| Forum |
| Graphic cards News, discussions, queries and problems related to Graphic cards. |
#1 (permalink) |
to some decent new system....... or a gfx card like hd 4670 should be enough with normal psu....can win 7 run on older systems ? |
#4 (permalink) |
I have 17 inch crt monitor mainly resolution is 1024*768, game at even 800*600 is good 4 me
i need gfx card mainly 4 mid range gaming,may be i buy a laptop as i'm out of home town 4 studies,so i don't want to spent any extra peny. |
#5 (permalink) |
IM AS MAD AS HELL!!
sys upgrade , DDR2 is cheaper
When someone dies in the grip of a powerful rage... a curse is born. Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk! |
#6 (permalink) | |
What type of SMPS do you have?
Intel Core i3 2100 //4GB Corsair DDR3 1333 RAM //Intel DH61WW//Sony AD-7260S DVD-RW//Samsung 2033SW Monitor//Windows 7//Seagate ST3250310AS 250GB HDD |
#7 (permalink) |
IM AS MAD AS HELL!!
wont be other components bottelneck the card ? also what if he gets spanking new LCD after few months ?
#8 (permalink) |
To the thread opener(hskpunjabi): Please specify your budget properly for us to assist you in your upgrade......max_demon...you are right about the bottleneck....lets see what upgrade budget he has.
#9 (permalink) |
As i said before i may buy a basic laptop as i am out of town 4 study,so i am thinking of gfx card hd4670 as upgrade(found after reading review on net)
i am upgrading home pc 4 gaming only like cod n' other fps games etc(p4 ht 3.06 ghz+2 gb ddr ram+asus board p5rd1-vm) so is selection right,i have normal 450 watt psu |
#12 (permalink) | |
Zenith SO Director Plus Ultra cost is around 33k as found in thread...comment on this Zenith SO Director Plus Ultra C2D 6500 2.1 Ghz (800 Mhz FSB, 2 MB L2 Cache) 2 GB DDR2 Ram (667 Mhz) 320 GB 5400 RPM SATA HDD Nvidia 9600 M GS 512 MB Dedicated Gfx card 15.6" WXGA screen (1280X800 max Resolution) 2 MP Webcam Bluetooth 10/100/1000 Mbps LAN WiFi 56 Kbps Modem 3 in 1 Card Reader PCI Express expansion slot Built-in High Definition Audio – 2 Channel; 2 Stereo Speakers; 2 Omni-Directional Digital Microphones 2 USB, 1 USB/E-sata combo and others. URL:http://www.zenithpc.com/zenithso-dir...sultra-bb.aspx |
#13 (permalink) |
EXIT: DATA Junkyard
Go for propous quads and DX11 hardware coming next month!
http://pleaseguide.me/ |
#14 (permalink) | |
Please answer these questions. 1. What is the max RAM support for your board? 2. Does your P4 3.06(assuming prescott) has support for 64 Bit? 3. Are you a light or a heavy Gamer? 4. What is the max resolution your monitor can support? Lastly how much can you spend for upgrading your current components? |
#15 (permalink) | |
2. it has 64 bit + hyper threading(HT) support....bit old so should it b changed?? 3. i'm not a heavy gamer,games with medium or lower setting r fine....should be playable smoothly 4.17'' Lg monitor currently running on 1024*768...may be it support 1280*600.....but if games can run fine on 800*600....they r welcomed if i have to change processor+ram+mboard.....budget will be around 10 k....i think rest parts can b used like(1 ide+1sata hd-disk,sony dvd rw...etc) i have plan to upgrade pc in December when my exams would be over,by then prices should fall ( as i heard they will after win 7 +dx 11 cards's launch) Last edited by hskpunjabi; 14-09-2009 at 06:45 AM. |
#16 (permalink) |
It would be better to put HD4650/4670 as they com pretty Cheap.
