Results 1 to 15 of 15
19-08-2012, 02:21 AM #1Right Off the Assembly Line
- Join Date
- Aug 2012
- Posts
- 8
AMD FX-8120 with HD6670 and LG 3D Monitor. Mulitple issues.
Hi,
This my first post on this forum.
I recently got this new build for my bro.
AMD FX-8120 BE (8-core @3.10ghz)
Sapphire RADEON HD6670 1Gb DDR5
Gigabyte GA-990FXA-UD3
Corsair 1333Mhz 4Gbx2 RAM
WD Green 6Gb/s 1 TB
Coolermaster Extreme Power Plus 600W
LG 23" 3D Monitor
Logitech K/B mouse combo.
All with latest driver/software updates. Haven't installed security yet.
We have these issues:
1. We are unable to overclock it. In AMD Catalyst Control Centre, CPU overdrive is grayed out even though it's an unlocked Black Edition. We only want to use
an auto-tune utility that will configure CPU, Graphics and Memory automatically, as we do not want to risk any damage. Gigabyte BIOS is complex. (990FX chipset ASUS mobo was not available in the market.)
2. I know that AMD cannot be compared to Intel but with such a system and after watching online video reviews of the AMD "Scorpius" platform, I did expect
an excellent gaming performance with an old game like Crysis 2 (Directx 11-High Res-Ultra settings-1080p) but even at lower settings(DX11-Extreme Settings-720p) there is an unacceptable lag.
3. Using HDMI we are able to watch excellent 3D movies, however when we stop viewing 3D content the monitors brightness/contrast is ruined and there is jagged edges to icons and Clear Type Text is lost. This lasts until we reboot the pc and change the monitor settings to Factory Defaults several times.
Please help.
19-08-2012, 04:15 AM #2
6670 can't run Crysis at extreme. Try at mid or high. Also switch to DX9
19-08-2012, 07:41 AM #3
Re: AMD FX-8120 with HD6670 and LG 3D Monitor. Mulitple issues.
1. You can't overclock the processor from the OS environment. Processor settings are to be edited in the BIOS for overclocking.
2. Your GPU is an entry level one and crysis 2 is one of those gpu hungry games. If you are interested in gaming then sell 6670 and get a mid range card like HD 7750 atleast. It'll let you max out all games at 720p.
3. Don't know about this one.The Dark Knight :
19-08-2012, 08:33 AM #4
The best way to overclock CPU is from BIOS. Although you can use a great tool, AMD Overdrive to overclock CPU, memory or set the timing of gthe memory modules, BIOS is the most stable option.
Since you're having a Black Edition CPU, i.e. the CPU multiplier is unlocked, you can very easily overclock the CPU.
1. Go to the Motherboard BIOS and find out the Turbo Core setting. Disable it. If possible, disable the power saving features like AMD Cool 'n Quiet
2. Start increasing the CPU multiplier by 0.5 and reboot to Window to test the stability. You can overclock it to around 3.5 to 3.6 GHz without increasing the CPU voltage.AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
19-08-2012, 11:37 PM #5
IMHO, you should consider changing the PSU before trying to overclock 8120.
Inactive in TDF.
20-08-2012, 12:03 PM #6
Overclocking is best done via BIOS. You don't need to overclock this processor anyways.
Video card is the one to be blamed here. Not the processor. Crysis 2 Extreme uses excessive tesselation (unnecessarily) to hurt performance. Run at 720p and High. Tesselation should be low.
Meanwhile do give a shot to Battlefield 3 @ 720p. Except Crysis 2 (unnecessary tesselation @ extreme), I expect all other games to run fine @ 720p on HD 6670.
Overall, HD 6670 is a slow card. I hope you have purchased the GDDR5 version of HD 6670, not the DDR3 one.
Install Catalyst 12.8 Final. It should be fixed in it.
This is an issue of scaling/underscan. After you move out of 3D, the text looks jagged because the screen size on HDTV decreases due to black borders. You can use the following slider to settle it.
If Catalyst 12.8 doesn't work, then try the fix I posted here - http://www.thinkdigit.com/forum/grap...ml#post1697725 (post #25)
Lastly, do change your PSU. You've bought a very bad one. Otherwise don't bother with overclocking.AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn)
| 2 * 4 GB Corsair 1600 Mhz Value RAM | Corsair CX430v2 | NZXT Gamma | Dell S2240L 22" @ 1080p
Intel i5-2500K | Asus P8Z68 Deluxe | 2 * 4 GB Corsair Vengeance | WD Caviar Blue 500 GB | CM Hyper 212 Evo | AMD Radeon HD 6950 2 GB | NZXT Tempest Evo | Corsair AX850 | AverMedia AverTV Capture HD H727
Samsung Galaxy S2 | Mac mini (Late 2009) with OS X Mountain Lion, 10.8
Pandaboard ES | OMAP 4460 SoC | 2 * ARM Cortex A9 cores | PowerVR SGX540 graphics
Arch Linux amd64 | Ubuntu 12.04 amd64 + omap4 ARM | Windows 7 x64
20-08-2012, 12:39 PM #7Alpha Geek
- Join Date
- Sep 2011
- Location
- Baguiati,Kolkata,West Bengal,INDIA
- Posts
- 587
@OP-Listen to the suggestions what all have said.Particularly @d6bmg and @ico,including everyone.
