Results 1 to 2 of 2
29-11-2011, 02:17 AM #1
*** Graphic Card Buying Advice TEMPLATE ***
Tips for answering the template questions.
First and the foremost, if you are creating a thread asking for a new graphic card you HAVE to mention the EXACT company, make and model of your Power Supply (SMPS). Specifications would be helpful too.
"i have a 400w power supply" --- this is wrong.
"i have a 400w power supply from Corsair" --- this is again wrong.
"i have Corsair CX400 power supply" --- this is right.
Second, if you are using an el-cheapo also known as "crap" power supply, read this thread first: Power supply blacklist thread for newbies Many companies like Cooler Master, Intex, Frontech, iBall etc. are black-listed here. Running a graphic card on these poor PSUs is not safe at all. So, if you are using one, you will have to increase your budget.
Third, before asking a basic query....use Google. The members of this forum are there to help you BUT not to spoon-feed you. Most basic queries are only a Google search away.
Fourth, if you don't want to Google, then read this thread: Basic information regarding graphic cards for newbies
Fifth, read this thread before creating a buying advice thread: Best Graphic Cards for money - in India. This thread will help you to get an idea of which Graphic cards you should be aiming at in your budget.
Threads from new members with half-baked and common queries will not be approved.
Only create a thread if you have read all the threads mentioned above. You create a thread in whatever way you want, but information in the following questions should be mentioned.AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn)
| 2 * 4 GB Corsair 1600 Mhz Value RAM | Corsair CX430v2 | NZXT Gamma | Dell S2240L 22" @ 1080p
Intel i5-2500K | Asus P8Z68 Deluxe | 2 * 4 GB Corsair Vengeance | WD Caviar Blue 500 GB | CM Hyper 212 Evo | AMD Radeon HD 6950 2 GB | NZXT Tempest Evo | Corsair AX850 | AverMedia AverTV Capture HD H727
Samsung Galaxy S2 | Mac mini (Late 2009) with OS X Mountain Lion, 10.8
Pandaboard ES | OMAP 4460 SoC | 2 * ARM Cortex A9 cores | PowerVR SGX540 graphics
Arch Linux amd64 | Ubuntu 12.04 amd64 + omap4 ARM | Windows 7 x64
31-01-2012, 04:33 AM #2
re: *** Graphic Card Buying Advice TEMPLATE ***
1. Which Power Supply do you have? (Be EXACT while naming the company and model)
Ans:
2. What is your budget?
Ans:
3. Which resolution will you game at?
Ans:
4. What are your current computer specifications?
Ans:AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn)
Advice on buying a graphic card
By Sainatarajan in forum Graphic cardsReplies: 2Last Post: 28-05-2012, 06:23 PM -
Advice on buying a graphic card for my friend !!!
By Sainatarajan in forum Graphic cardsReplies: 5Last Post: 26-05-2012, 06:46 AM -
Advice needed regarding Graphic card.
By ashray99923 in forum Graphic cardsReplies: 5Last Post: 18-03-2009, 03:12 PM -
Buying a graphic card . . .
By jay4u in forum Graphic cardsReplies: 1Last Post: 06-04-2005, 09:08 AM
LinkBack URL
About LinkBacks
