| Forum |
| CPU / Motherboards News, discussions, queries and problems related to CPUs and motherboards. Section Thread Index |
#1 (permalink) |
I have recently Buyied AMD sempron 2500+ 64 bit based computer, I checked on inline vendors they say tht this processor has 1600 MHz FSB See this link for Confirmation http://www.tigerdirect.com/applicati...?EdpNo=1530708 But in BIOS it shows only 200MHz, Can Anyone tell me that it is really 1600Mhz.... Also what is the safest level it can be overclocked I have Gigabyte Motherboard K8MV800 See this link.... http://valid.x86-secret.com/show_oc.php?id=38735 -- Anurag |
#2 (permalink) | |
do u have an E6 rev processor as in the cpu-z screenshot? if yes then its very much overclockable...however u need to be more concerned about how far ur mobo/RAM will hold out. Anyways ur fsb at stock is 200 Mhz, while ur cpu speed is 200*7 = 1400Mhz...that is incase ur sempron is a palermo core! |
#4 (permalink) |
listen fsb=front side bus is a motherboard thing, and is 200MHz at stock for all Athlon64s
therefore FSB is NOT the same as CPU freq! the frequency at which ur cpu is running can be calculated by fsbclock*cpu multiplier in ur case 200*7=1400mhz (not 1600MHz!) if its still not clear, just post a screenshot of cpuz first page, so that we can see
A64 3200 winnie + 512*2 KVR 2.5-3-3-6 2T + MSI K8N SLI platinum - Creative SB Live! 7.1 + Leadtek PX6600GT 550/1125 + 160 GB Seagate N.C.Q. + 320 GB WD + LG 17" CRT 3Dmark05 - 4008 3Dmark03 - 8,983 |
#5 (permalink) |
Nope, I know that it is running at 200Mhz FSB, But The online vendors like tigerdirect.com (See link to tht in my first post) are saying that this Processor is having a 1600MHZ FSB...
I want to know tht it is really so, For me CPU-Z shows a 200MHz FSB only. |
#8 (permalink) |
Learner
Everybody is confused here,
Firstly let me tell u that everything is right in ur cpu. ur processor clock speed is 1400Mhz, which is right, 1600 is ur Hypertransport speed, which they refer to as fsb, 200Mhz is ur bus speed from memory to processor, the memory runs at 200 Mhz. Download everest here http://www.lavalys.hu/products/downl...?pid=1&lang=en and see the hypertransport speed. It will ne 1600Mhz. |
#10 (permalink) | |
for confusing ppl i guess !wat he means is Ht speed= 800 Mhz *2 =1600Mhz (its like saying 200Mhz DDR ram as 400 Mhz dont worry...ur mobo has 1000Mhz HTT corresponding to 2000Mhz as indicated by the site..
#11 (permalink) | |
Learner
Same is the case with ur system, with 1000Mhz hypertransport, 2000Mhz is the net efective speed. recall why we call it DDR 400, when the bus speed is 200Mhz. |
#12 (permalink) |
The Sempron 2500+ is a Socket 754 CPU,how in the world can it have DUAL Channel RAM Support ?
No S754 CPU till date has Dual CHannel support. Also the 2500+,even though based on E6 core and being extremely well overclocker,isnt much of fun as the Multiplier as well as the Vcore is locked. |
#13 (permalink) |
Yeah,
Got it, Kniwor is right.... The Hypertransport speed is 1600MHz, And the actual frequency at which the Processor communicates with memory is 200MHz... Is it comparable to what we have on Pentium 4's the 800Mhz FSB ? |
#14 (permalink) | |
Learner
IT'S DUAL CHANNEL HYPERTRANSPORT, and hypertransport is not the bus used to transfer data from ram. |
#15 (permalink) |
Darklord means that its "Full Duplex"
AMD64 2800+ 1GB ECC DDR 400 ,MSI K8T800 Asus Geforce FX 5200 128 MB, 120 GB Barracuda,16X DVD RW,Samsung 16x DVD,Samsung Wireless ,Creative AUDIGY2 ZS 7.1 with Creative Inspire 7.1/1800+AXP 512MB ECC DDR400 .40GB BLACK |
#16 (permalink) | ||
#17 (permalink) |
I think they mean FULL Duplex, not dual channel !! Right Darky ?
#18 (permalink) |
Well you can choose between 8bit or 16 bit upstream and downstream communication between the chipset and the CPU.
Is this what you are calling dual channel ? 16 bit upstream and downstream both way ? |
#20 (permalink) | |
Learner
they calculate it in terms of total data transfer rates, and hence it doubles. simple. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
