Go Back   Digit Technology Discussion Forum > Hardware > CPU / Motherboards
CPU / Motherboards News, discussions, queries and problems related to CPUs and motherboards. Section Thread Index
Old 25-04-2005, 09:58 AM   #1 (permalink)
Stareable.com
Default CPU temperature 99 deg
Hello guys,
i am in big trouble, i removed the thermal paste that i got with the Intel fan, just to see the difference in temperatures. And now the CPU temp goes up to 98-99 deg. With the paste it went up to 85 and now its very high.
Where can i get that paste from and for how much ?
Also ,
I need a good cooling fan for around 600 Rs.
Co-founder, http://stareable.com
Mumbai
risqer is offline
Old 25-04-2005, 10:32 AM   #2 (permalink)
geek_rohit's Avatar
Dude that thermal paste was there for a reason. Intel ain't putting there without one. You shouldn't have messed up with it on the first part. Now you should put in some thermal paste ASAP. Or you are shortening the life of your processor. Get the paste from a computer dealer. And as for the fan, get one which is from a good make. And put it adjacent to the heatsink on the cabinet's rear part.
SportZForumZ - We Know Your Game Better
http://www.sportzforumz.com
My Site & Blog
http://www.rohit-sharma.com
geek_rohit is offline
Old 25-04-2005, 12:06 PM   #3 (permalink)
whats te costof a good quality thermal glease or thermal paste?
Happy Computing :lol:
krishnathelord is offline
Old 25-04-2005, 12:17 PM   #4 (permalink)
artic silver will cost around 450-500 ...
check out http://www.arcticsilver.com/arctic_s...tions_big2.htm
grinning_devil is offline
Old 25-04-2005, 01:32 PM   #5 (permalink)
Stop whatever you're doing right now, put off your comp. Get any thermal paste. Don't bother about Arctic Silver right now.
Scrape off any thermal sticker residue with a blunt instrument. Careful not to break anything.
Use a good quality solvent to clean heat sink contact area and CPU surface. Clean thoroughly until everything shines like in the Pril ad Any solvent with minimum additives will do for now. Preferably flick your girlfriends acetone based nail polish remover.
Now apply a very small amount of thermal paste on the cpu core to fully cover the top surface. Quantity is critical. Excess will only reduce thermal conductivity and worsen matters in a few months when it starts caking.
Use a pea drop of paste, and a credit card sized stiff cardboard to spread paste evenly, in one direction, straight strokes until fully covered. Patience is the key here if you wanna get max coverage with min paste.
It's not necessary to apply paste on heat sink. Just give it a small left right twist once seated on CPU to spread paste. Clip on the retainer.
That's it, and don't forget to replace that nail polish remover before you get caught for stealing.
Cheers,
Keith
Keith Sebastian is offline
Old 25-04-2005, 02:12 PM   #6 (permalink)
what were you trying to do exactly by removing the thermal paste
Keith has given you a gr8 detailed solution simply follow it.
currently just dont operate your comp with the thermal paste removed
just to prevent any damage
If its possible for you to get Artic Silver 5 get it or currently get a good
thermal paste from a computer dealer and apply it.
Artic Silver will provide better cooling than any other thermal paste.
Overclock Me.
Overvolt Me.
AMD Me.
quad master is offline
Old 25-04-2005, 02:48 PM   #7 (permalink)
Please HELP where do you get this help with a tele no / address I have been hunting for this.
PLEASE PLEASE help
**** happens
pradeep_chauhan is offline
Old 25-04-2005, 03:46 PM   #8 (permalink)
That can be got from Prime Abgb, lamington road, mumbai, cost shud be arnd 550-600.
www.techenclave.com Ecumenical Technology !:)
blade_runner is offline
Old 25-04-2005, 08:30 PM   #9 (permalink)
I am in bangalore pl can you help me with a telephone number.
Thanks
**** happens
Old 27-04-2005, 11:00 PM   #10 (permalink)
sidewinder's Avatar
99 degree!!!!!!!!!!!!!!!!!!!!!!!!!!!111 u ccan even cook ur food over that
sidewinder is offline
Old 01-05-2005, 03:13 PM   #11 (permalink)
Arctic Silver 5 is not good for Prescott's Original Intel HSF, as the shape of the HSF is little different.
Best is the thermal pad.
This is my personal experience.
I have Intel Prescott 3.4 GHz with original Intel HSF. I bought AS5 for 600 bucks and found out that its not good for Prescott's HSF.
The reason is that the Prescott's HSF has a curve in its bottom and there is no contact with the processor as AS5 is Semisolid where as the thermal pad is solid and can stick to the curve of the HSF.
Kannan.
Binary Bits
http://www.binarybits.net
Kannan is offline
Old 01-05-2005, 05:50 PM   #12 (permalink)
which colling solution,fan etc should i go for if i want / need etc to that is with built by ati radeon 9800pro 128mb so that warranty isn't void.
how do i check temp?
akshayt is offline
Old 01-05-2005, 06:19 PM   #13 (permalink)
Do you talk like that in real life too ??
The only thing which I could properly understand was
You can use Speed Fan (Click Here)
Kannan.
Binary Bits
Kannan is offline
Old 01-05-2005, 07:10 PM   #14 (permalink)
wud be fun nd nice to meet him...
the meeting will be over in a flash...ofcourse without ny commas,fullstops !!!
Old 02-05-2005, 04:07 PM   #15 (permalink)
now from where you can get good thermal pads..in mumbai....any installation instructions????
Ankit is offline
Old 05-05-2005, 04:01 PM   #16 (permalink)
club_pranay's Avatar
if the heat sink thing fails.... pls get your processor replaced!!
my P4 1.6 ghz also behaved the same way.... i tried everything... from a good quality heatsink, fan, thermal paste etc.... but later found out that there was sonething wrong with the processor.... it took 15 days and it got replaced... and the problem was solved
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 06-05-2005, 10:47 PM   #17 (permalink)
Don't use PC for a long time in this condition else the processor wud be damaged, Apply the paste ASAP, Get it from Lamington Road if u stay in mumbai.
PM me if you have any difficulties regarding your Symbian OS cellphone.
suhasingale is offline
Old 05-09-2007, 07:49 AM   #18 (permalink)
GaurishSharma.com
gary4gar's Avatar
Default Re: CPU temperature 99 deg
Hey..its going to blow up soon
gary4gar is offline
Old 05-09-2007, 09:33 AM   #19 (permalink)
MVP in VC++
Why did u dig up such a old thread yaar???
cvvikram is offline
Old 05-09-2007, 11:10 AM   #20 (permalink)
Rubik's Uncle!!
Charan's Avatar
Eh? gary4gar bumping a two year old thread? I just cannot believe it.
Reporting...
Charan is online now
Old 05-09-2007, 12:55 PM   #21 (permalink)
shantanu's Avatar
gary4gar : old member and this kind of thing... next time misery
shantanu is offline
- by kool
- by Jripper
- by kool
