Go Back   Digit Technology Discussion Forum > Hardware > CPU / Motherboards
CPU / Motherboards News, discussions, queries and problems related to CPUs and motherboards. Section Thread Index
Old 12-10-2005, 12:57 PM   #1 (permalink)
Default BEST MOTHERBOARD FOR AMD WITH ONBOARD GRAPHIC CARD
HI ! I want to buy a mobo for 939 pin amd pro of 4.5-5k.I want to play games like doom3,hl2,etc.I am looking 4 a mobo with onboard graphic solutions which can play all above games . I know it can b possible only at low settings,can u tell me low settings in what sense?
EVERYBODY WANTS TO GO TO HEAVEN BUT NOBODY WANTS TO DIE
mandar5 is offline
Old 12-10-2005, 01:01 PM   #2 (permalink)
MSI-RS-480 is d only board avlbl in india which has onboard gfx.. Its in d pricerange u mentioned.. By low settings, it means that u'll b able to play @ 800*600 resolution wid low/medium effects..!
delhibhai1000 is offline
Old 12-10-2005, 03:43 PM   #3 (permalink)
Learner
Kniwor's Avatar
No arguments, MSI RS480, great borad.
Kniwor is offline
Old 12-10-2005, 03:44 PM   #4 (permalink)
The Hardware Labs
mohit's Avatar
u may also try the latest ASUS A8N-VM CSM having the integrated nvidia 6 series vga onboard , see the specs here ,
http://www.asus.com/products4.aspx?m...3&l2=15&l3=210
mohit is offline
Old 12-10-2005, 10:53 PM   #5 (permalink)
ATI RADEON EXPRESS 200G (A58K9-MLF)
This ATI mobo has a onboard chipset based on X300 series.But costs somethig close to 6K.There is nothing better than this , I bet.
venkat1605 is offline
Old 15-10-2005, 10:46 AM   #6 (permalink)
Hey any one tell the conclusion, Which of this three is the best???????????????????????????????
navino87 is offline
Old 15-10-2005, 01:26 PM   #7 (permalink)
Laptoping
Sourabh's Avatar
MSI RS480 is the only viable option, I dont think boards from Asus or any other manufacturer based on nvidia 6100/6150 are out yet in the market. Also with the boards built by ATI availability would be an issue. So MSI RS480M2 is the mainboard to get if you want descent onboard graphics.
Sourabh is offline
Old 15-10-2005, 03:32 PM   #8 (permalink)
Learner
Kniwor's Avatar
Well all other boards suggested there, are they available in india market, what is their price, I'm sure they wont beat RS480 as far as the price/performance ratio is concerned.
Kniwor is offline
Old 16-10-2005, 03:20 AM   #9 (permalink)
I would like to see what the hardware testing groups say about these as well. Considering the ATI is only a few % slower than the best Nvidia boards, if they did anything to cut corners it will fall far behind in performance. Even though the ATI uses an entry level GFX chipset still cut down again to 2 pipelines from 6, it still takes a lo of silicon. Although performance wise the ATI chipset without GFX is not any faster and lame compared to NVidia.
AlienTech is offline
- by kool
- by Jripper
- by kool
