Page 1 of 4 1 2 3 4 LastLast
Results 1 to 30 of 118
  1. #1
    . Jaskanwar Singh's Avatar
    Feb 2010
    Amritsar
    Default Sapphire HD6950 1GB - Temperatures and Overclocking
    Guys i decided to overclock my card to 6970 clocks (880mhz).
    I used MSI Afterburner to monitor and Sapphire Trixx to oc. Stress test used was from TPU - GPUtool.
    I used 10mhz increments and set fan profile to 80% fixed. Ran test for 1 min after each increment.
    When i reached 880mhz the test ran. Screen went blank and recovered. Amd driver stopped and recovered. The test still ran but screen hanged. Temp was avg 75C and load 97-99%. Used task manager to close test.
    After that i ran black ops at highest settings and played it for 1hr. Totally stable and temp was avg 66c. Fan profile 80%.
    I didnt touch memory and voltage still and still have to measure fps increase.
    Was so engrossed in game that i got late for tutions.
    Screens and fps tomorrow.
    Comment on this oc.
    With profile at 100% what can i expect?
  2. #2
    Here I Comes You Viruses Geek-With-Lens's Avatar
    Jun 2011
    Mumbai
    Default Re: Sapphire HD6950 1GB - Temperatures and Overclocking
    That I Don't know But if you have guts then overclock this card beyond 1 ghz. MSI Twin Frozr Can.
    Back To ThinkDigit Forum After Long Break.
    Razer Carcharias 8-)
    Swan M10 :-D
  3. #3
    Feb 2010
    Amritsar
    ^check out overclock3d review. TFII could only reach 895mhz on stock volts. Each card is not same.
    And i wont touch voltage atleast now. No need.
  4. #4
    Jun 2011
    Mumbai
    N560GTX-Ti Twin Frozr II/OC Overclocking | bit-tech.net
    Man You've to refresh your knowledge Bit-tech guys has overclocked it to 975mhz without overvolting & with overvolting 1020mhz.
    MSI N560GTX Ti Twin Frozer II review
    974mhz without overvolting.
    Wastage of money on sapphire 6950 1gb.
    Swan M10 :-D
  5. #5
    Super Moderator Skud's Avatar
    Jun 2004
    10 light years away
    Yeah, you buy a graphics card for OCing, LOL.
    @Jas, what's the current temps of Amritsar? And your temps are with AC on or normal?
    Gaming Rig:i7 2600K | N620 | P8Z68 Deluxe | 2x4GB RipjawsX DDR3 1600 | Vertex 3 120GB | Logitech G510 | Logitech G400 | Sapphire 6950 1GB | BenQ G2420HD | Corsair HX750 | Lancool K62
    HTPC Rig: C2D E7400 | EP45-DS3R | 2x2GB DDR2 800 | MS Wireless Desktop 2000 | Gigabyte 5770 | Samsung 32" | Seasonic SII 520W | Silverstone LC10
    Audio Gear: Altec Lansing VS2421 | ASUS Vulcan ANC | HiFiMan RE-0
    Storage: 2x250GB | 3x500GB | 3x1TB | 3x2TB
    Android: Galaxy R | Galaxy Y
  6. #6
    Feb 2010
    Amritsar
    Quote Originally Posted by Geek-With-Lens View Post
    1.be specific which tf2 u were talking.
    2.g3d oced 6950 one to 987 without overvolting and oc3d to 895.
    3.Check out g3d forums and u will find 560 ti tf2 at 920-930. Do remember its already at 880.
    And if u want to argue on that topic then i will pm u tomorrow stating my proofs. Now go on - topic.
  7. #7
    Jun 2004
    10 light years away
    Check this also:-
    Graphics Cards related queries here.
    I will post my results later.
  8. #8
    Feb 2010
    Amritsar
    Quote Originally Posted by Skud View Post
    its around 35. the temps are without AC.
  9. #9
    Jun 2004
    10 light years away
    I am getting same temp figures as you in stock clocks. Waiting for yours pics. That's most important.
  10. #10
    Jun 2011
    Mumbai
    N560 Ti Twin Frozr II will be lot cooler than sapphire 6950 at any clock.
    Swan M10 :-D
  11. #11
    Jun 2004
    10 light years away
    Does it matter as long as your card doesn't overheat or show sign of problems?
    Off-topic: Have you decided about the cabinet?