Your First and Foremost duty/action/function/choice is to change the "PSU",which is quite "crappy" and leads to "serious issues",those of who had used it.
Go for PSU's from:---> Corsair,Gigabyte,Seasonic,Antech with at least 500W configuration.
You need to change your GPU(HD 6670) also,which is quite useful for HTPC or casual games,not for serious hardcore gaming.
21-08-2012, 04:52 AM #8
^^ Gigabyte PSUs are not so good - Op should get Corsair GS600 at-least.
Who Dares Wins
Avenging Angel !
Phenom II 955BE↔Asus M5a97 R2.0↔Corsair 2x 4GB RAM↔HD6850↔Corsair GS600↔CM Hyper 212↔CM 430 Elite
My Blog : http://topgeartopspeed.wordpress.com/
BlackListed : Viewsonic, Gigabyte
22-08-2012, 02:47 PM #9In The Zone
- Join Date
- Feb 2012
- Location
- New Delhi
- Posts
- 371
yup agree that the hd 6670 is meant for casual gaming
for hardcore gaming anything below a hd 7850 is not desirableSpoiler:
22-08-2012, 03:06 PM #10Right Off the Assembly Line
- Join Date
- Aug 2012
- Posts
- 8
Thank you all for your replies.
First of all:
Im able to play Crysis 2 without any issue with DX11-High Res-Extreme-1080P settings on my system. I have played several other games @Very High-Dx11 settings with relative ease including Crysis 1(Dx9), Max Payne 3, Batman Arkham Asylum etc.
I use Intel Core i5 2400 Quad @3.1Ghz
Asus P8H61-M-LX(Rev. B3)
Sapphire Radeon HD6670 1Gb DDR5
Seagate 500Gb HDD SATA2.0
Coolermaster Extreme Power Plus 500W
Corsair 4Ggx2 DDR3
So:
I don't get the HD6670 bashing. It's my hands-on experience.
Second:
Yes, we did resolve the scaling issue with the AMD update before return to the forum.
Third:
We did overclock the AMD FX-8120 CPU using the BIOS from 3.1 to 3.8Ghz with stock cooler and the same Coolermaster 600W. Im impressed.
Dont want to go beyond even if possible. Still didnt solve the game performance issue.
Returned the card for a Radeon HD7770 and now the lag issue is resolved. So the conculsion is that the AMD Scorpius platform gving an "......ultimate gaming experience" is just theoritical not practical. Now Im able to play Crysis 2 and Dirt 3 at max graphics settings.Last edited by maxrockpro; 22-08-2012 at 06:19 PM.
22-08-2012, 08:19 PM #11
ok.
Just make sure that exreme power plus 600 don't get fried.Inactive in TDF.
23-08-2012, 03:10 AM #12
either you're absolutely wrong or just kidding or your definition of playable FPS is something else
Crysis 2 in DX11 mode with High Res Texture Pack at 1920*1080 resolution is playable on HD6670 with Extreme settings - simply not possible - even a HD6850 struggles to keep avg. frame rate near ~30
check here :
Crysis 2 DX11 VGA and CPU performance benchmarks
and if you are saying the cpu is making all the difference then check this out :
Who Dares Wins
Avenging Angel !
23-08-2012, 06:04 AM #13
^I think he used 7770 for gaming.
The Dark Knight :
23-08-2012, 12:56 PM #14Right Off the Assembly Line
- Join Date
- Aug 2012
- Posts
- 8
Nope, I still use HD6670 for my intel system. I dont count the FPS, but I know what smooth gameplay means. I am a Blu-Ray video fanatic, any video or graphic lag/stutter/pixelation is just unacceptable to me. Hence, I've deleted all my old games that like Maxy Payne 1, Wolfenstein 3D and many other favourite games due to their graphics quality. I've also dumped my old DVD video collection of over hundred movies.
Also, benchmarking software and real world applications are two different things. I dont have my own web site, so: check
As far as overclocking AMD with Coolermaster is concerned. I'll run a stress test and see whether I need to take it back down to 3.1Ghz.
Peace
P.S: Does anyone know how a thread is closed as [Solved]?
24-08-2012, 03:15 AM #15
^^ Look at this ( from the link you mentioned above ) :
12 and 17 FPs ain't very playable and you said Crysis 2 ran with extreme settings with High Res Texture pack at HD resolution - well the truth is :
Only if you run Crysis Warhead at mainstream and Crysis 2 on High settings they will be playable on HD6670 - maxing out each and every gfx settings for games like Crysis on HD6670 is simply beyond it's scope.
PM any mod if you need to Re-Open this thread.Who Dares Wins
Avenging Angel !
LinkBack URL
About LinkBacks
