Results 1 to 22 of 22
  1. #1
    s2n
    s2n is offline
    Sep 2011
    Default Best mobo for i5 2500k?
    Hi,
    Please suggest a mobo (budget around 6k) for i5 2500k.
    I am interested in OC to 4 - 4.5 ghz max.
    Thank you.
  2. #2
    Fast 'N' Furious topgear's Avatar
    Jul 2006
    Geek's Heaven
    Default Re: Best mobo for i5 2500k?
    you can't find any good mobo which can be used to Oc core i5 2500k around ~6k.
    Increase your budget and get MSI Z68A-GD55 or Gigabyte GA-Z68AP-D3 or Asus P8Z68-M PRO - all of these are around ~9k
    Who Dares Wins
    Avenging Angel !
    Phenom II 955BEAsus M5a97 R2.0Corsair 2x 4GB RAMHD6850Corsair GS600CM Hyper 212CM 430 Elite
    My Blog : http://topgeartopspeed.wordpress.com/
    BlackListed : Viewsonic, Gigabyte
  3. #3
    Aug 2007
    Chinchwad Pune
    Yep. For 6K you will get H67 / H61 Mobo which are good for Non "K" versions.
    Stretch Budget around 8.5K Minimum to get the MSI GD55
    Jetway Mobo is cheaper but reviews are not good.
    Phenom II 955 BE | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Kingston v300 SSD 240 GB | Seagate : 1 TB | NZXT Phantom 410 | Sony Experia Neo V
  4. #4
    Overclocker @ 4.8 Ghz esudip's Avatar
    Sep 2011
    Pune
    If you want to Overclock you have to Stretch your budget. If you are buying a Intel i5 2500K you need to take graphical advantage of it so I suggest you to buy Z68 Chipset board.
    I just brought Asus P8Z68-V for my Intel i5 2500K and I successfully OC it to 4.8 Ghz. There are Z68-M (Micro ATX) boards from Asus which rages between 8-9 K
    Intel Core i 5 2500K @ 4.6 Ghz | Asus P8Z68-V | Gskill Sniper 1600 16 gb | Thermalright Silver Arrow Heatsink | Corsair TX750-V2 PSU | Cooler Master HAF 922 Cabinet | Raedon HD 6970 2 Gb :hyper:
  5. #5
    Sep 2011
    @OP, I can provide u good deal on Biostar TZ68 A+, Not overclocking beauty but will sufficient for Turbo Boost. Also Z68 Platform. Actually the marketing guy from Biostar is good friend of mine so if I can help u anyway on Non Profit basis i would love to
    Do consider suggestion by fellow members but Personally i will save 1.5k-2k on board & will spend it on getting nice cooler which is must even though u r Planning Turbo Boost(Most are confident with Stock HSF so the suggestion)
    Anyways let us knw if we can further help u in anyway
  6. #6
    Human Spambot MegaMind's Avatar
    Nov 2010
    Perambalur, TN
    I'd say save up for atleast Asus P8P67-M - 8K
    i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - Plextor M3 PRO 128GB - 1TB 7200.12 - GTX 570 sonic platinum - CM M850 - HAF X - XONAR DX + Z906/XB500 - OptX AW2210 - DSL 2750U - APC 1.1KVA
  7. #7
    Human Spambot saswat23's Avatar
    Jan 2011
    Bhubaneswar
    AFAIK Asus P8Z68-M comes for around 9k. So, why go for P8P67-M.
    Check here
    My Blog :D
  8. #8
    Sage of the Six Paths
    Sep 2011
    Jetway's Z68 JHI09-Z @6.8k is probably the cheapest you can get. But I'd save up for a Asus motherboard.
  9. #9
    Nov 2010
    Perambalur, TN
    Quote Originally Posted by saswat23 View Post
    Z68 doesnt really hav any advantage if u dont use ssd caching & virtue... .
    Also its confirned that P67/Z68 chipsets wont support Sandy-Bridge-E cpu..
  10. #10
    Sep 2011
    Quote Originally Posted by MegaMind View Post
    Also its confirned that P67/Z68 chipsets wont support Sandy-Bridge-E/Ivy bridge cpu..
    May I have a link to this news?
  11. #11
    Nov 2010
    Perambalur, TN
    Quote Originally Posted by rajnusker View Post
    Impressive yes, but sure there are obstacles as well, the processor needs a new motherboard as it comes on a new processor socket, LGA 2011. That means reinvesting in a new high-end motherboard probably costing 200~300 EUR, and then investing in a new Sandy-Bridge-E processor which is probably going to cost you a steep 900 EUR for the most high-end model (which we will use today).