  12. #12
    Jun 2011
    Mumbai
    All Three are good but lian li pc-k62 i've decided if not available cm 690 ii advanced or tempest evo.
    Swan M10 :-D
  13. #13
    Jun 2004
    10 light years away
    I am losing my novelty value because of you guys.
    OK, no more OT.
    Jas, give some more results.
  14. #14
    I am the night...I am... vickybat's Avatar
    Aug 2009
    Gotham City
    Quote Originally Posted by Jaskanwar Singh View Post
    Comment on this oc.
    At 80% fan speed all the time, you'll damage them in the long run. Fans will make whirring noise and eventually stop working. Its not at all advised to run them at 80% fixed all the time.
    Fan longevity will come crashing down. Don't even think of keeping them at 100% all the time.
    Download radeon pro and use fan settings from there.
    Core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book ,Seagate freeagent ext hdd 1tb , hp dvd writer,Apc 650 va, logitech z313 , Micromax Funbook , Klipsch image S3 (IEM).
  15. #15
    Jun 2004
    10 light years away
    Are you sure about this? If I am not mistaken previously in AGP era fans generally used to run at full pelt. Those cards serve years. This fan speed control thing is relatively new.
  16. #16
    Feb 2010
    Amritsar
    Quote Originally Posted by vickybat View Post
    ok. i will change them to automatic.
    and will download radeon pro.
    and which softwares to benchmark.
    dirt3 has inbuilt one too. skud you want it?
    then time to research on it.
    5870 fan @100 % = damage? - [H]ard|Forum
    [Solved] Adjusting Graphics Card Fan Speed - Graphics-Cards - Graphic-Displays
    they say by the time fan stops working, we would have upgraded to new card.
  17. #17
    Jun 2004
    10 light years away
    Yeah, Dirt3 bench please and vantage, if possible.
    Plus 3dmark11, heaven, avp, re5, metro 2033, crysis2. This should suffice.
  18. #18
    Aug 2009
    Gotham City
    @ jaskanwar singh
    hmm go for 3d mark vantage. The latest crysis 2 dx 11 benchmark is also very nice.
    Don't use msi kombuster ever. You can try furmark too. Try unigine heaven as well and see how good 6950 is in tess. Crysis 2 will be a practical benchmark for tess.
    But best way is to try at some real stressful titles like metro 2033, crysis 2 with dx11 , high res textures and everything set to ultra. Dirt 3 is also a good dx11 benchmark.
    About fans , they will indeed go kaput at those settings no matter what people say.
  19. #19
    Jun 2004
    10 light years away
    Regarding fan speed at least during winter we can keep it at default levels. I guess like Patna, Amritsar also gets very cold.
  20. #20
    Super Moderator asingh's Avatar
    May 2008
    New Delhi
    Jaskanwar, you should mention the FPS differentials you are getting. Stock vs. OC. At least 3-4 games.
  21. #21
    Aug 2009
    Gotham City
    Even in summer you can use default. Max 60% or at best 70% under heavy overclock but not for prolonged usage. Not at all recommended using at 80% or beyond.
  22. #22
    Feb 2010
    Amritsar
    ok. i dont have avp and metro though.
    yeah.
    Quote Originally Posted by asingh View Post
    ok. tomorrow i will put them.
  23. #23
    May 2008
    New Delhi
    Even Crysis 2, and any of the latest COD series.
  24. #24
    MV VIP to the MAX SlashDK's Avatar
    May 2010
    Delhi
    @Everyone
    Umm... I know that this may sound a nooby question but why do you guys over clock such high end PC's? Faster proessors = better for productivity but what about graphics? With the exceptions of a few games such as Crysis2 DX11, Metro2033 etc. and compute what difference does it make? I am personally running my Athlon ii x4 635 under clocked and undervolted and my HD 6850 is underclocked too. Sorry if this sounds amateurish but please clarify.
    Battlelog : DK-xxx-
    Steam : $/@$]-[ DK
  25. #25
    Jun 2004
    10 light years away
    yeah.
    You can download the RE5 and AVP benchmark tool from net. No need for full games.
    Quote Originally Posted by Cybertonic View Post
    @Everyone
    FUN!!! Also it gives an idea how far you can stretch your hardware.
  26. #26
    Treatment in progress... mukherjee's Avatar
    Apr 2005
    Amar shohor Kolkata
    Refrain from personal attacks.
