Results 1 to 24 of 24
03-10-2011, 07:35 AM #1Right Off the Assembly Line
- Join Date
- Oct 2011
- Posts
- 7
Zotac GTX 560 ti BLACK SCREEN PROBLEM
Hi my name is Stenly I have just recently upgraded to Zotac Gtx 560 ti Card. My previous card was Sparkle 9500 gt.
My problem is whenever I play games like Bionic commando , Crysis 2 ,Just cause 2 etc at high or low Setting after few minutes or even in few seconds
I get a black screen and the system hangs. I have tried all the possible things I have also updated the drivers.
My Config :
Motherboard - Gigabyte G31M-ES2C
Processor - Core 2 Duo E7500 (not overclocked)
PSU - Iball Stallion 600 watt
Ram - 4 GB
Cabinet - Iball Bullet
Previous Card - Sparkle 9500 gt
Current Card - Zotac 560 ti
I have sent my graphics card back to the zotac frm where i have bought.
And got the replaced card.
But its also giving the same problem.
Plz hlp.
I hve attached the iball spec of my PSU.
03-10-2011, 01:43 PM #2
Re: Zotac GTX 560 ti BLACK SCREEN PROBLEM
That iBall PSU looks very suspicious to me. Test your computer with another good PSU like FSP Saga II 500w
Follow me on Twitter: http://twitter.com/wuodland
03-10-2011, 02:27 PM #3
Yup the psu is the culprit here.
Core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book ,Seagate freeagent ext hdd 1tb , hp dvd writer,Apc 650 va, logitech z313 , Micromax Funbook , Klipsch image S3 (IEM).
03-10-2011, 02:33 PM #4Apprentice
- Join Date
- Sep 2011
- Posts
- 77
+1 for thetechfreak's tip
don't relay on iball,
FSP is offering very low prices on PSUs, check out
Also try arranging another PSU if possible to see if issue continue
03-10-2011, 08:32 PM #5Sage of the Six Paths
- Join Date
- Sep 2011
- Posts
- 925
Seriously? I don't understand why do you people consider iBall PSU's to be absolute crap! My friend is powering a dual core, 2gb ram, 5770, 2 hdd, one dvd with a 650rs iball 450w psu with no issues. It is possible that OP has got a faulty unit, but considering it crap is not ok..
OP if you have the 560 ti 1gb edition (stock),
ON this review:
GeForce GTX 560 Ti review
It is clearly stated:
Which is with a high-end rig. So even if the Stallion is 50% efficient, it should be able to power up your rig.System Wattage with GPU in FULL Stress = 319W
04-10-2011, 12:46 AM #6
U've got ur facts messed up bro...
Firstly you got the concept of efficiency wrong...its not that if he has a 600W PSU with 50% efficiency then his PSU will provide peak power of 300W. Check it up on the net or look up one of Cilus's earlier post where he explained it very well
Secondly agreed that even with a cheap PSU u could run a high end rig well. But is it really worth the risk??
read this article:
Don't Be Surprised When Your Cheap PSU Blows Up : 1670 Watts For $60?
a cheap PSU has a good chance of damaging the rest of your configuration causing lot more loss than what it would have cost u to buy the "branded reliable" PSU.AMD Athlon II X4 630 | MSI 785GM E51 | 4 GB DDR3 1333 Corsair | 500+160 GB Seagate | SAPPHIRE HD 6850 | NZXT Gamma | Seasonic 500 Watt :D | Samsung 19" LCD | Google Nexus 4 16GB | Google Nexus 7 16GB
04-10-2011, 06:40 AM #7Right Off the Assembly Line
- Join Date
- Oct 2011
- Posts
- 7
So If I chacnge my PSU to Corsair GS700 or GS800 It will work fine without any problem.
04-10-2011, 09:04 AM #8Sage of the Six Paths
- Join Date
- Sep 2011
- Posts
- 925
Iball is much better than other cheap brands like Frontech, Bitech, etc. But I agree that it will eventually damage your rig.
I don't know if the listed price over Lynx is correct, but if it is then it is definitely not a CHEAP psu.
@OP how much you paid for the PSU?
04-10-2011, 09:11 AM #9
@rajnukser
I have gone great length to find this post by Clius. Hope you understand what we mean to say
04-10-2011, 04:21 PM #10
This was the same post I was talking about!!
