Go Back   Digit Technology Discussion Forum > Hardware > CPU / Motherboards
CPU / Motherboards News, discussions, queries and problems related to CPUs and motherboards. Section Thread Index
Old 09-02-2005, 05:32 PM   #1 (permalink)
Default Asus Motherboard - 2 Monitors
HI ppl.
i have an asus mobo (A7V8X)...
now in display settings in win xp..it always says that i have two monitors installed....same thing with a friend of mine (A7N8x)...can anybody explain why is it so??
Hitesh Gupta
hitesh_hg is offline
Old 09-02-2005, 09:53 PM   #2 (permalink)
it doesnt say u have 2 monitors installed
it shows 2 monitors
means ur gpu supports tv out / dual monitors
once u connect the ext. display device/second monitor u can use this utility to change which one u wanna display on
which gpu do u have anyways ?
theraven is offline
Old 10-02-2005, 10:25 AM   #3 (permalink)
i still dont get it. anyways i'll post a screen shot of what it displays sometime later...
its a via card ...onboard....
there is no free port to connect ... except one comm port to connect modem and some usb...
Hitesh
There are only 10 type of people in world...
1 who understand binary..
1 who don't
Old 10-02-2005, 09:00 PM   #4 (permalink)
whokay
a screen shot would help
theraven is offline
Old 15-02-2005, 05:31 PM   #5 (permalink)
Ok Guys here is a screen-shot
Hitesh Gupta
1 who don't
Old 15-02-2005, 09:35 PM   #6 (permalink)
hmm
dunno
which drivers are u using ?
the one bundled with your driver cd ?
anyways...its showing the same monitor 2ce
either ways doesnt make a diff .... its not an issue as such ..
try updating ur drivers from the manufacturers website
theraven is offline
Old 16-02-2005, 11:24 AM   #7 (permalink)
well earlier i used the drivers from the cd but recently i started using the latest drivers (from digit cd/dvd)
As it is I don't have any problems but what i wanna know is what the hell is happening on my pc....
Also, as i mentioned earlier same thing happens witha friend of mine, he owns A7N8X (N-vidia chipset) asus mobo
Hitesh Gupta
1 who don't
Old 16-02-2005, 10:30 PM   #8 (permalink)
ah ... do one thing
rollback the drivers to the ones from the cd and see if this shows up again
the thing with new drivers is .. it shows the features of newer versions of cards ( or rather all versions of that specific chipset ) since it isnt oriented to that specific company model/make
therefore it'll show certain things .... which tho disabled for changing ... are still visible
man i hope i didnt confuse u with this ..
basically its the new drivers ...
try a roll back to the old ones .. and see if it makes a diff
if it does .. and u want the above explained .. come back here
theraven is offline
- by kool
- by Jripper
- by kool
