Go Back   Digit Technology Discussion Forum > Hardware > CPU / Motherboards
CPU / Motherboards News, discussions, queries and problems related to CPUs and motherboards. Section Thread Index
Old 29-03-2005, 09:20 PM   #1 (permalink)
Default sli mobos
can u use an sli mobo with only 1 gfx card?
CyBorG3132 is offline
Old 29-03-2005, 09:27 PM   #2 (permalink)
Default Yes
Yep u can use a single card in an sli mobo.
vasanth_12345 is offline
Old 29-03-2005, 11:05 PM   #3 (permalink)
enoonmai's Avatar
If you use a single card in an SLI mobo, it will run at x16. Using two identical cards from the same manufacturer in SLI mode will make the cards run at x8 each. You can indeed run the computer on a single video card without a hitch and upgrade to another video card for SLI mode if its necessary.
Playing FEAR XP/LSW2
enoonmai is offline
- by kool
- by Jripper
- by kool