But I was too lazy to find it last night
Anyway OP before spending money on a new PSU check the card on a friends PC which has a good PSU. That way u can confirm the source of the problem and then buy the new PSUAMD Athlon II X4 630 | MSI 785GM E51 | 4 GB DDR3 1333 Corsair | 500+160 GB Seagate | SAPPHIRE HD 6850 | NZXT Gamma | Seasonic 500 Watt :D | Samsung 19" LCD | Google Nexus 4 16GB | Google Nexus 7 16GB
04-10-2011, 04:27 PM #11
I remembered which thread it was in so I found it in few minutes
You donot need to spend so much money. A FSP Saga II 500w will do perfect unless you want to overclock
09-10-2011, 06:57 AM #12Right Off the Assembly Line
- Join Date
- Oct 2011
- Posts
- 7
Hey yesterday I noticed that when I play games Like Street fighter IV
Battlefield Bad company 2 , Bionic Commando Rearmed. These games works fine
I dont know how they work well but I noticed that the GPU load was always between 30 to 47% . I played this games for several hrs. Nothing happed I was using the Iball Staliion 600. but when I played crysis 2 or run the stability test
It crashes in 10 to 15 sec. I also saw that it was at peak 85 to 99% Gpu load for few sec. Hey also one more thing when I run the benchmark of that Video stabilty test. It works fine but in video stabilty test it crashes.
Plz rply. Why it not crashes and then why it crashes.Last edited by jokerisdead; 11-10-2011 at 07:54 AM.
22-10-2011, 10:46 AM #13
I have this same problem , a black screen appears with "NO SIGNAL" error from the monitor, and I am forced to restart the whole machine.
I don't think its a case of bad PSU, I got Coolermaster GX750watt still i get this problem, tomorrow I am gonna replace my card for a may be non-ti version if they let me.
Classic case of Badly manufactured GPUs or drivers(
whatever, I dont think they are even gonna admit their fault).
I think this is my last time I haddaway with nVidia, after 6months or so, I am going to switch to Radeon.
24-10-2011, 08:23 AM #14
No...
On CoolerMaster (refresh) - Overclock.net - Overclocking.net
Your PSU isn't a good one either. Should be labeled to a 450w unit.
Cooler Master GX 750 W Power Supply Review | Hardware SecretsAMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn)
| 2 * 4 GB Corsair 1600 Mhz Value RAM | Corsair CX430v2 | NZXT Gamma | Dell S2240L 22" @ 1080p
Intel i5-2500K | Asus P8Z68 Deluxe | 2 * 4 GB Corsair Vengeance | WD Caviar Blue 500 GB | CM Hyper 212 Evo | AMD Radeon HD 6950 2 GB | NZXT Tempest Evo | Corsair AX850 | AverMedia AverTV Capture HD H727
Samsung Galaxy S2 | Mac mini (Late 2009) with OS X Mountain Lion, 10.8
Pandaboard ES | OMAP 4460 SoC | 2 * ARM Cortex A9 cores | PowerVR SGX540 graphics
Arch Linux amd64 | Ubuntu 12.04 amd64 + omap4 ARM | Windows 7 x64
24-10-2011, 11:17 PM #15
To all who are having "No Signal" error. Please try this: Crashing/Graphical Issues Fixed! GTX 560 Ti - Forums - World of Warcraft
Instead of WOW, select the game you have issues with. A friend who works for Alienware tech support told that this solves the issue- if not then uninstall the driver, use the drivesweeper, install the stable driver and then do the step above.
26-10-2011, 07:09 AM #16Right Off the Assembly Line
- Join Date
- Oct 2011
- Posts
- 3
The solution mentioned at the WOW forum was also no joy.
I have the same problem as earlier mentioned: a black screen after a few minutes of playing Assassin's Creed or BP4F and only a hard reboot will bring my pc to life again. I already exchanged my Zotac 560 ti (ZT-50301-10M) for another one because of this problem. But it has the same problem!
I also tried the cards in two different pc's:
[PC1]
OS: Windows 7 Pro X64
CPU: AMD AThlon II X4 955
MB: Gigabyte GA-MA790X-UD4P
Memory: Geil 4GB DDR2 PC6400
PSU: Corsair TX650
Display: Dell U2311H (via DVI and DisplayPort)
HDD (System): SSD Intel 510 120GB
[PC2]
CPU: Intel Core2Duo E6850
MB: Gigabyte GA-P35C-DS3R
Memory: Kingston 4GB DDR2 PC5300
PSU: CoolerMaster SilentPro 500
Display: Dell U2311H (DVI and VGA)
HDD (System): 2x 250GB Seagate ST3250410AS Raid 0
Both are very stable systems. Any suggestions?
31-10-2011, 12:50 PM #17
I think you should talk with ur dealer immediately , I did too.
At first they were not taking responsibilities and tried to replace the card with another one GTX560Ti, but I managed to replace mine with Sapphire 6870HD,I think it doesn't score up to GTX,stillI got a stable solution .