    Source
  12. #12
    Sep 2011
    Pune
    Oh Men, I have P8Z68-V board from ASUS and it has Z68 Chipset which runs my Intel i5 2500K SANDY BRIDGE Very well @ 4.8 Ghz........
  13. #13
    make.believe Ayuclack's Avatar
    Jul 2011
    Ahmedabad
    Msi z68 gd 80 b3
    Gaming PC :Core i5 2500K || MSI Z68 GD 65 (B3)|| Corsair A70 || Gskill Ripjaw X ||550 Ti||Corsair GS700||Logitech G300||Sound Gear||AudioTechnica ATH M50||Tt eSport Shock||Sennheiser CX90||Sennheiser PMX60||SoundMagic E10||SoundMagic ES18||iPod Touch 4G 64||iPhone 4&4S||Xperia S CM10.1||Note 2 Omega||Tab 7 + PA CM10.1||Photography ||Nikon D5200||18-55 VR ||50mm f/1.8D||SanDisk Extreme 16GB + 4GB
  14. #14
    Jul 2006
    Geek's Heaven
    ^^ what's the price ?? last time I remember it was around ~13k which will be too steep considering Op's budget but as OP is not replying anymore we can't say for sure if he is willing to increase his budget or not
    Who Dares Wins
    Avenging Angel !
  15. #15
    Wandering In Tecno Land Ecko's Avatar
    Feb 2005
    ^Bump
    Same issue ..Just wanna spend around 7-8k max
    Born in Windows Die In Linux © 2009-10 All Rights Reserved.
    Learn Linux : www.linoob.com (Official WebSite)
  16. #16
    Gadget Freak Tenida's Avatar
    Aug 2008
    Calcutta
    Quote Originally Posted by Ayuclack View Post
    Msi z68 gd 80 b3
    MSI Z68A GD80(B3) costs Rs 14000/-+Vat
    My Gizmos O_O
    ||Core i7 2600K | MSI Z68A GD80 | MSI GTX560Ti ||
    ||F&D A555U | Roccat Kave | Funbook | LG Optimus L9 (W) ||
  17. #17
    Query Killer!!!!!! max_snyper's Avatar
    May 2006
    Mumbai
    ^^ what are the current prices for z68-gd65 & z68-gd55 in India as of current?
  18. #18
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    ^^ GD55 is around 9.5K and GD65 is around 10.6K.
    AMD FX 8350 @ 4.5 GHz|16 GB RipjawX 1873 MHz CL10 @ 1.6V|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus with CM 10.1 JB 4.1|HCL Me Y2 Tab (rooted)] XOLO Q800 with Ultimate V2 JB 4.2.1| Galaxy Tab 2 P3100
  19. #19
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    Quote Originally Posted by Ecko View Post
    ^Bump
    Then Asus P8P67-M is the best option for you.
    And for overclocking P67 is better than Z68. This is not my word but it is being said by many many experts, AFAIK.
    Inactive in TDF.
  20. #20
    Jul 2006
    Geek's Heaven
    @ Ecko - increase the budget a little more and get P8Z68-M PRO @ 8.9k
    Who Dares Wins
    Avenging Angel !
  21. #21
    Feb 2005
    @topgear Where I can buy it ?? Online @ that price ??
  22. #22
    Jul 2006
    Geek's Heaven
    ^^ here you go
    Link
    Who Dares Wins
    Avenging Angel !
  1. Mobo under 12000 for i5 2500k
    By N@m@n in forum CPU / Motherboards
    Last Post: 12-07-2012, 04:27 PM
  2. Mobo for i5 2500K:Gigabyte p67 ud5 b3 or z68? Or any others?
    By Vamsisd in forum CPU / Motherboards
    Last Post: 20-02-2012, 04:45 AM
  3. Z68 Mobo req for i5 2500K Budget 10k
    By priyam1309 in forum CPU / Motherboards
    Last Post: 16-10-2011, 04:51 PM
  4. Best mobo for 2500k or 2500
    By rdrockyrocks20 in forum CPU / Motherboards
    Last Post: 05-08-2011, 03:53 AM
  5. Core i5 2500k + mobo
    By rak2410 in forum PC Components / Configurations
    Last Post: 16-04-2011, 10:07 PM
