Results 1 to 4 of 4
Thread: Cpu usage ?
  1. #1
    Broken In shreyadr's Avatar
    Mar 2005
    Mumbai
    Question Cpu usage ?
    while working many times my cpu makes a too much noise ( may be the fan) and get slower. that times cpu usage shows 100%. HOW to reduce that usage so that my system will work smoothly without making any noises ?
    SAVE MONEY - SAVE ELECTRICITY
    for details e-mail me at
    shreyadr@gmail.com
    http://majhiduniya.wordpress.com
    http://majhigallery.wordpress.com
    http://majhimarathi.wordpress.com
  2. #2
    Case Mod - 60% ||||||---- spynic's Avatar
    Dec 2006
    Mumbai
    Default Re: Cpu usage ?
    run fewer progs simultaneously...
  3. #3
    Wise Old Owl piyush gupta's Avatar
    Sep 2005
    never land
    Better u check for ur cooling system
    Either u can use another fan or check whats making noise
    1.Fan
    2.hard Disk
    if its Fan Clean ur fan and then see any difference
    if its Hard disk ask ur H/w Vendor
  4. #4
    Broken In aj27july's Avatar
    Feb 2007
    Indiyeah
    uninstall programs that are resource hungry (like patented anti virus and internet security kits).
    This will definitely help.
    The moment you start looking for the truth,
    you are no longer a part of the mob,
    you become an individual.
    ----OSHO
  1. Cpu usage
    By avichandana20000 in forum Hardware Q&A
    Last Post: 18-05-2012, 12:02 PM
  2. Too much HDD Usage?
    By mitraark in forum Hardware Q&A
    Last Post: 16-04-2011, 10:14 PM
  3. 100% CPU Usage
    By midhunmon in forum Hardware Q&A
    Last Post: 07-05-2008, 12:38 PM
  4. cpu usage 100 %%
    By rcd in forum CPU / Motherboards
    Last Post: 11-11-2004, 03:43 PM
  5. CD-RW Usage
    By khandu in forum QnA (read only)
    Last Post: 23-08-2004, 06:10 PM
