| Forum |
| CPU / Motherboards News, discussions, queries and problems related to CPUs and motherboards. Section Thread Index |
#1 (permalink) |
But strangely just after the pci slots were there must be an AGP slot there is a series of silver dots in a rectangular shape and on the PCB is written AGP now please tell me where is the AGP slot |
#2 (permalink) |
are u sure u checked the right model number ? and that u have the very same ??
cuz it seems this mobo model doesnt have an agp slot check the mobo box and manual .. also recheck the model no. cuz if after the white pci u dun have a brown agp then sorry to say u dont have an agp slot
No Mercy, No Limits. Oobertech.net - Keeping Knowledge Free |
#3 (permalink) | |
check this out Raven http://vesta-im.com/display.asp?pid=97&pt=mb&mbt= i have the same motherboard with not a single difference except that slot in place of that slot are the dots which i mentioned earlier |
#4 (permalink) |
i still say check ur box and manual ..
cuz if u cant find the slot .. its just not there and in that case the model must be different i also went thru all the models there all i can say is that u either got ripped off or are completely confused between companies and models cuz there has to be an agp port if its ANY of those motherboards and afaik ALL 845's come with an agp slot ... sorry buddy
#7 (permalink) |
since my comp is 2 yrs old and unfortunately i have lost the manual but on the PCB its clearly written VESTA and the bios shows the 845gl version,is there any other way out since i am planning a system upgrade.
My friend just told me that the connections are there but the slot isn't can this possible |
#9 (permalink) |
Laptoping
Is it an assembled system or a branded one? If its a Branded one it can very well be possible that there wont be a AGP slot by default on the motherboard. It seems obvious that the chipset used is 845GL which has AGP Card Support but the manufacturer hasnt provided a slot mebbe to keep it in a Micro-ATX formfactor or due to mass orders for a particular Branded PC supplier.
Getting another board is the only option, you can get them pretty cheap these days for around 2k.
You could think I'm wrong, but that's no reason to stop thinking. |
#10 (permalink) | |
Keith
[ THIS SPACE HAS BEEN RESERVED FOR FUTURE USE IN CASE I WANT TO BOAST ABOUT MY PC'S, HOUSE, CAR, GIRLFRIENDS OR OTHER STUFF THAT I KNOW YOU DON'T REALLY CARE ABOUT ] |
#11 (permalink) | |
Many companies will make Boards that can work differently and in a variety of ways, Its only very recently that you do not find very many boards for multi purpose uses.. IE making is board is very expensive, designing it and manufacturing it is very complex. The best example of this is TV tuner boards which can have many functions on them like stereo, amplifier, NTSC/PAL/SECAM modes, video capture, hardware compression etc etc etc.. All they do for the different boards is add chips for the different functions or not have them for the cheaper ones. Even if the board looks identical as the TV tuner card with hard ware compression and live video capture, I am sure no matter how much you try, the cheapo plain vanilla card will not be able to get those functions to work on it. It always used to make me think that why they would go to so much extra work when some of the missing parts would cost them maybe rs5 total. So to even save money they would have to sell a lot of boards, those designers and engineers doing this dont work cheap.. But they try to save paisas here.. 1 paisa is 1 paisa... Some of these shops work on many million pieces and thats a million paisa... This is mostly a Chinese invention though. Cause you wont find such things on a US made board. But on the chinese ones you wont find 1 single extra unusable or unused component on there. SOMETIMES, you can add the "slot" or what ever yourself but I am sure other parts are missing... They would not leave the resistor and capacitors and other things used to hook it up there. In some cases they get an order for a specific spec and they will change things fast and do it. Some times it means reducing functionality. I think it was DELL that ordered many million pieces of 20Gig HD's from maxtor... But since maxtor did not make 20GB HD's they just had a boot block which changed their 40Gig HD to appear as 20Gig's... You could reformat the HD and get 40 gig's.. It was chaper for Maxtor to just add the 20GB boot block to their 40GB hd than making a 20GB from scratch. Maybe the chinese would have done it differently... But maxtor is korean owned now I think... |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
