Go Back   Digit Technology Discussion Forum > Hardware > Graphic cards
Graphic cards News, discussions, queries and problems related to Graphic cards.
Old 10-04-2009, 09:54 PM   #1 (permalink)
Default lcd monitor or graphics card problem
i have the following sys:
intel c2d e6700
asus commando mother board
2*2gb transcend 800mhz ram
250gb sata 2 hard disk
vg1930 viewsonic 19inch lcd screen
leadtek 8800gts 640mb
windows xp x64
my problem is that I get lot of vertical lines on the screen a startup and i am not able to boot into normal mode, but i can get in safe mode. at first i was able to go into normal mode but after few seconds part of the screen was getting filled by violet color and the system gets stuck and i had to restart it....i changed the graphics card from the currnt pcie slot to another which i havent used before but the same problem occured. i even chnged the monitor interface from dvi to d-sub still no change, at first when i used d-sub the whole screen became violet instead of part of the screen. later wen i removed the d-sub cabal and reattached it, it became normal but still aprt violet appeared and system got hanged.....after some time i could not boot into normal mode, but was able to go into safe mode....i have the latest nvidia graphics drivers installed....the problem didnt occur immediately after installing latest drivers....wat is the problem my monitor or graphics card???
vamsi23 is offline
Old 10-04-2009, 09:59 PM   #2 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Default Re: lcd monitor or graphics card problem
I think ur monitor is going crank. Happens with ViewSonic afaik.
http://pleaseguide.me/
comp@ddict is offline
Old 11-04-2009, 04:02 PM   #3 (permalink)
thx for the reply
vamsi23 is offline
Old 11-04-2009, 04:45 PM   #4 (permalink)
Excessive happiness
furious_gamer's Avatar
Is it so? Never heard anything like this before. I myself having a 19" ViewSonic and till date have no problems with it. Just a info.
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Addicted to Game Dev & Grand Prix Story
furious_gamer is offline
Old 11-04-2009, 04:57 PM   #5 (permalink)
The Sorcerer's Avatar
^^ Prepared to be suprised:
http://blogs.techrepublic.com.com/helpdesk/?p=404
http://tech2.in.com/india/news/monit...-users/18411/0
http://www.team-bhp.com/forum/gadget...lcd-india.html
Viewsonic's after sales has gone bad since 2007. If you run a search on consumer complaints forums, there some more where that came from.
The Sorcerer is offline
Old 11-04-2009, 05:04 PM   #6 (permalink)
Excessive happiness
^^ Thats really shocked. I am lucky one,as till date i had no problems with it...
Old 12-04-2009, 09:44 AM   #7 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
That's the reason I took out the VX2255wm from my list and replaced it with the Samsung 2233SW FULL HD for Rs. 10,100
Old 12-04-2009, 09:55 PM   #8 (permalink)
i took my graphics card and installed in my dad's system and the same problem occured...so i think its GC...but when i placed my dad's GC in my sys nothing happened, the monitor didnt show anything.....the power button color of monitor was normal, but the screen was blank....any idea wat could be wrong other than GC??????
vamsi23 is offline
Old 12-04-2009, 10:42 PM   #9 (permalink)
GC is most probably fried because of the power supply. Which reminds me to ask a generic question to the OP- which power supply?
Old 13-04-2009, 06:38 PM   #10 (permalink)
500watts zebronics
Posted again:
500 watts zebronics
vamsi23 is offline
Old 13-04-2009, 07:49 PM   #11 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
500watts zebronics
I think this is the reason. Now u're gfx card is kaput, and u'll hav 2 buy a new one + new PSU.
Old 13-04-2009, 11:43 PM   #12 (permalink)
great....but my sys is already 1.5 years old it never gave any problem except playing gta4 all settings max my psu burned, but got it replaced and was working fine nothing happened to GC first time...started playing gta 4 again but with auto config settings it worked for 3 days....can u suggest good psu....how is corsair hx 620 or tx 650 which is better????
vamsi23 is offline
Old 14-04-2009, 10:18 AM   #13 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
^^I think u'll hav to buy new gfx card too.
Here:-
Cooler Master 500W ExP @ 2.8k
Sapphire/Palit HD4830 512MB GDDR3 @ 7.6k
Total = Rs. 10,400
