Go Back   Digit Technology Discussion Forum > Hardware > CPU / Motherboards
CPU / Motherboards News, discussions, queries and problems related to CPUs and motherboards. Section Thread Index
Old 08-02-2012, 09:09 PM   #31 (permalink)
Adam young
sukesh1090's Avatar
Default Re: Anyone with 880gm-usb3 using 1600 mhz DDR3
but here i am not getting intex 1Kva ups.i asked one shop and he told he doesn't have it.sometimes i feel like i am living in the hell.here i can't get anything i want.
:razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
sukesh1090 is offline   Reply With Quote
Old 08-02-2012, 10:55 PM   #32 (permalink)
at Binary World, Indiranagar, Bangalore 850VA is available for 1984 & 1kva for 2785.
Buy Computers Laptops @ Lowest Price, Intex 2 @ http://bwindia.net
Is God willing to prevent evil, but not able? Then he is not omnipotent.
Is he able, but not willing? Then he is malevolent.
Is he both able and willing? Then whence cometh evil? Is he neither able nor willing? Then why call him God?
whitestar_999 is offline   Reply With Quote
Old 08-02-2012, 11:16 PM   #33 (permalink)
Adam young
sukesh1090's Avatar
but the problem is the ups will be as heavy as elephant so it will cost me a bomb for courier.btw are you staying in Karnataka?
-Rifleman's Creed
Old 08-02-2012, 11:39 PM   #34 (permalink)
BMG ftw!!
d6bmg's Avatar
Buy it online.
ITDepot have APC/Intex 1KVA
d6bmg is online now   Reply With Quote
Old 08-02-2012, 11:59 PM   #35 (permalink)
Adam young
sukesh1090's Avatar
oops it will cost me a lot for courier and even itdepot doesn't have intex 1 kva.
-Rifleman's Creed
Old 09-02-2012, 12:09 AM   #36 (permalink)
i am in NCR.i gave you binaryworld link because it is in karnataka too & i thought maybe you can ask someone or a dealer(for some extra 200-300) to get it from there.
Old 09-02-2012, 12:15 AM   #37 (permalink)
Adam young
sukesh1090's Avatar
will check it and will ask some more dealers here.btw thanks for the help guys.
-Rifleman's Creed
Old 09-02-2012, 03:46 AM   #38 (permalink)
Fast 'N' Furious
topgear's Avatar
Originally Posted by sukesh1090 View Post
k used xtreme psu calculator,
-without oc option with capacitor aging as 10% and got minimum psu wattage 264w and recommended psu wattage as 314w.
-with overclocking to 4200Mhz with 1.5vcore got minimum wattage as 319w and recommended as 369w.
-with current settings 3200MHz at 1.275 vcore got minimum wattage as 244w and recommended as 294w.
-with overclocked to 4200MHz with 1.45vcore and 0% capacitor aging getting minimum wattage as 290w and recommended is 340w.
so if i am right then the minimum wattage are what would be the actual power consumption.then at overclocked to 4200Mhz the system consumes 300w with 5% capacitor aging(which is highly not possible as it is brand new psu) and as i rad in reviews at this load my psu has around 85-88% efficiency.so with 85% efficiency the total consumption comes around 350w and add 25w for monitor so total is 375w.if it is true that 600va provides 360w then it is overload if it is more than 360w then it should withstand this.i have disconnected the speaker from it as one shop keeper told me that woofer eats up a lot of power will check it with running prime95 or any games and disconnecting psu from main socket so as to check if it can hold or not.
I don't think that xtreme psu calculator is correct in calculating power usage of a OCed Phenom II cpu - look at any review site - at 4 Ghz PII 955BE consumes ~375-400W ( with cpu load only using prime 95 ) and reviewers most of the time use good and new PSU - as I said beofre games can't consume cpu like prime95 but when you play games gpu consumes power and I've wrote sad1fJ|bout this on previous post.
To give you a better idea look at the image below
ToPsPeEeD = FaSt BuT StEaDy
Old 09-02-2012, 06:46 PM   #39 (permalink)
Adam young
sukesh1090's Avatar
brother how can there be a that much increase in power consumption when he has overclocked it only to 3.77GHz the increased power consumption is almost equal to consumption of another 955.looks like something is wrong in that.that 3.77GHz speed my processor reaches at around 1.3v that is undervolted from normal vcore.
-Rifleman's Creed
Old 10-02-2012, 05:36 AM   #40 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ probably that's a C2 rev Phenom II cpu but when OCed phenom II cpus consumes a lot more power - a rig with 1.5v vcore Oced phenom II 955BE C3 rev cpu consumes as much as 400W or for eg. Phenom II 980BE runs at 3.7 Ghz but when OCed to 4.3 Ghz it consumes
so the load power consumption is increases with OC- this makes it clear I think
Old 10-02-2012, 01:11 PM   #41 (permalink)
Adam young
sukesh1090's Avatar
then i will stick with my stock clock for time being.thank you bro.
-Rifleman's Creed
Old 11-02-2012, 03:35 AM   #42 (permalink)
Fast 'N' Furious
topgear's Avatar
at summer time even I'll run my cpu at stock or a little bit lower speed and set very little vcore to manage the increased heat and keep my rig coool
Tom's HW has a great guide about under volting phenom II cpu .. check this out
Undervolting Your Phenom II And Core 2 Processors : Efficiency For Free: Core 2 Quad And Phenom II X4 At Reduced Voltage
- by kool
- by Jripper
- by kool
