Go Back   Digit Technology Discussion Forum > Hardware > Graphic cards
Graphic cards News, discussions, queries and problems related to Graphic cards.
Old 03-07-2009, 04:52 AM   #1 (permalink)
Arrow Graphic Card suggestion.
Hi all.
I currently have a 23 " Acer LCD monitor it has HDMI input. C2D 2.66 and 2GB ram. need a budget graphic card. I thought of Palit 9500GT / 9400GT both have HDMI output.
1> do i need a new smps ? I have the standard smps 400w that comes with cabinet.
2> any other graphic card that around the same price as above.
I am not a gamer. just causal gaming..racing and FPS stuff maybe an hour or less than that daily. need pointers on which wud be a better graphic card for me...
agm_1052001 is offline
Old 03-07-2009, 08:35 AM   #2 (permalink)
dOm1naTOr's Avatar
Default Re: Graphic Card suggestion.
Sapphire HD 4670 512 DDR3 for 4.2k
Also Gecube can be considered around same price. Much better than 9500GT.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 03-07-2009, 11:14 AM   #3 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
+1 for HD4670. DOn't consider 9500GT especially when HD4670 is available at such a price.
http://pleaseguide.me/
comp@ddict is offline
Old 03-07-2009, 11:38 AM   #4 (permalink)
Make Way the LORD is Here
ssk_the_gr8's Avatar
Ati radeon hd 4670 is what you should buy.
(Gen.1:26-27) New Testament
FORUM RULES - Updated
Don't Buy from Sulekha
ssk_the_gr8 is offline
Old 04-07-2009, 01:43 AM   #5 (permalink)
Alrite guys HD 4670 is the common choice...now again i m nt a gamming geek god (GGG) so tell me diff between shappire , ati radeon .. are they just diff companies using the chipset ?? and looking at the specs i think i would need a smps ..so which one should i go for ....
Old 04-07-2009, 01:59 AM   #6 (permalink)
dOm1naTOr's Avatar
sapphire is a brand who makes cards out of ATI GPU. Other brands like sapphire are gecube, xfx, asus, msi , palit etc.
4670 generally dun need much power as other cards. It also dun need any additional power connector. So any generic 450W PSu can run it.
If u want to be on safer side, get a zebby Pro 400 or 450W PSU. They are for around 2k.
G3: XPS M1530 |
FZ 16.
Old 04-07-2009, 03:21 PM   #7 (permalink)
I'd suggest sapphire and msi. As for a new psu . I dont think u'll need one.
Old 04-07-2009, 03:54 PM   #8 (permalink)
damnbadman666
damngoodman999's Avatar
Sapphire is good !!
AMD Phenom 2 940 @ 3.4Ghz [Hyper 212+] MA790GP-UD4H OCZ DDR2 2x2GB Asus GTX 560ti 1TB SATA2 LG 20" LED Razer DA mice RED HOT cabby
damngoodman999 is offline
