Go Back   Digit Technology Discussion Forum > Hardware > CPU / Motherboards
CPU / Motherboards News, discussions, queries and problems related to CPUs and motherboards. Section Thread Index
Old 16-01-2005, 08:12 PM   #1 (permalink)
Default Which is best.--->Intel 915P or Intel 915G
iam bit confused abt this variants
which is the best in terms of GAMING,and upgrading for the future and future proof
also intel has another variant Intel 915 GOM/POM and lots of models in the G variants.
so which is the best in these.................
vps85 is offline
Old 17-01-2005, 12:06 AM   #2 (permalink)
Another Brick in the Wall
drgrudge's Avatar
this is for 915p
Computer motherboards and desktop systems based on the Intel 915P Express chipset and the Intel Pentium 4 Processor with HT Technology deliver ultra-smooth system responsiveness with PCI Express graphics cards, 800 MHz system bus, and dual-channel DDR2 and DDR memory, for bandwidth-intensive applications such as high definition audio and video.
PCI Express buses enable 3.5 times more bandwidth for I/O and graphics cards, as compared to PCI and AGP8X respectively.
To support faster DDR2 and DDR memory, and the PCI Express cards, the Memory Controller Hub (MCH) features wider buses that support dual-channel DDR2 at 533 MHz, for up to 8.5 GB/s of peak memory bandwidth.
To break through I/O bottlenecks a new bus delivers up to 2 GB/s bandwidth between the memory and I/O controllers, compared with 266 MB/s for previous Intel Hub Architecture.
Intel High Definition Audio (Intel HD Audio) features eight independent DMA audio engines that support multiple audio streams with audio codecs. This integrated audio solution rivals the performance of high-end sound cards.
Faster storage performance comes with Intel Matrix Storage Technology in the ICH6R or RW component, which also provides enhanced RAID technology so you can protect data while increasing performance on the same Serial ATA drives.
for more info see
http://www.intel.com/design/chipsets/915P/
intel 915g
Motherboards and desktop computers based on the Intel 915G Express chipset, designed for the Intel Pentium 4 processor supporting Hyper-Threading (HT) Technology in the LGA775 package, deliver a decade's worth of innovation:
PCI Express buses can deliver over 3.5 times more bandwidth for I/O and graphics cards than PCI and AGP8X respectively
Graphics flexibility, with support for both the built-in Intel Graphics Media Accelerator (GMA) 900, which supports widescreen LCD displays and accelerated DirectX 9 3D, plus support for PCI Express graphics cards.
Flexible memory support for both dual channel DDR2 533 memory, which can deliver up to 8.5 GB/s bandwidth, and dual channel DDR memory allows for a range of memory configurations.
For smoother media recording, enjoying the benefits of Intel High Definition Audio, multi-tasking with HT Technology, and dramatically increased performance with Serial ATA drives, the Intel 915G Express chipset brings compelling new capabilities to the desktop PC.
for more info see
http://www.intel.com/design/chipsets/915g/
i would prefer 915g chipset becoz it supports wide screen lcd stuff
and i think both perform equally good in terms of graphics and audio
drgrudge is offline
Old 17-01-2005, 06:37 AM   #3 (permalink)
Oldskool TranceAddict
Both are almost equal in terms of performance when u install a nice PCI-express GFX card eg 6600GT or X700. and certainly both do support DDR2. However only few mobo's have this feature enabled in 915G as to cum in budget. ASUS has one mobo that has support for both DDR and DDR2 alongwith PCI-E architechture and tons of overclocking options with a nice onboard VGA.
But if u r in serious overclocking i wud say go 4 i925X eg ASUS P5AD2 Premium. Keep this in mind "NO SLI HERE " atleast till now. U can wait 4 nForce5
Feel The [poWer] and Unleash The Beast Within.
[poWer] is offline
Old 17-01-2005, 03:52 PM   #4 (permalink)
If you want between 915p and 915g
i will tell you go for the 915g
Stock Intel Mobos are not for overclockers so if you are serious about
overclocking.
Go for ASUS P5GDC-V Delux 915G based Mobo
Features
Intel LGA775 Pentium 4 CPU
Dual Channel DDR & DDR2 max 4GB
Intel GMA 900
PCI-X16 Slot if you wish to later add a PCI-X GPU
Onboard 7.1 Audio - Azalia Sound Chipset
SATA & PATA Both are supported
ASUS AI Proactive Features
AI NOS™ (Non-delay Overclocking System)
AI NET2 network diagnosis before entering OS
Stack Cool™ patented fanless cooling system
Overclocking Features
AI Overclocking (intelligent CPU frequency tuner)
CPU, Memory, and PCIe x16 voltage adjustable
SFS (Stepless Frequency Selection) from 100MHz up to 400MHz at 1MHz increment
Adjustable FSB/DDR ratio. Fixed PCI/PCIe frequencies.
ASUS AI Booster utility
ASUS C.P.R.(CPU Parameter Recall)
Other ASUS Special Features
CrashFree BIOS 2
Q-Fan2
Multi-language BIOS
MyLogo
Well i really liked this 915G from ASUS
Contacts:- 022-56926013
Email:- info_india@asus.com.tw
Web:- www.asus.com.tw
Cost of this mobo approx Rs 12000 might have changed but this was the
cost in November.
Well if you want more performance go for
Intel 925X
Still More Performance
- Intel 925XE - Bus speed 1066 (dont know if this mobo is available in India)
- SLI Mobos allow 2 GPU's for awesome Graphics while playing Latest Games.
The 925 Series will cost you a bomb they are (i think) more than Rs 20K
quad master is offline
Old 20-01-2005, 08:07 PM   #5 (permalink)
Don't 4get Nforce5 ie SLI on Intel processors
Q : What\'s Flash ?
A : The fastest thing in the world.
Q : Who am I ?
A : The Quickest [flAsh]
[flAsh] is offline
Old 20-01-2005, 08:57 PM   #6 (permalink)
Seriously speaking though the AMD platform is much better in gaming than Intel.
www.techenclave.com Ecumenical Technology !:)
blade_runner is offline
- by kool
- by Jripper
- by kool
