Results 1 to 15 of 15
  1. #1
    Dec 2011
    Default URGENT--CPU+Mobo under 8k
    Hello all,
    I need to buy new CPU+MoBo. I'll be using it for the gaming, image editing, watching 720p videos and MS Office 2010 mostly. I do NOT plan to use it for HTPC or similar things or overclock it or upgrade it except for adding a RAM module. I will be using win 7 x86.
    I have rest of the components that includes an XFX Radeon 4670 1gb DDR3 graphics card and a 500w Zebronics SMPS
    My budget for CPU +MoBO is strictly 8000 bucks. From what I hear intel won't do me any good in this budget because of lack of multi cores. But I may have been misinformed. So, obviously I turn towards AMD. I do NOT want ASUS MoBO. I have too many bad experiences with the damn Rashi Peripherals, especially in Kolkata.
    If I use DDR 3 1600, will it be a bottleneck for the MoBo with FSB of 1333 MHz?
    BTW Will Amd LLano processors do any good as I have a 4670?
    Any good place in Kolkata to buy.. Is it a good idea to order from costtocost or Computer Empire, Delhi?
    Open to all suggestions.
    Thank you all in advance.
  2. #2
    Nov 2011
    NCR
    Default Re: URGENT--CPU+Mobo under 8k
    source:smcinternational.in
    total:7460
    note:make sure to get v3.1 as there is also v4.0 of the same model with same price but it has inferior 3+1 VRM instead of 4+1 VRM on v3.1.because of this v3.1 can fully support even 6 core processors & 125W phenom II quad cores & thus is much better option in terms of future proofing.
    specifications
    GIGABYTE - Motherboard - Socket AM3+ - GA-78LMT-S2P (rev. 3.1)
    2 x 1.5V DDR3 DIMM sockets supporting up to 8 GB of system memory
    Support for DDR3 1333+ (O.C.)
    whether DDR3 1600 is justified for this setup i can't say as i never owned an AMD system.
  3. #3
    Fast 'N' Furious topgear's Avatar
    Jul 2006
    Geek's Heaven
    GIGABYTE GA-78LMT-S2P v3.1 is easily available on most of the local shops @ 2.6k but if OP somehow got a rev 4.0 mobo then there won't be much difference as he is not going to OC so PII and Athlon II cpus with 95W TDP will run just fine on that.
    Coming to the cpu it's hard to find Athlon II X4s so it's better to get Phenom II X4 840 @ 5.3k from local shops.
    1600Mhz ram will run at 1333 Mhz on the this mobo - to run them at 1600Mhz Op needs to OC the mems a little bit but that's very easy to do
    Who Dares Wins
    Avenging Angel !
    Phenom II 955BEAsus M5a97 R2.0Corsair 2x 4GB RAMHD6850Corsair GS600CM Hyper 212CM 430 Elite
    My Blog : http://topgeartopspeed.wordpress.com/
    BlackListed : Viewsonic, Gigabyte
  4. #4
    Aug 2011
    Mumbai
    u just have to enter the BIOS and change to RAM multiplier from x6.66 to x8.00 as for the 4670 thats fine
    Athlon II X4 640 @ 3.55Ghz || Gigabyte 78LMT-S2P || 6 GB DDR3 RAM ||Zotac GTS 450 1GB DDR5 @ 920/1050/1800 @ stock volts || 500GB Seagate HDD || Corsair CX430 V2 || Philips 107 E5 1024x1280 @ 60Hz || 3D mark 06 score 15450
  5. #5
    Dec 2011
    Thank you guys for your replies.
    Any ideas abt any good place in Kolkata to buy...
  6. #6
    Jul 2006
    Geek's Heaven
    ^^ try MD computers and bargain a bit to get a good deal
    Who Dares Wins
    Avenging Angel !
  7. #7
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    Me n Tenida was in the Chandni chawk yesterday n find out no Athlon II X4 processors are available. Only Phenom II and Athlon II X2 are available. So Phenom II 955 is the best choice now. Price will be around 5.8K..
    AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
  8. #8
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    Quote Originally Posted by Cilus View Post
    Any idea about when they will be available again? Cause, till then suggesting atlonII X4 would make no sense at all. (and I don't think they will be imported again soon, if not ever).
  9. #9
    Mar 2009
    Kolkata
    Only choice is Online stores like smc, theitwares, Flipkart etc.
  10. #10
    Aug 2011
    Kolkata
    ^^ most of the time they are costlier than street price. :-/
  11. #11
    Nov 2011
    NCR
    Quote Originally Posted by d6bmg View Post
    is this true even for situations where you buy from the shop itself which also sells online e.g.smcinternational in nehru place?
  12. #12
    Dec 2011
    Thumbs up Re: URGENT--CPU+Mobo under 8k
    I finally got the following items from Supreme IT Mall, behind Chandni Metro Gate-
    Athlon II x4 645- Rs 5000
    GIGABYTE GA-78LMT-S2P v3.1- Rs 2550
    Zion 4 GB 1333- Rs 1200
    Thank you all for your cooperation
  13. #13
    Gadget Freak Tenida's Avatar
    Aug 2008
    Calcutta
    ^^So you find Athlon II quad core processor at this hard time...nice very nice.Congrats
    My Gizmos O_O
    ||Core i7 2600K | MSI Z68A GD80 | MSI GTX560Ti ||
    ||F&D A555U | Roccat Kave | Funbook | LG Optimus L9 (W) ||
  14. #14
    Mar 2009
    Kolkata
    Quote Originally Posted by windtalker View Post
    Nice purchase buddy n the prices are good too. Congrats man....nJoy gaming now.
  15. #15
    Jul 2006
    Geek's Heaven
    Congrats on your purchase and for finding that Athlon II X4 645 - though I'm not a great fan of the shop from where you got the cpu but at the end of the day you just got the right things at right prices which made it a good deal
    Who Dares Wins
    Avenging Angel !
  1. AM3 mobo (urgent)
    By soyab0007 in forum PC Components / Configurations
    Last Post: 02-11-2011, 07:34 PM
  2. Urgent - need mobo for i5 2400 !
    By karthik316_1999 in forum PC Components / Configurations
    Last Post: 31-08-2011, 08:28 PM
  3. URGENT HELP ! with cpu and mobo
    By kooki in forum Hardware Q&A
    Last Post: 10-04-2008, 09:35 AM
  4. Compare mobo URGENT
    By nishant_nms in forum Hardware Q&A
    Last Post: 15-10-2006, 10:35 AM
  5. urgent help req. mobo=psu
    By choudang in forum CPU / Motherboards
    Last Post: 30-12-2005, 08:46 PM