BTW your config is pretty good at least better than Mine which doesnot support 64 bit Don't sell it off after putting the Graphics Card, make an HTPC out of it. This is my config Intel Pentium 4 3.00Ghz HT enabled processor(Prescott) Intel D865GBF motherboard SoundMAX 1985 Digital Audio(6 channel) Sapphire ATi Radeon HD3650 512MB DDR2 AGP 8x Samsung IDE HDD 80GB Lite-ON DVDRom and Lite-On DVDRW 1GB DDR 400Mhz (2x512MB) Dual Channel mode |
#17 (permalink) |
If you can sell your current Proccy+mobo+ram for ~ 3k (ram alone should go >1.4k) ..then you can pickup
Mobo - Gigabyte G31 - 2.4k Proccy - E5300 - 3.4k Ram 2 Gb - 1.2k Gfx - Ati 4670/9600gt 4k Total - 11 - 3 = 8k .. but now you have good enough rig for next 2-3 years, and for your monitor resolution it will play most of the games at high settings. |
#19 (permalink) | |
GaurishSharma.com
#21 (permalink) | |
which should be bought in able to play games/run win 7....as some time games require high processors.......i basically love 2 play fps games loke call of duty, company of heros....nfs etc how much ram should i buy( thinking of 4 gb's so 64 bit xp or win 7 is reqd . as well as 64 bit processor support do dual core's n core 2 due's have this support?? Last edited by hskpunjabi; 19-09-2009 at 02:15 PM. |
#24 (permalink) |
Crowman
Hey hskpunjabi AMD has Athlon II X4 620 Quad core @ 5.5k which is waaaay better than Core 2 Duo E7400 @ 5.5k and for mobo you can get Biostar TA785GE 128M @ 4.2k, which doesnt need you to buy a GFX card. U can game and enjoy your windows 7 at medium settings too (for gaming). Sure you dont want AMD?
Like a post? Use the reputation button.
Abusive, offtopic post? Use the report post button. Read before messaging any moderator for any query: FAQ + answers for new members Read all the sticky threads before asking any type of query. Most basic questions are answered in those. |
#25 (permalink) |
@OP AFIAk.. E5300's architecture is same as Core2duo, so basically they are C2D processors with may be less cache.. no problem with the proccy..if you can extend your budget a little then AMD solution will be best too as suggested above.. btw E5300 is fine since you will be mostly limited by GFX performance. this config can easily play CRYSIS at medium-high setting on your monitor.
#27 (permalink) |
Bond, Desi Bond!
@hskpunjabi, what techalomaniac said is true. Athlon II X4 quad core is available for 5.5k and it has much more VFM, thanks to two extra cores. Even a dual core Athlon II X2 250 that is available for 3.5k competes with E7400. and G31 mobos are very very basic.
my suggestion for you is to go for AMD rig with X4 630, 785G mobo and DDR3 RAM. This will be able to run most of the current gen games at low to medium settings and easily plays highdef content. then wait for the release of budget DX11 cards from ATI and nVidia (ATI's should be in by end of October and nVidia's should be in by next month). that would make your rig better placed for next upgrades when compared to already stale E7400+G31+9xxxGT
My first blogspace: http://desiibond.blogspot.com |
#28 (permalink) |
okay....write some amd configs with prices,,,are there onboard 256 mb graphics as in intel's boards///////
are laptops cheaper in dubai?? how much cheaper? one of my friend is planning to bring one for him. i might also ask to get one 4 me if deal is good... Last edited by hskpunjabi; 26-09-2009 at 07:30 AM. |
#29 (permalink) |
Laptops r cheaper in dubai but make sure its purchased frm a duty free shop...' in hongkong , singapore , china and taiwan r places where u can get any electronics products in damm cheap prices...'
Recently my uncle brought me a omega seamaster planet ocean james bond series watch which he wearing in quantum of solace movie...' its cost around $750 + taxes roughly @ 75000 bucks...' he bought it @ 38000 bucks frm singapore...' And go 4 Amd rig....' its vfm in every aspect....' |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
