Results 1 to 18 of 18
  1. #1
    Right Off the Assembly Line dippi_taurus's Avatar
    Sep 2007
    Bangalore
    Post Graphic card for a P4 system
    Hello guys,
    This is my PC spec. I have a HP Pavilion a1320in pc with a P4, 3.06Ghz with HT processor. My mobo has a PCI X16 slot and a 2x 1GB RAM. PSU is a stock 230W. Now, I am in need of a graphics card and the one I have in mind is the ATI Radeon HD 4870 1GB. For this, I would also like your suggestions on a good PSU. My question is, will the above mentioned card run on my system? If not could you suggest one. There is no price margin so please feel free to post some good ones.
    Now, before you go any further, I like to add that I also know that my CPU is outdated and is gonna be a bottleneck for the GPU. And I'm not likely to upgrade my system for now. So, please don't mention it.
    Could you also tell me the price and company of both the GPU & PSU with good customer satisfaction.
  2. #2
    Fast 'N' Furious topgear's Avatar
    Jul 2006
    Geek's Heaven
    Default Re: Graphic card for a P4 system
    HD4870 is power hungry OLD card - no point in getting this.
    For your system best would be Sapphire HD6670 1GB GDDr5 @ 5.5k / Sapphire HD6750 1GB GDDR5 @ 6k along with a FSp saga II 350W PSU @ 1.5k
    Who Dares Wins
    Avenging Angel !
    Phenom II 955BEAsus M5a97 R2.0Corsair 2x 4GB RAMHD6850Corsair GS600CM Hyper 212CM 430 Elite
    My Blog : http://topgeartopspeed.wordpress.com/
    BlackListed : Viewsonic, Gigabyte
  3. #3
    Sep 2007
    Bangalore
    Post Re: Graphic card for a P4 system
    Quote Originally Posted by topgear View Post
    Hey dude, thanks for the reply. Just checked the Sapphire Readeon HD6750 1GB. Looks great. The question is the card features a PCIe X16 2.1 interface. Wouldn't this be a problem. I mean I've read in a couple of places that the 2.1 interface gives a lot of trouble regarding backwards compatibility. Well what do you say? Have you checked it in a system with a PCIe x16 interface?
    Also the card looks a bit big. What is its' form factor? I don't know if it fits in my system but the motherboard has a micro atx form factor.
  4. #4
    sam
    sam is offline
    Forum Moderator sam's Avatar
    Jan 2010
    Guwahati
    Quote Originally Posted by dippi_taurus View Post
    where?
    many have used PCIe 2.0 card in PCIe 1.0 slot without any problem.
    The AMD site says that the card has a PCIe x16 interface, but Sapphire says that its a x16 2.1 interface. What gives?
    the particular card, Sapphire HD6750 uses PCIe 2.1 connector. also AMD makes the GPU so they gave a reference. it is upto their AIB partners what they want to do. bundle 512Mb/1Gb/2Gb VRAM of type GDDR3/GDDR4/GDDR5 & what type of cooling to use.
    depends on the cabby & what other expansion card you are using. most midrange cards use 2 slot coolers. so if nothing is blocking it, then it should fit fine. also check for hard drive that may block the card's power supply points.
  5. #5
    Sep 2007
    Bangalore
    Quote Originally Posted by Sam View Post
    So, you're saying that I wouldn't have any problem running a PCIe x16 2.1 card in a PCIe x16 slot, right?
    I don't have any other expansion cards and I have one 1TB hard drive.
  6. #6
    Jul 2006
    Geek's Heaven
    ^^ Make sure you have the latest bios version for your mobo.
    That card should easily fit inside most of the cabinets.
    Who Dares Wins
    Avenging Angel !
  7. #7
    Sep 2007
    Bangalore
    Ok guys, now that the graphics card has been finalized could you suggest me a good PSU for this card. I'm looking for a good branded one with good components and customer satisfaction. The FSp saga II is not available at my place though. Please help.
  8. #8
    Wise Old Owl mithun_mrg's Avatar
    Oct 2003
    Assam
    Go for a Corsair CX430 or GS600
  9. #9
    Jul 2006
    Geek's Heaven
    GS600 @ 4k would be an overkill for his present config but it's good choice for future thoiugh
    CX430 is enough for him and if he can find a CX400 it would be just great.
