Results 1 to 18 of 18
  1. #1
    EXTREME Siddharth_1's Avatar
    Mar 2011
    Default HD 7870 vs. HD 6970
    AMD Raedon HD 7870 and HD 6970 have almost the same cost but have difference in some of their technical specifications. Which one would have a better performance and at the same time would be more future proof.
    Also i want to that i should buy it from sapphire, xfx, msi or asus and which model of the GFX.
    PC
    i5 2500k | MSI Z68MA-ED55(B3) | RipjawsX (2X4GB) | MSI R7950 2PMD3GD5 | Seagate 1TB 7200.12 | CM GX-550W | CM Elite 430|Samsung 22x | BlackWidow Ultimate DragonAgeII Edition8-) | MX518 | Goliathus Fragged Control Editon
    + Lumia 720 + iPod Touch 32GB + PSP
  2. #2
    Tensor Gaurav Bhattacharjee's Avatar
    Feb 2010
    Guwahati
    Default Re: HD 7870 vs. HD 6970
    From what I have seen the 7870 is about equal with a 580 which is currently alot more money and at a higher wattage.
    In fact the 7870 stands up quite well to the 7950.
    Basically the 7870 is about a 10-15% gain over the 6970 with about 30% less power usage.
    Athlon II X2 260 | Gigabyte GA-78LMT-S2P | HIS IceQ Radeon HD5670 1GB GDDR5 | Corsair Value 1x4GB 1333MHz | Cooler Master Elite 311 | Corsair CX430V2 | WD Caviar Blue 160GB | Viewsonic VA503m | Logitech Z110 | Sony DVD-RW AD-7240S | Generic Keyboard & Mouse | Zebronics 700VA
    SteamID
  3. #3
    Mar 2011
    Actually is was talking about their advantages over each other:
    HD 7870
    • PCI-E 3.0 over PCI-E 2.1
    • Core Clock speed of 1000MHz over 880MHz
    • Max Power Draw of 175W over 300W
    • Open GL 4.2 over 4.1
    • DirectX 11.1(compatible) over 11
    • 28nm Process over 40nm Process
    • More future proof because it is launched 1.5yrs later
    HD 6970
    • Memory Clock speed of 5.5GHz over 4.8GHz
    • Memory Bandwidth of 176GB/s over 153.6GB/s
    • 1536 Fragment Pipelines over 1280 Fragment Pipelines(Fragment Pipelines: Pixel Shader Processor Pipes)
    • 96 Texture Units over 80 Texture Units
    Similarities
    • Memory Size of 2GB
    • GDDR5 Memory Type
    • 256bit Memory Bus Type
    • Raster: 32
    PC
  4. #4
    Super Moderator Skud's Avatar
    Jun 2004
    10 light years away
    All you need to do is to see some benchmark results and you can decide by yourself. And 7870 would be touch pricier at this moment and its not even released in India as of now. And the pros and cons you have mentioned are mere theoretical, its the performance in games that matters.
    Gaming Rig:i7 2600K | N620 | P8Z68 Deluxe | 2x4GB RipjawsX DDR3 1600 | Vertex 3 120GB | Logitech G510 | Logitech G400 | Sapphire 6950 1GB | BenQ G2420HD | Corsair HX750 | Lancool K62
    HTPC Rig: C2D E7400 | EP45-DS3R | 2x2GB DDR2 800 | MS Wireless Desktop 2000 | Gigabyte 5770 | Samsung 32" | Seasonic SII 520W | Silverstone LC10
    Audio Gear: Altec Lansing VS2421 | ASUS Vulcan ANC | HiFiMan RE-0
    Storage: 2x250GB | 3x500GB | 3x1TB | 3x2TB
    Android: Galaxy R | Galaxy Y
  5. #5
    Sep 2010
    Ofcourse 7870hd if same/almost-same price.
    Cause:
    1. Great oc
    2. Less power hungry.
    3. Newer 28nm technology.
    4. Significant increase in computational power.
    5. Dx11.1
    6. More lead over 6970hd at shader heavy games like metro2033.
    7. Last but not least, u can brag of being a proudful owner of 7xxxhd gfx card.
  6. #6
    I am the night...I am... vickybat's Avatar
    Aug 2009
    Gotham City
    Same here. 7870 is the card to buy. The main reason being it performs very very close (almost similar) to a Gtx 580 and even a 7950 at much lesser price. That should be a good enough reason imo.
    Core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book ,Seagate freeagent ext hdd 1tb , hp dvd writer,Apc 650 va, logitech z313 , Micromax Funbook , Klipsch image S3 (IEM).
  7. #7
    Mar 2011
    So you mean to say that i should wait for some time till the performance stats of 7870 are published over the internet.
    But dont you think that the less no of texture units and pixel shader processors(fragment pipelines) in 7870 as compared to 6970 would effect its performance.
    PC
  8. #8
    ico is offline
    . ico's Avatar
    Jun 2007
    Bangalore
    Quote Originally Posted by Siddharth_1 View Post
    HD 7870
    HD 6970
    Similarities
    • GDDR5 Memory Type
    • Raster: 32
    You should ignore things like memory bandwidth, core clock etc. You don't judge by those.
    Only three things matter -
    1) FPS in games.
    2) Power consumption.
    3) Price.
    AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn) | 2 * 4 GB Corsair 1600 Mhz Value RAM | Corsair CX430v2 | NZXT Gamma | Dell S2240L 22" @ 1080p
    Intel i5-2500K | Asus P8Z68 Deluxe | 2 * 4 GB Corsair Vengeance | WD Caviar Blue 500 GB | CM Hyper 212 Evo | AMD Radeon HD 6950 2 GB | NZXT Tempest Evo | Corsair AX850 | AverMedia AverTV Capture HD H727
    Samsung Galaxy S2 | Mac mini (Late 2009) with OS X Mountain Lion, 10.8
    Pandaboard ES | OMAP 4460 SoC | 2 * ARM Cortex A9 cores | PowerVR SGX540 graphics
    Arch Linux amd64 | Ubuntu 12.04 amd64 + omap4 ARM | Windows 7 x64
  9. #9
    Jun 2004
    10 light years away
    It's already out a week ago. Google.
  10. #10
    Mar 2011
    Quote Originally Posted by ico View Post
    1) FPS in games.
    3) Price.
    Thanks for your suggestion.
    Quote Originally Posted by Skud View Post
    I found this source-
    AMD Radeon HD 7870 and HD 7850 Launched - 3D Tech News and Pixel Hacking - Geeks3D.com
    HD 7870 has much better performance than other GFXs of its price range. Especially, as compared to GTX 570, it has better performance and yet its quite cheaper. It also has variably good performance as compared to HD 7950 and GTX 580, which possibly be matched by an OC edition of HD 7870.
    But because nvidia kepler series are going to be launched in a month, so i think that i should also wait for GTX6.X.X. Take a look at this link-
    http://www.brightsideofnews.com/news...-leak-out.aspx
    It says that GTX 660(GK104) would have an approx. cost of $250 and will perform better than HD 7950. So, i may be able to get something better than HD 7870 in a price of $350.
    But 1 thing is want to ask is that will my Gen2(PCI-E2.0x16) mobo [MSI Z68MA-ED55(B3)] will support these PCI-E3.0x16 GFXs.
    PC
  11. #11
    In The Zone rchi84's Avatar
    May 2009
    Dubai, UAE
    GPUs are backwards compatible, meaning you can even plug those into a Pci-e 1.0 slot, but they will have some performance crippled.
    They will run absolutely fine on Pcie 2.0 x16 slots. There are few games that will actually utilise all that bandwidth on a single monitor as of now.
    Core i5 2400|| Gigabyte ph67 B3|| 8GB DDR3 1333|| 1TB WDC Black|| CM 690II Nvidia Edition|| CM 850W Silent Pro|| Samsung 2333T|| Gigabyte Geforce 670 2GB (Windforce 3x)|| Logitech G35 Headset
  12. #12
    Nov 2011
    Btw from where r u planning to buy 7870?? Its not even released in india.
  13. #13
    Mar 2011
    I have the contact of an importer who imports electronics in India. He possibly could get a graphics card for me from US or Europe.
    PC
  14. #14
    sam
    sam is offline
    Forum Moderator sam's Avatar
    Jan 2010
    Guwahati
    ^^ by the time your importer imports the GPU, you may get it from ITWares, or SMC or TE's dealer's paradise for much less. also warranty.
  15. #15
    Mar 2011
    ^^ the person frequently travels from india to abroad so maybe if he gets the GPU personnaly, i need not pay any import duties and i could get it at the prices abroad. But maybe it might never happen.
    Anyways, thanks for your suggestion.
    PC
  16. #16
    Back on TDF :) devx's Avatar
    Nov 2011
    Bhopal (M.P)
    Hey people in here if somebody knows the 7870 seller info. in India by next week please post.....
    The DIVINITY
    Seagate GoFlex 500GB || Transcend JetFlash 700 16GB
    Samsung Galaxy Spica GT-I5700 + Sandisk 16Gb class 4
  17. #17
    Mar 2011
    ^^k...
    PC
  18. #18
    Nov 2011
    Bhopal (M.P)
    = ebay.in is selling Gigabyte / Powercolor / Sapphire 7870 at 27-28k as always IMPORTING from USA., i don't think anyone is going to order from Ebay better to wait till it properly arrives in our market.
    = Hey MSI R7870 Twin Frozr 2GD5/OC is available on SMC for 22.1k + shipping (100 for surface & 300 for Express)., by the way CILUS found it first & posted.
    = Hardwire.in > SAPPHIRE = 22,889/- > MSI = 24,450/- > HIS 23,595/-
    Sapphire HD 7870 2GB - Hardwire.in
    http://hardwire.in/graphics-cards/46...n-frozr-2.html
    http://hardwire.in/461-his-radeon-hd-7870-iceq-2gb.html
    = TheITwares > HIS = 22,850/-
    HIS HD 7870 IceQ Edition 2GB GDDR5 H787Q2G2M HD7870 Radeon 256-bit PCI Express 3.0 x16 HDCP Ready CrossFireX Support Graphic Card
    The DIVINITY
  1. 13-11-2012, 11:23 PM
  2. 13-11-2012, 11:20 PM
  3. 30-07-2012, 10:53 AM
  4. 27-07-2012, 10:20 PM
  1. Overclocking my new Sapphire HD 7870
    By slashragnarok in forum Overclocking
    Last Post: 29-07-2012, 08:07 PM
  2. HD 6870 CF or HD 6970 2GB ??????
    By heartripple in forum PC Components / Configurations
    Last Post: 19-08-2011, 09:17 PM
  3. AMD HD 6950 and 6970 released
    By topgear in forum Graphic cards
    Last Post: 12-02-2011, 12:24 PM
  4. AMD Radeon HD 6950 to HD 6970 Mod
    By paroh in forum Technology News
    Last Post: 11-01-2011, 01:46 AM
  5. should i get one 6970 now..?
    By max.4u in forum PC Components / Configurations
    Last Post: 17-12-2010, 10:32 PM
