Go Back   Digit Technology Discussion Forum > Hardware > CPU / Motherboards
CPU / Motherboards News, discussions, queries and problems related to CPUs and motherboards. Section Thread Index
Old 02-09-2004, 03:53 PM   #1 (permalink)
Default Help needed with nforce mobo and R-Connect
I have a krypton c18g-400 motherboard with the nforce2 chipset with onboard Geforce 4mx. The problem is that my LG RD2030 Reliance handset drops the connection after 1 or 2 minutes. Samsung handsets from Reliance work fine. After investigating, i have found that the LG handsets from Reliance give this problem with any nforce1 and nforce2 chipset based boards. I have checked the handset with more than one nforce1/2 based boards. Samsungs work fine. Due to this problem R-connect has become unusable. Also, no black&white samsungs available from reliance anymore. Please suggest a solution so that I dont have to change my motherboard. I use WinXp pro.
sirajpatel is offline
Old 02-09-2004, 08:10 PM   #2 (permalink)
King of my own Castle
freshseasons's Avatar
I dont think basically nforce 2 or nforce3 is the problem...try softwares that keep the internect connect Alive or check the status of LG handset option that it doesnt disconnect after 2 or 3 minutes...
freshseasons is online now
Old 10-09-2004, 04:05 PM   #3 (permalink)
Thanks freshseasons. But I tried both the suggestions already. No result. Besides, the LG works fine on motherboards with other chipsets. And samsungs work fine on mine. Please someone help.
- by kool
- by Jripper
- by kool
