes its under warranty
  4. #4
    Game & anime Lover pkkumarcool's Avatar
    Sep 2010
    Florence
    How ur surfing then i guess on mobile?
    On TDF after a loooo...nng time!
  5. #5
    Aug 2008
    Calcutta
    Quote Originally Posted by Zangetsu View Post
    I mean which brand
    Why not test the gfx card in other system or RMA is other option
    My Gizmos O_O
  6. #6
    Jan 2008
    Soul Society
    Quote Originally Posted by pkkumarcool View Post
    how does it matter with my problem...
    i can post it from frnds PC,office or cybercafe...
    I mean which brand
    Its Sapphire HD5770
    well I can't coz none of my frnds stays nearby
    Hardware experts pls reply ASAP
  7. #7
    Sep 2010
    Florence
    i meant to say that are u able to surf using ur pc in some way..have u tried to borrow or exchange gfx card from friend to check its gfx card problem only?
    go to nearest comp shop and check it this is the best way..
  8. #8
    Jan 2008
    Soul Society
    I can't access my PC.bcoz my Gigabyte mobo doesn't have IGP.
    neither I can borrow card frm frnds coz none of my frnd lives nearby
  9. #9
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    Then send it for RMA rather than asking here. We can't help you here as tou can't neither test your card to other systems or test another card to your system.
    Sapphire RMA service is very good and if your card is damaged then they will replace it.
    AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
  10. #10
    Jan 2008
    Soul Society
    Quote Originally Posted by Cilus View Post
    yes that is main issue I have only option left is RMA...
    but can u guys tell me what is red led means here
  11. #11
    Gaming hardcore pramudit's Avatar
    Dec 2011
    Jhansi
    afaik red light glows when hdd is in use...
    your issue is same as my gpu bt my mobo has igp so atleast my computer works....
    Intel Core 2 Quad Q8400 |Asus EAH4350 HD| WD blue 500GB | Intel DG41RQ | 2GB DDR2 | HP DVD-RW | Creative 2.1 | SAMATRON 55V |
    Samsung Galaxy Y || XOLO A700
    Garena id- pramudit
    My coil Gun
  12. #12
    Jan 2008
    Soul Society
    Quote Originally Posted by pramudit View Post
    but the red led is glowing in my graphic card & not HDD
  13. #13
    Dec 2011
    Jhansi
    then check out gpu website or any manual that came with it, my card had no light so dont know anything...
    Garena id- pramudit
    My coil Gun
  14. #14
    Human Spambot saswat23's Avatar
    Jan 2011
    Bhubaneswar
    Form the colour i.e Red, one can very well say that the card has some problem. BTW why dont you get the card checked at shop from you bought it?
    RMA is the last option for you. Perhaps you will be getting a HD 6770 as replacement. So, RMA it ASAP.
    Check here
    My Blog :D
  15. #15
    Fast 'N' Furious topgear's Avatar
    Jul 2006
    Geek's Heaven
    It means there' some loose contact between the pci-e slot and the gfx card connector or the gfx card is not getting enough power.
    Remove the card from the slot, clean the card and the slot, put them back, check the pci-e 6 pin power connector of the PSu and the gfx card and make sure they are dust free and ok. connect the pci-e power plug and try running the pc.
    Who Dares Wins
    Avenging Angel !
    Phenom II 955BEAsus M5a97 R2.0Corsair 2x 4GB RAMHD6850Corsair GS600CM Hyper 212CM 430 Elite
    My Blog : http://topgeartopspeed.wordpress.com/
    BlackListed : Viewsonic, Gigabyte
  16. #16
    Jan 2008
    Soul Society
    Quote Originally Posted by saswat23 View Post
    r u sure abt that HD6770
    Quote Originally Posted by topgear View Post
    actually the problem started when I opened the cabinet for cleaning & I had removed the card cleaned it & inserted it back.
    the day I cleaned I used the machine for 10~15mins it was working perfectly
    but the next day when I started my machine the problem started
    I will again use the step given by u...
    Q: Does static charge damages the card?
    I searched TDF & found AcceleratorX had the same problem as mine
    550 Ti or 5770
    Quote Originally Posted by AcceleratorX View Post
    @Skud:
    My Sapphire HD 5770 developed the D4000 LED issue, i.e. thermal diode going crazy even though there is no overheating happening. From what I could see on the internet, only Sapphire (the exact same one I had) and HIS models have this problem. There are a variety of fixes, from applying more thermal conducting paste to using a better aftermarket cooler, but in some cases the card was just plain bugged - mine was one such case. The display would go black after 15-30 minutes and the D4000 LED light would come on.
