Go Back   Digit Technology Discussion Forum > Hardware > CPU / Motherboards
CPU / Motherboards News, discussions, queries and problems related to CPUs and motherboards. Section Thread Index
Old 21-09-2005, 04:50 PM   #1 (permalink)
Default Intel based Comp
My cousin sister want ONLY an INTEL based comp. The comp will mostly be used for net, MS office and songs and movies at most. no games. so pls suggest the config. budget: 25K
PS: i tried to force her to go for AMD, but she wouldnt.
shwetanshu is offline
Old 21-09-2005, 05:38 PM   #2 (permalink)
Aniruddh's Avatar
Intel Config:-
1.Intel64 P4 2.66 LGA775-5k
2.Intel Original 915GAV-4.5k
3.256MB DDR 400MHz ram-1.3k
4.Samsung 17''monitor-5.5k
5.Sony Combo Drive-2.3k
6.Microsoft kb & optical mouse-1k
7.Altec Lansing AVS300(2.1)/creative SBS 370(2.1)-1.3k
8.Seagate sata/baracuda 80GB-2.9/2.6k
9.Numeric 600VA ups-2k
cabinet of ur choice-1k
All this will come around 25k.if u can then add 256 DDR ram more,256mb is i guess enough for ur kinda work but still if u want.
Aniruddh is offline
Old 21-09-2005, 06:48 PM   #3 (permalink)
gxsaurav
Posts: n/a
Hmm, I will refine the list given above by Aniruddh
2X256 MB DDR400 RAM, for dual channel, Intel loves it.
Celeron D is also good but if she is goint to encode movies, Pentium 4 is better, ask her that, if she is not going for movies encoding or DVD ripping, then Get a Celeron D 2.8 GHz.
915GAV is good enough for her, although if found cheap go for Asus P5GL-MX
Syncmaster 793MB Monitor,
Logitech Internet pro desktop, Wireless
Lite-On combo drive SOHC-5236K, what's the use of this movie system without a DVD drive
Creative inspire T3000 speakers, or if affordable then go for iTrigue 3200
Samsung 120 GB SATA HD, with 8 MB buffer, 7200 rpm
APC 500VA UPS, will enough for this system
Frontech cabinet as they give a lot of fan installation options, install a rear exhaust & one side exhaust fan.
Colorsit M300U Power supply or equivelent, don't go for low quality brands for PSU