08-11-2011, 08:26 PM #18
I just ordered this same card as I saw this thread just now. Is everyone having this problem with this card?
Appreciate me now and avoid the rush!!
i5 2500K || 8GB DDRIII 1600 MHz RAM || Zotac GTX560Ti || Samsung 2233sw || Corsair GS600
14-11-2011, 10:55 AM #19
Seems like many folks around the globe are having issues with GTX560TI card..I did have a Zotac Factory clocked card but returned it, and there is a useful nVidia forum link mentioned below where they discussed about this issue.
GTX 560 Ti: Having issues or not? - NVIDIA Forums
But, seriously People who have this card at best its performance are saying
that it is one the best cards available in the market. Best of Luck with your shipment.
15-11-2011, 09:00 PM #20
I am having the same issue with gtx 250 and alas as soon as i started using the on-board graphic card of mobo, the problem is gone......
I had problem even in using the computer properly........my screen used to go blank even while normal browsing.....
Dunno what to do, everyone says that graphic-card cannot be repaired...In the Pic: The Great Sachin Tendulkar
16-11-2011, 01:41 AM #21Alpha Geek
- Join Date
- Jun 2008
- Posts
- 610
Here is the fact the crysis is the bench marking game of all. It uses all the calculation a gpu as well as cpu can make it work. Not sure what tech. But i fried 2 psu thank fully my other spec remains unaffected. Better get a psu from corsair. Go for higher supply may be this will allow room for expansion say anything in feature. Its a good to spend than later to regret.
Intel I5 2500K@4.3GHZ OC : Corsair Force 3 SSD 120gb: GSKILL 8GB 2X4GB 1600MHZ: Asus P8Z68 V: ZOTAC GTX 560TI 1GB DDR5:CORSAIR GS800 :Corsiar 400R :Asus Xonar DX 7.1 AC: NZXT SENETRY2 :CORSAIR H100: LG E2360V 23" : Logitech MX518:
16-11-2011, 05:15 PM #22Right Off the Assembly Line
- Join Date
- Oct 2011
- Posts
- 3
I have contacted Zotac in Germany (the country I bought my card) and they were very helpful. They contacted their HQ in Hongkong about my problems. After this they confirmed -by phone- there is a known bug / problem.
The good news is that they also are working on a fix!
This fix is now tested. For this they also wanted my card as soon as possible send to their European technical HQ in the UK. I send my card 31-10 to Zotac and I am waiting for the replacement (with the fix).
I presume the fix is a new bios release? (I believe some other manufacturers solved these issues by raising the default voltages).
Sent: 27 oktober 2011 18:24
To: name@myemail.nl
Subject: broken card
Dear Sir,
we have consultated the headquarter in Hongkong and we are very interested to get your card directly and fix this bug soon completely. Please fill in the attached Excel form. Also please attach a copy of the invoice.
If the data is complete you receive an address to where the defective card should be sent then.
Kind regards
Ihr ZOTAC-Team
Email: support @zotac.de
27-11-2011, 12:53 AM #23Right Off the Assembly Line
- Join Date
- Oct 2011
- Posts
- 3
The UK technical support of Zotac did some testing on my 560Ti and they informed me by mail that it will be replaced. The mail also had some attachments with information about this RMA. One of these attachments had some interesting comments: 'upgraded to GTX 570 AMP ZT-50204' (...for real?). Last tuesday I received my replacement and it was indeed a GTX 570 AMP ZT-50204!!!
I tested this card the last couple of days with my games (like BF3) and its great! No black screens anymore (or any other problem) and it is a very fast video card. It has also has DisplayPort and has the same size or is slightly bigger than the 560Ti so it is small enough to fit into my (not-so-big) midtower case. I'm very happy with this 570 AMP video card and the excellent support of Zotac!
28-11-2011, 09:28 AM #24
@^ OMG!!!
Congrats!!
Zotac 560 ti BLACK SCREEN PROBLEM
By jokerisdead in forum Graphic cardsReplies: 1Last Post: 07-10-2011, 06:08 PM -
Problem..Screen Turns black for few seconds
By gunners009 in forum Graphic cardsReplies: 3Last Post: 27-08-2011, 08:16 PM -
Nokia 5800 black screen problem
By ico in forum Mobiles and TabletsReplies: 2Last Post: 11-08-2011, 07:13 AM -
The XP's black screen problem....
By pr.itdude in forum Software Q&AReplies: 4Last Post: 11-07-2010, 09:24 AM -
Help!! black screen ?? video problem!!!
By premvb6 in forum Software Q&AReplies: 4Last Post: 30-04-2009, 09:07 PM
LinkBack URL
About LinkBacks
