Go Back   Digit Technology Discussion Forum > Hardware > Graphic cards
Graphic cards News, discussions, queries and problems related to Graphic cards.
Old 01-09-2005, 02:06 PM   #1 (permalink)
bang bang!
Chirag's Avatar
Default Problem due to Graphics Drivers or somthing else
Everyone here wanted to have a new graphics card but i want to have new graphics driver?
The shop frm which i bought my pc have been closed now. They had the propoer driver for my pc. Now some times back my pc had problem. I repaired it and installed S3 graphics driver but damn games r not running properly. I don't have any graphics card. See the images below:-
Memory
CPU
Main board
GTA:VC
Cricket 2002
My Config:-
Windows XP Sp2
40 GB HDD
256 MB SD Ram
(config u can see in images)
Please suggest me a Graphics Driver.
I have tried many many means many graphics drivers. But none worked. I am in doubt that is this problem bcoz of graphics driver.Can any other thing me behind this problem of games not running propoerly?I Don't have Java Virtual Installed? Is this the problem? Shld i install it?
Chirag is offline
Old 01-09-2005, 02:19 PM   #2 (permalink)
your motherboard is based on the VIA chipset. I would suggest downloading the VIA hyperion drivers from here:
http://downloads.guru3d.com/download.php?det=1085
They say this is for all VIA chipset based systems to check it out.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 01-09-2005, 02:30 PM   #3 (permalink)
bang bang!
Chirag's Avatar
THnx for the link but i donwloaded the same frm digit cd and nothing worked all was same.
PLease help me.
Chirag is offline
Old 01-09-2005, 05:23 PM   #4 (permalink)
bang bang!
Chirag's Avatar
Help me please.
The problem is not yet solved.
Which drivers to choose?
Chirag is offline
Old 01-09-2005, 10:48 PM   #5 (permalink)
aadipa's Avatar
This board comes with S3 Graphics ProSavage8™ 2D/3D Accelerator, and required drivers can be obtained from link.
Hope this helps.
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 03-09-2005, 07:57 PM   #6 (permalink)
bang bang!
Chirag's Avatar
Problem not yet solved help me
Chirag is offline
- by bhaskar