    Who Dares Wins
    Avenging Angel !
  10. #10
    Sep 2007
    Bangalore
    Sorry for the delay guys. Was kinda busy with work. Was wondering......... among the 6670 1GB & 6750 1GB which company should I buy from? - Sapphire, MSI or XFX?
  11. #11
    Jul 2006
    Geek's Heaven
    avoid the last one and now you have two choices - so make your decision
    Who Dares Wins
    Avenging Angel !
  12. #12
    Sep 2007
    Bangalore
    Ok here's the quotation the guy gave me-
    1. Sapphire HD 6670 1GB - Rs. 5200
    1. Sapphire HD 6750 1GB - Rs. 5400
    2. Sapphire HD 6770 1GB - Rs. 6700
    3. Corsair CX400 - NA
    4. Corsair CX430 V2 - Rs. 2000
    5. Corsair VX450 - NA
    6. Corsair VX550/GS 600/GS700 - NA/3700/4700
    7. HDMI cable - Rs. 300/500 [LOCAL/BELKIN]
    Wondering if I should go for 6750 which is just a couple of hundred rupees difference. Also I couldn't find the CX400 or CX450 anywhere but since there's CX430 v2 should I go for that or the GS 600?
  13. #13
    sam
    sam is offline
    Jan 2010
    Guwahati
    go for 6750. price is good.
    about the PSU, if you have budget go for the GS unit but it'll only allow you to go for some highend GPU later not multi-GPU. the CX430 v2 unit is damn cheap. and according to Jonny's review it is a good unit for the money.
    but are you sure the price of CX430W v2 is 2k?
  14. #14
    Jul 2006
    Geek's Heaven
    yep, get HD6750 and Corsair CX430 V2 - the price of the PSU seems very low though
    Who Dares Wins
    Avenging Angel !
  15. #15
    Sep 2007
    Bangalore
    Yes it is.
  16. #16
    Jul 2006
    Geek's Heaven
    ^^ in Kolkata CX430W v2 is 2.8k - you are getting it for vey cheap - don't miss this chance
    Who Dares Wins
    Avenging Angel !
  17. #17
    . fz8975's Avatar
    Jun 2011
    surat/anand
    its p4 PC 6750 will bottleneck ??
  18. #18
    ico is offline
    . ico's Avatar
    Jun 2007
    Bangalore
    yup, P4 is a bottleneck.
    I think the OP was buying so that he could even use it later - after upgrading from P4.
    anyhow, don't bump old threads.
    AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn) | 2 * 4 GB Corsair 1600 Mhz Value RAM | Corsair CX430v2 | NZXT Gamma | Dell S2240L 22" @ 1080p
    Intel i5-2500K | Asus P8Z68 Deluxe | 2 * 4 GB Corsair Vengeance | WD Caviar Blue 500 GB | CM Hyper 212 Evo | AMD Radeon HD 6950 2 GB | NZXT Tempest Evo | Corsair AX850 | AverMedia AverTV Capture HD H727
    Samsung Galaxy S2 | Mac mini (Late 2009) with OS X Mountain Lion, 10.8
    Pandaboard ES | OMAP 4460 SoC | 2 * ARM Cortex A9 cores | PowerVR SGX540 graphics
    Arch Linux amd64 | Ubuntu 12.04 amd64 + omap4 ARM | Windows 7 x64
  1. Dual graphics card or a single high end graphic card
    By Gamersam in forum Graphic cards
    Last Post: 13-05-2012, 12:36 AM
  2. need graphic card for my system
    By pawannarwani91 in forum Graphic cards
    Last Post: 01-02-2012, 06:54 AM
  3. Suggest me a Graphic Card, Case and Cooling System! 25k Budget
    By krish_puri in forum PC Components / Configurations
    Last Post: 06-10-2011, 11:36 PM
  4. New system proc mobo graphic card ram
    By ASH_DSG in forum Graphic cards
    Last Post: 02-01-2010, 01:37 PM
  5. Graphic card limit for my system?
    By yrana2002 in forum Graphic cards
    Last Post: 01-12-2008, 10:57 AM