    PC: Core i7 2600K||Z68V Pro||Noctua U12P SE2||Vengeance 1600Mhz 8GB||GTX560Ti HAWK||CM Elite 430||1TB+300GB||VX550||G110||G1 mouse||Razer Goliathus
    Photography: Nikon D5100||Nikon 55-300 VRII||Canon Powershot SX220HS||Tamrac Velocity 9x
    Audio:Brainwavz M4,B2,R1||Meelec A151||PX100 II||Fiio E5||AudioTechnica ATH-T500
  27. #27
    Jun 2004
    10 light years away
    I guess the Sapphire card is not minding at all.
  28. #28
    Feb 2010
    Amritsar
    asingh what are temps of your oced 4890s? and have you fixed fan profile to a value?
    UPlay - Jas808, Steam ID - HD6950, TF2 Outpost - Link
    Athlon II x4 635, CM Hyper 212 Evo, Gigabyte GA-880GM-UD2H, G.SKILL 6GB, Sapphire HD6950 1GB (Unlocked - HD6970), WDC 500GB Green, Corsair GS600, CM Elite 430, DELL ST2220L, X360 Controller, Logitech G400, Razor Goliathus Omega - Speed
    HP Pavilion G6 2005AX - Genuine Windows 8 Pro, Samsung Galaxy Y Duos
  29. #29
    In The Zone rchi84's Avatar
    May 2009
    Dubai, UAE
    Hi Jas
    Nice OC. but don't know why you didn't use afterburner to OC as it allows you to OC, monitor temps and adjust fan profiles all at once Once you enable unofficial overclocking, it allows you to up the GPU voltage too, if you need it.
    What are the stock volts on the Sapphire? If it's like mine (around 1100 mv), then you should be able to get it to 850/1300 atleast, without any problems.
    Memory OCing is not really needed, imho, as it only gives you a small boost. So you can keep the memory at 1250.
    Kombustor is Furmark with MSI branding, so don't know why it gets a negative. The only thing is that both Nvidia and AMD throttle the GPU when they detect you're running Furmark/Kombustor.
    Try OCCT. It's a very good test to check for memory artifacts. Run it on complexity 8, at 1080 fullscreen. It's usually very good at letting you know when Memory OC is unstable, as it overwhelms the DDR5 memory error correction.
    Based on personal experience, Metro 2033, Crysis 2, Witcher 2 and Assasin's creed brotherhood (surprisingly punishing on my card at 1080 with 8xAA, esp when you sync with viewpoints) would be good indicators of stability.
    If you can play crysis 2 for fifteen minutes, without getting a "AMD Driver has stopped responding" message, your OC is stable.
    Play with the afterburner fan profile, which is very useful, but remember to close the Powertune window in catalyst, which doesn't work when afterburner is running, anyway.
    Core i5 2400|| Gigabyte ph67 B3|| 8GB DDR3 1333|| 1TB WDC Black|| CM 690II Nvidia Edition|| CM 850W Silent Pro|| Samsung 2333T|| Gigabyte Geforce 670 2GB (Windforce 3x)|| Logitech G35 Headset
  30. #30
    Aug 2009
    Gotham City
    ^^ I think there should be a general ratio between core clocks and memory clocks. Simply because when you increase the core clocks without significantly increasing the memory clocks, the gpu performs faster operations per clock but when tries to fetch from the memory, gets slower due to lesser clock rates.
    So it renders faster but fetches data relatively slower and in the end, you don't see a significant overall performance increase.
    So i think, if you increase the core clocks to lets say 10mhz, memory clocks should also be incremented by the same value so that the overall ratio is maintained.
    This is completely my thinking but i could be wrong here.
  1. Overclocking my new Sapphire HD 7870
    By slashragnarok in forum Overclocking
    Last Post: 29-07-2012, 08:07 PM
  2. Overclocking n downclocking of sapphire 6870 ?
    By rohitiitbhu in forum Overclocking
    Last Post: 22-06-2012, 05:45 PM
  3. Overclocking Sapphire Radeon HD6570
    By vaibhav23 in forum Overclocking
    Last Post: 10-06-2012, 05:07 AM
  4. [Want to Buy] Hd6950 2gb
    By malcolm_cg in forum Want to Buy
    Last Post: 23-05-2012, 12:41 PM
  5. Replies: 12
    Last Post: 12-09-2011, 12:39 PM