    I gave it for RMA and have collected the repaired/replaced unit (I don't know whether Aditya infotech repairs or replaces). In the meantime, however, I got myself a 550 Ti and the system is running fine, so I'm in no mood to check the 5770 at this time. Will however keep the card for possible use in building a PC from spare parts I got.
    But given the frequency of this issue, it seems that many Sapphire cards of that particular PCB revision has this problem. It was a non-reference PCB design, should have known better.
    I used to think Sapphire was the gold standard for ATI graphics cards, but when a card develops an issue like that in 1.5 years, you don't get a good impression.
  17. #17
    Aug 2007
    Chinchwad Pune
    5770 = 6770 apart from Name Change.
    Static Charge can damage any electrical part specially PCBs. So Yes for GFX Card.
    Phenom II 955 BE | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Kingston v300 SSD 240 GB | Seagate : 1 TB | NZXT Phantom 410 | Sony Experia Neo V
  18. #18
    In The Zone dibya_kol's Avatar
    Dec 2011
    kolkata
    RMA it ..
    | i5-2500k With CM Hyper 212 EVO | Biostar TZ68K+ | 8GB(4x2)G.Skill RipjawsX | XFX 5770+240GT PhysX | LG E2240(22'' LED) | Corsair vx 550 | Cooler Master 690 |
  19. #19
    Jul 2006
    Geek's Heaven
    550 Ti or 5770
    read this :
    http://www.overclock.net/t/885790/xf...4000-light-red
    Who Dares Wins
    Avenging Angel !
  20. #20
    Jan 2008
    Soul Society
    ^^have read that
    finally sent for RMA
    will have to wait 10~15 days max for replacement
    I hope sapphire RMA is good
    will post after the results
  21. #21
    Jan 2008
    Soul Society
    Finally got my card.
    They have replaced it with HD6770 1gb gddr5.well it doesnt have copper cooler & no green leds.rest is good i hope performance will better than 5770
  22. #22
    Dec 2011
    kolkata
    yes it is better than 5770 in some dx11 titles. But it is basicily 5770.
  23. #23
    Dec 2011
    Jhansi
    congrats zangetsu...
    i havent got back my 4350...
    Garena id- pramudit
    My coil Gun
  24. #24
    Dec 2011
    kolkata
    ^^ u also rma-ed ur card ? Tell me what gpu u r expecting ?
  25. #25
    Jul 2006
    Geek's Heaven
    congrats .. if possible upload a pic or post the product page link from the manufacturer's website.
    Who Dares Wins
    Avenging Angel !
  26. #26
    Dec 2011
    Jhansi
    dibya_kol i'm expecting a hd 6450 ddr3 or 6570 for some extra bucks...
    Garena id- pramudit
    My coil Gun
  27. #27
    Dec 2011
    kolkata
    ^^ hmm .. That would be nice if u get any of those ..
  28. #28
    Dec 2011
    Jhansi
    lets see when and what i get...
    Garena id- pramudit
    My coil Gun
  29. #29
    Jan 2011
    Bhubaneswar
    Zangetsu got the card earlier because it was Sapphire RMA. But yours is Asus.
    So, have patience for atleast a month.
    Check here
    My Blog :D
  30. #30
    Jan 2008
    Soul Society
    ^RMA of video cards take time
    atleast 15~20 days or 1 month
    but nothing can beat Corsair on RMA process
    I got this card
  1. Graphics Card - HD5770 / HD4850
    By cooldip10 in forum Completed/Closed Deals
    Last Post: 16-07-2011, 09:44 AM
  2. graphic card problem
    By hero_ishant in forum Graphic cards
    Last Post: 29-07-2010, 07:17 PM
  3. Graphic card problem
    By guptamohit in forum Graphic cards
    Last Post: 17-04-2009, 09:45 PM
  4. graphic card problem
    By adithya217 in forum Graphic cards
    Last Post: 04-05-2008, 11:35 PM
  5. Graphic Card Problem
    By vaibhavtek in forum Graphic cards
    Last Post: 19-12-2007, 05:51 PM
