Go Back   Digit Technology Discussion Forum > Hardware > CPU / Motherboards
CPU / Motherboards News, discussions, queries and problems related to CPUs and motherboards. Section Thread Index
Old 15-02-2005, 08:50 AM   #1 (permalink)
Default performance of IDE Controller on INTEL 915GAV motherboard
I am planning to upgrade my system.
I have a 120gb,40gb and 6gb hard disk,DVD writer and CD writer.
I want to go for the new 915g chipsets.But INTEL 915GAV has only one IDE slot, which connects two devices.
If i put an external IDE Controller card, will the performance be good.
Is there any other good m/b.
sholay is offline
Old 15-02-2005, 08:54 AM   #2 (permalink)
To have a real good throughput i would recommend you to get your self a pcie ide adaptor card that gives you a better throughput due to the enhansed data transfer rate of the pcie bus If you use a normal pci card the bottle neck of the 133MB/s (shared) kicks in and will not allow to use the full available bw. also get a card that provides you with dual ide interface which will help you even further
**** happens
pradeep_chauhan is offline
Old 18-02-2005, 03:47 AM   #3 (permalink)
The external PCI or PCIe card is actually going to give you a better performance in theory , Moreover , there is going to be lesser CPU usage , the same reason why you have to install a SCSI card for a SCSI HDD because the CPU wont be able to handle the speed , either it will decrease the performace of the HDD or the system performance will decrease .
AMD64 2800+ 1GB ECC DDR 400 ,MSI K8T800 Asus Geforce FX 5200 128 MB, 120 GB Barracuda,16X DVD RW,Samsung 16x DVD,Samsung Wireless ,Creative AUDIGY2 ZS 7.1 with Creative Inspire 7.1/1800+AXP 512MB ECC DDR400 .40GB BLACK
indro is offline
Old 18-02-2005, 11:45 AM   #4 (permalink)
The price of the IDE card would be more than the price of the 6 gig HD. Considering you can get 160gigs for around 4500 now. Why even bother? Even a 40gig is small these days.
AlienTech is offline
Old 18-02-2005, 12:54 PM   #5 (permalink)
darklord's Avatar
PCI IDE Raid card with Silicon image chipset with ATA 133 support costs around 1500/-
darklord is offline
Old 18-02-2005, 04:06 PM   #6 (permalink)
Please stay away from the Silicon image card it is a software raid and works only in windows also its cpu utilisation is very hight i bought the card and two 160GB SATA disks and an stuck with the disks (card was returned) Buy a Intel RAID card instead it is a bit expensive but worth every rupee
**** happens
Old 18-02-2005, 09:49 PM   #7 (permalink)
expected market price???
nd is it available in PCI-EX too???
grinning_devil is offline
Old 19-02-2005, 12:40 AM   #8 (permalink)
Yes it is available in the pci-e bus varient. The entry level card has a cpu more powerfull than a P2 with 128 MB SDRAM and four SATA drives supporting RAID 1,2,5,1+0 10 The cost is about 18000/-
**** happens
Old 20-02-2005, 07:15 AM   #9 (permalink)
//The cost is about 18000/-//
Must b real desperate to buy a card that costs as much a terraByte hard disk.
Old 20-02-2005, 10:32 AM   #10 (permalink)
Its not the disk size but the speed at which it can serve data to a fast cpu this card uses the pcie bus to transfer data at about 600MBps(using two scsi 320 interface) so that is what is interesting.
**** happens
- by tv6952
- by soumya
