Go Back   Digit Technology Discussion Forum > Hardware > CPU / Motherboards
CPU / Motherboards News, discussions, queries and problems related to CPUs and motherboards. Section Thread Index
Old 26-04-2008, 07:27 PM   #1 (permalink)
ajaybc's Avatar
Question Please suggest Processor+Motherboard under 14K
My friend is thinking of upgrading his computer with a new processor and motherboard.His budget is 14K.both Intel and amd based solutions are preferred.The mobo shud have onboard graphics and PCIE slot so that he can connect a graphics card later.
I have shortlisted MSI P6NGM and Abit IP35-E motherboards.
Please suggest a gud mobo and procy .The usage is basically gaming and movies
Available for freelance web design and web development jobs.
You can view my portfolio here.
Ajay Balachandran
Please contact via PM
ajaybc is offline
Old 27-04-2008, 03:18 PM   #2 (permalink)
ajaybc's Avatar
Angry Re: Processor+Motherboard under 14K
NOT EVEN A SINGLE REPLY!(IS THIS REALLY DIGIT FORUM?!BECAUSE I KNOW THE GUYS AT DIGIT FORUM LOVES TO HELP OUT
Ajay Balachandran
ajaybc is offline
Old 27-04-2008, 03:30 PM   #3 (permalink)
Living to Succeed
ajayashish's Avatar
Default Re: Processor+Motherboard under 14K
well for onboard graphics IP35 will not be considered... u can consider XFX 650i as it has got onboard gforce 6100 and also has PCI-E slot...
ask him to get a second had graphic card around 2-3k and IP35 with good processor and that will be better
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
ajayashish is offline
Old 27-04-2008, 03:40 PM   #4 (permalink)
Google Bot
Pathik's Avatar
Even the xfx 650i doesnt hav onboard gfx. Get the abit ip35e , a e8200 and a 8400gs. About 14.x k
Pathik is offline
Old 27-04-2008, 03:48 PM   #5 (permalink)
Living to Succeed
ajayashish's Avatar
^^^ my mistake XFX 630i has onboard Gforce 7150
Old 27-04-2008, 03:53 PM   #6 (permalink)
MOBO- Gigabyte GA-MA78GM-S2H with radeon 3200 onboard gfx(the best among all in onboard gfx)-4.5-5K
proccy-AMD Phenom 9500 - 8K
The best AMD solution under 14 K IMO.
If u dont need phenom then u can get 5000 + X2 black edition for 5-5.5K
SunnyChahal is offline
Old 27-04-2008, 04:01 PM   #7 (permalink)
ajaybc's Avatar
Question Re: Processor+Motherboard under 14K
Is phenom quad core?
Does it perform better than the intel counterparts?
Ajay Balachandran
ajaybc is offline
Old 28-04-2008, 01:06 PM   #8 (permalink)
Cool Buddy's Avatar
you should not consider a quad core at the moment as anyways games wont utilise it & it is also a bit expensive at the moment. Instead go for an AMD X2 5000+ and buy a Geforce 8600 or 8500 based graphics card, would be better for gaming.
Cool Buddy is offline
Old 28-04-2008, 01:17 PM   #9 (permalink)
ajaybc's Avatar
Thanks buddy
Ajay Balachandran
ajaybc is offline
Old 28-04-2008, 02:03 PM   #10 (permalink)
Gigabyte G33 mb @3600 & Intel C2D E6550 or later @ 7000
Abit P35-E @ 5.6K with E6xxx @ 7k + GPU 1.5K.
4 mb cache take care all growing needs
gcbeldar is offline
Old 28-04-2008, 08:41 PM   #11 (permalink)
ajaybc's Avatar
Talking Re: Processor+Motherboard under 14K
It is not Gigabyte G33 it is Gigabyte GA-G31M-S2L Motherboard
It costs around Rs.3205
Dint think G33 boards were that cheap.Thanks
Ajay Balachandran
ajaybc is offline
Help with Processor + Motherboard abhipal Hardware Q&A 12 08-08-2007 02:24 AM
processor with this motherboard clmlbx Hardware Q&A 22 01-05-2007 10:07 PM
Need a Processor and motherboard anilthomas26 Hardware Q&A 6 12-11-2006 01:36 PM
- by kool
- by Jripper
- by kool
