Results 1 to 4 of 4
  1. #1
    Wise Old Owl Cool Buddy's Avatar
    Mar 2006
    Milky way
    Default Buying a motherboard
    Looking at the digit motherboard shootout I've decided to buy the MSI k9AGM motherboard which has an HDMI port. My sole and topmost requirement is support for a resolution of 1440x900. This b'coz I've got a 19" wide LCD a month ago & my motherboard doesn't support its native resolution due to which I'm working on 1280x1024. I don't like the stretched look and want a cheap motherboard which can solve my problem. Will this motherboard support this resolution?
  2. #2
    Google Bot Pathik's Avatar
    Aug 2005
    Default Re: Buying a motherboard
    You dont need to take a new mobo for that.. just take some decent graphic card..
  3. #3
    TechTin.com ravi_9793's Avatar
    Jun 2005
    www.TechTin.com
    yes..just add a decent graphics card to your system.
  4. #4
    Mar 2006
    Milky way
    This mobo of mine does not even have an AGP slot, so I cannot buy a graphics card. Plz tell me if the chipset will support a resolution of 1440x900
  1. NEED HELP >>>>>Buying new motherboard.?
    By ajay chand in forum CPU / Motherboards
    Last Post: 25-11-2011, 09:10 AM
  2. Help buying Motherboard
    By pearljammer in forum PC Components / Configurations
    Last Post: 31-12-2010, 12:48 AM
  3. Buying a new Motherboard
    By aytus in forum Hardware Q&A
    Last Post: 31-03-2009, 08:56 PM
  4. Buying a Motherboard....
    By GeekyBoy in forum Hardware Q&A
    Last Post: 08-12-2007, 05:44 PM
  5. Need Help in Buying a new Motherboard!!!
    By keith_j_snyder2 in forum Hardware Q&A
    Last Post: 31-12-2006, 11:15 PM
