| Forum |
| CPU / Motherboards News, discussions, queries and problems related to CPUs and motherboards. Section Thread Index |
#1 (permalink) |
I want to buy a brand new amd configuration with only the following components: AMD 64 cpu Motherboard 1gb ddr 400 ram 1dvd drive Cooling fans What I have in mind: AMD 3200 64 clawhammer(1mb cache),if i can't get that then the newcastle.Anyways,what is the cost of amd 3000 64 and amd 3400 64,their availability and performance difference. I look towards a nforce 3 mobo 250chipset by gigabyte,gigabyte 250gb?Cost?Performance?Is it worth over asus k8v(price?) and other msi and asus mobos of its range? I accept any of the three brands: kingston transcend corsair I want 512mb*2 ddr 400 ram.What is the cost,any other recommendations? 1dvd drive cooling fans for upto 200-500 My budget if upto 30k for all this. i have 128mb radeon 9800pro ati. How much would i get for just this: 1.7ghz willamette 256kb cache 478socket 256mb sd 133 p4 simmtronics memory 32mb tnt2 riva m64 i45mobo: 3sd ram sockets upto 3gb cpu support upto 2.4ghz agp slot no onbaord agp onbaord sound usb 2.0 gameport |
#2 (permalink) |
Posts: n/a
30k is low, an Athlon64 3200+ with newcastle (512 KB L2 ) costs 12k here, with the AUSU K8V for 10k, the gigabyte Nforce3 250GB board is hard to find here but may be easy to find there
I prefer Gigabyte due to their power circutery, while ASUS for their overclocking |
#3 (permalink) | |
MSI & Asus boards based on Nforce3 250Gb are better options. MSI K8N Neo FSR - 7500/- MSI K8N Neo Platinum - 10,000/- Asus K8N-E-Deluxe - 9500/- |
#4 (permalink) |
is it an nforce 3 250 chipset? Does it perform better than asus k8v and equal to gigabyte 250 GB nfroce 3 ? How is 30k low? 12k for cpu 9k for ram 7k for mobo =28k fans for 200 dvd drive for 1.5k maybe 31k,does that make a difference? how much would i get for old parts?
Core i7 2600k|Gigabyte P67A UD4 B3|Corsair XMS3 2x4GB|HD6970|Coolermaster SilentPro 850M|Coolermaster HAF 932|Audioengine AE5|Samsung Galaxy S|Samsung Galaxy Tab 3G|Blackberry Curve 8520 |
#5 (permalink) |
Posts: n/a
Prices are higher here for AMD, cos AMD doesn't selles much here, so they are changed at your place, no problem in that
Nforce3 chipset other then 250GB are not prefered, also going for K8V is not prefered as it is Socket 754, go for Socket 939, U will be able to use it in the future too |
#6 (permalink) |
what is the cost of 939 mobos and cpus?
#10 (permalink) |
cost of 939cpu
#12 (permalink) | |
Keep asking akshayt till these guys get pissed !
www.techenclave.com Ecumenical Technology ! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
