A Little Story Behind -
I had overclocked my card to 900/1275 and was going to overvolt to get further. Before that i decided to read some user experiences at newegg. Saw this -
Bios Switch unlocks 6970 shaders.
So thats how the fun began.
How to Unlock -
1. You need to have a Sapphire HD6950 with a dual fan cooler. 1GB or 2GB both have good chance of unlocking.
2. Make sure the card is running at stock 800/1250.
3. Turn off the system, open the cabinet side panel and locate the BIOS Switch on the card. Its near crossfire bridge connector.
4. Flip the switch towards right.
5. Reboot.
6. Open GPU-Z and you shall see this hopefully -
7. Now you can overclock it to 880/1375 (the HD6970 speeds) (Note - Every card is different. Some cards may need overvolting to get to 880/1375. Overclock at your own risk)
What about noise? I have read this card is noisier under load (just like other dual fan cards). Even my single fan's noise is audible at 50% and above in winter when the ceiling fan doesn't spin.
Jas, superb work buddy. You are becoming pro day by day. Now you got a HD 6970 from your HD 6950. So I don't think you need to puch the card much further.
Jas does we the owners of 6950 have chance to do this . i ask this question bcse we all have different company cards only kapilove have and i have the same company card. can we do this or not . and yes nice oced jas & cilius check Ur spell mistake u did it in a hurry i think edit it .
It's answered here:
Originally Posted by Skud
@kapilove77: MSI had released a BIOS and instructions to unlock the shaders earlier for that card. Google it.
Of course, it won't be just a flip of switch, you have to actually flash the BIOS. Else there are scripts to do it automatically. But beware, this might be risky and there's no guarantee. In any case, always backup the original BIOS.
thanks cilus.
yes i am keeping it at 880/1375.
Originally Posted by slashragnarok
Does this card have 2 6 pin connectors or 6pin+8 pin?
2 6pin.
@TP
in AvP they have used 4xAA, i have run it at default settings -
# AvP Benchmark Config File
# To use a config file such as this with the Benchmark, launch the
# AvP_Benchmark.exe with the following on the command-line (e.g.via a
# short-cut).
# -config=name_of_your_config.txt
# If no config file is specified the Benchmark will run at it's default
# settings (which are listed below).
# Lines beginning with # are comments and are ignored by the Benchmark.
# By default the Benchmark will output to the user's Documents folder,
# under a subfolder called "AvP_Benchmark". The filename of the report
# will include the current date and time to make it easier to compare
# different runs.
# To specify a different report filename, use the following on the
# command-line:
# -report=name_of_report_file.txt
# Each value has a default which will be used if there is not a valid
# setting (i.e. out of range or the line is commented out).
# If there are multiple mentions of the same value (e.g. Shadow Quality)
# then the last one in the file will be used.
# Video resolution, Width and Height
# Defaults to Windows resolution if commented out.
#Width: 1024
#Height: 768
# Texture Quality:
# 0 = Low, 1 = Medium, 2 = High 3 = Very High
# Defaults to 2 if commented out.
Texture Quality: 2
# Shadow Quality:
# 0 = Off, 1 = Low, 2 = Medium, 3 = High
# Defaults to 3 if commented out.
Shadow Quality: 3
# Anistropic Filtering
# Range of 1 to 16
# Defaults to 16 if commented out.
Anisotropic Filtering: 16
# Screen Space Ambient Occlusion
# 0 = Off, 1 = On
# Defaults to 1 if commented out.
SSAO: 1
# Vertical Sync
# 0 = Off, 1 = On
# Defaults to 0 if commented out.
Vertical Sync: 0
# DX11 Tessellation
# 0 = Off, 1 = On
DX11 Tessellation: 1
# DX11 Advanced shadow sampling
# 0 = Off, 1 = On
DX11 Advanced Shadows: 1
# DX11 Full Screen Anti-Aliasing Sample Count
# 1 = Off, 2 = 2xAA, 4 = 4XAA
# Defaults to 1 if commented out. DX11 MSAA Samples: 1
scores in line with 6970 and 6950 scores. i used same settings.
in 3dmark11 i think they have used the score combined of all 6 tests whereas i have used 4 GPU tests only.
in unigine i think they have used default settings.
Guys i have problem with Dirt3 benchmark.
i choose 8xmsaa 3 times for benching, but everytime i see the xml file its reset o 4xmsaa. any solution?
here is 3d mark 11 extreme preset gpu score -
Originally Posted by ashis_lakra
Yep, first one.. I wish GTX 560 ti could unlock to GTX 570 . haha
