Results 1 to 10 of 10
10-06-2012, 10:31 AM #1Right Off the Assembly Line
- Join Date
- Jun 2012
- Location
- Hyderabad
- Posts
- 43
Better processor among these i5 3570 or fx 8150 or i5 2500k ?
According to cpubenchmark
PassMark Intel vs AMD CPU Benchmarks - High End
fx 8150 has high rank..But some reviews says i5 3570 is better than fx 8150.How could 4 cores is better than 8 cores processor ?
[Solved] I5-3450 VS FX-8150 - CPUs - CPU-Components
I'm bit confuse with the l2 and l3 cache.Isn't more cache makes data move faster? So It makes AMD processors run more faster than intel. Right?
And also i5 3550 and i5 3570 have heating issues when compared to i5 2500k
And the performance difference between these is just 5%(Don't include IGP,coz these days everyone having GPU's)
Consider this for whole performance not only for gaming..
10-06-2012, 03:28 PM #2
Re: Better processor among these i5 3570 or fx 8150 or i5 2500k ?
For gaming, 2500K
For apps 8150.
10-06-2012, 03:48 PM #3
fx8150 has poor performance due to slow single thread performance as compared to 2500k. But surely the fx has better benchmark due to the reasons you listed. Therefore, +1 to d6bmg.
PC+ Lumia 720 + iPod Touch 32GB + PSPSpoiler:
11-06-2012, 06:09 AM #4
only consider getting FX8150 if the apps you use will be highly threaded - overall 2500k is jack of all trade and master of many if not everything
Who Dares Wins
Avenging Angel !
Phenom II 955BE↔Asus M5a97 R2.0↔Corsair 2x 4GB RAM↔HD6850↔Corsair GS600↔CM Hyper 212↔CM 430 Elite
My Blog : http://topgeartopspeed.wordpress.com/
BlackListed : Viewsonic, Gigabyte
11-06-2012, 07:27 AM #5Right Off the Assembly Line
- Join Date
- Jun 2012
- Location
- Hyderabad
- Posts
- 43
11-06-2012, 09:17 AM #6
^^ Depends upon your usage. For gaming and high overclocking, 2500K is the better choice over i5 3570K.
All the Ivy Bridge Processors have heating issues when overclocked and overclocking them is also not as easy as the Sandybridge processors.
Get 3570K + Z77 Motherboard if you are not going to overclock much (the stock performance of 3570K is slightly better), want a lots of features like PCI-E 3.0 etc, good Onboard Graphics (HD 4000) etc.
But still I think i5 2500K is the better choice.AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
11-06-2012, 09:20 AM #7Wise Old Owl
- Join Date
- Aug 2007
- Location
- Chinchwad Pune
- Posts
- 1,440
All 3rd Gen i Core i.e 3xxx series are overpriced and not worth the premium they demand.
Buy 2nd Gen onlyPhenom II 955 BE | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Kingston v300 SSD 240 GB | Seagate : 1 TB | NZXT Phantom 410 | Sony Experia Neo V
11-06-2012, 11:57 AM #8Right Off the Assembly Line
- Join Date
- Jun 2012
- Location
- Hyderabad
- Posts
- 43
12-06-2012, 02:57 AM #9
IB cpus are not that bad actually but to get the max efficiency and balance between heat and power consumption you need to play with volt and OC - here's two articles for you
Core i5-3570K, -3550, -3550S, And -3570T: Ivy Bridge Efficiency : Four Ivy Bridge-Based Core i5 CPUs, Compared
AnandTech - Undervolting and Overclocking on Ivy BridgeWho Dares Wins
Avenging Angel !
12-06-2012, 02:01 PM #10
Sandy Bridge will offer enough juice for you for some years. If you aren't a hardcore performance oriented user who deals with lot of things at same time, then Core i5 2500K will serve you well. Just my own opinion, though experts will say different.
I tried auto verclocking my CPU to 4.3 GHZ via Asus Auto Tuning and I immediately saw the difference in everything !. It's your choice whether you'll like more value ( Core i5 2500k ) or future proof ( Core i5 3570k ) for some more years than SB.
Fx 8150 vs i5 building new CPU
By Hariman in forum PC Components / ConfigurationsReplies: 12Last Post: 27-07-2012, 03:27 AM -
I5 2500k @ 5.6 ghz ???
By Sainatarajan in forum OverclockingReplies: 6Last Post: 21-06-2012, 11:33 PM -
FX 8150 overclocking on air
By sumonpathak in forum ReviewsReplies: 15Last Post: 26-03-2012, 05:06 PM -
Huawei Ideos U 8150 is this a good buy
By diagus in forum Buying AdviceReplies: 2Last Post: 11-02-2012, 04:57 PM -
Epic CPU battles of history: Athlon FX-55, Pentium 4 EE, FX-8150 si Core i7 3960X
By Jaskanwar Singh in forum CPU / MotherboardsReplies: 9Last Post: 06-01-2012, 02:58 PM
LinkBack URL
About LinkBacks
