Results 1 to 15 of 15
Thread: No display ASUS P8Z68 V PRO
17-07-2011, 09:20 AM #1
I just assembled my new system and hooked everything up. Now I don't get any display both on VGA and DVI. No boot screen nothing.
Asus P8Z68 V PRO|Intel Core i5 2500k|NZXT Tempest Evo|GSkill RipjawsX 4GBx2|Corsair TX 850 V2|Seagate Barracuda 7200.12 1TB x 2|Noctua NH-D14|Sapphire HD 7870
17-07-2011, 10:31 AM #2
Re: No display ASUS P8Z68 V PRO
Are the CPU and GPU/PSU fans spinning up.
17-07-2011, 10:37 AM #3
You are not getting display on both onboard vga and hd6970?
My Gizmos O_O
||Core i7 2600K | MSI Z68A GD80 | MSI GTX560Ti ||
||F&D A555U | Roccat Kave | Funbook | LG Optimus L9 (W) ||
17-07-2011, 02:03 PM #4
All fans spinning. Just no display. I'm not talking about the Graphics card display. Only the onboard display.
One more thing. I just tried pulling out the RAM and booting the PC up. No beeps, no display coming. Just fans spinning and LEDs lit up on mobo and cabinet.Asus P8Z68 V PRO|Intel Core i5 2500k|NZXT Tempest Evo|GSkill RipjawsX 4GBx2|Corsair TX 850 V2|Seagate Barracuda 7200.12 1TB x 2|Noctua NH-D14|Sapphire HD 7870
17-07-2011, 02:10 PM #5
Connect the dvi cable of ur monitor to your graphics card port.See if the display is coming or not.
My Gizmos O_O
17-07-2011, 03:43 PM #6
I'm already using the video card in on PC. I'm testing the other PC. I don't understand why the onboard graphics won't show up. All fans spinning. All leds on. CPU led. Optical disk drive working. Could it be because of RAM failure?
Sorry. Problem fixed.Asus P8Z68 V PRO|Intel Core i5 2500k|NZXT Tempest Evo|GSkill RipjawsX 4GBx2|Corsair TX 850 V2|Seagate Barracuda 7200.12 1TB x 2|Noctua NH-D14|Sapphire HD 7870
17-07-2011, 07:09 PM #7
^^Wat was the prob.?
i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - Plextor M3 PRO 128GB - 1TB 7200.12 - GTX 570 sonic platinum - CM M850 - HAF X - XONAR DX + Z906/XB500 - OptX AW2210 - DSL 2750U - APC 1.1KVA
18-07-2011, 12:19 AM #8
I guess he initiated the pci/peg adapter or used auto select in bios display out settings, auto mode selects pci gfx i.e the 6970 in his case, but he connected the adapter to the mobo display out.
Project Halcyon V2.1
2600k/Z68VPro/Vengeance/U12PSE2/TX750v2/1TB.Black/DRWB5ST/HAF912+A
M35/PortaPro/E30/Optimus.L9/Siberia/5800XM/FZ150/SH14/FiiO.E6
Dell.15R/Ci3.3110m/7670m/ALVS4621/Funbook/Ferox
18-07-2011, 10:27 AM #9
If the GPU is used, the onboard gets disabled.
18-07-2011, 11:33 AM #10
U need to set the "Initiate Graphics adapter As Onboard"...is set to PCIE by default imo...
PC: Core i7 2600K||Z68V Pro||Noctua U12P SE2||Vengeance 1600Mhz 8GB||GTX560Ti HAWK||CM Elite 430||1TB+300GB||VX550||G110||G1 mouse||Razer Goliathus Ω
Photography: Nikon D5100||Nikon 55-300 VRII||Canon Powershot SX220HS||Tamrac Velocity 9x
Audio:Brainwavz M4,B2,R1||Meelec A151||PX100 II||Fiio E5||AudioTechnica ATH-T500
18-07-2011, 11:43 AM #11
Guys, Off topic : If Virtue is enabled, Will the power consumption in GPU idle be reduced?
18-07-2011, 10:05 PM #12
18-07-2011, 11:04 PM #13
28-07-2011, 02:46 PM #14Right Off the Assembly Line
- Join Date
- Jul 2011
- Posts
- 1
Hi I got the very same problem. After assembling my new build system I get:
1) No POST - VGA LED lights constantly red
2) No Beep tones (speaker cable is plugged correctly)
3) No Screen on monitor (no signal, tried VGA and DVI cable on Graphics card
output)
4) Monitor works fine with Laptop (tried to extend the display)
5) Graphics card seats firmly, pins are clean, connected through both 8 + 6 pin connectors form power supply and was tried in both slots
6) CMOS was cleared through jumper on motherboard
7) All CPU, Graphics, and Chassis fans fans are spinning
7) No expansion cards are plugged in
8) No USB devices plugged in as well
POST LEDs by start up:
CPU - Check
RAM - Check
VGA - Failure - Lights up red
Boot Device - Doesn't light up
Hardware equipment:
CPU: INTEL i7 2600K
Motherboard: ASUS P8Z68-V Pro
Graphics: ASUS Radeon HD 6970/2DI2S/2GD5
RAM: CORSAIR 16GB (4x4) KIT DDR3 1600MHz CL9 Blue Vengeance XMP
HDD: WESTERN DIGITAL Caviar Green 3TB 64MB cache SATA III Advanced Format
DVD: ASUS DRW-24B3LT/BLK/G/AS
PSU: CORSAIR GS800
What could be the problem, how did you manage to fix it ?
Please advise - thank you
30-07-2011, 10:28 PM #15
Turns out I forgot to plug in the EATX 12V power. The 8 pin one. All my life I'd been used to just plugging in the 24 pin ATX connector.
20-02-2012, 01:17 AM
05-02-2012, 10:35 PM
05-02-2012, 07:06 PM
09-12-2011, 02:52 PM
09-12-2011, 12:06 PM
03-12-2011, 07:53 AM
02-12-2011, 03:12 PM
01-12-2011, 01:27 PM
30-11-2011, 08:04 PM
P8Z68-V PRO no signal to monitor and red memory light - General-Motherboard - Motherboards-Memory
Refback This thread29-11-2011, 04:48 AM -
ASUSTeK Computer Inc.-Forum- P8Z68-V PRO no signal to monitor and red memory light
Refback This thread29-11-2011, 02:10 AM -
27-11-2011, 09:52 PM
Refback This thread27-11-2011, 08:15 PM
Problem related to Asus P8Z68 V-Pro
By summers in forum CPU / MotherboardsReplies: 3Last Post: 02-10-2011, 08:30 PM -
Asus P8z68 V Pro MB - Sleep Mode Help
By fantom in forum Hardware Q&AReplies: 0Last Post: 05-09-2011, 10:10 PM -
Asus P8Z68-V PRO Unboxing
By toolius in forum OverclockingReplies: 6Last Post: 07-08-2011, 11:09 PM -
Asus P8z68 V pro MB help
By techking_dinesh in forum Hardware Q&AReplies: 23Last Post: 29-06-2011, 06:51 PM -
asus p8z68-V or p8z68-v-pro which one ?
By fukra in forum CPU / MotherboardsReplies: 23Last Post: 25-06-2011, 01:37 AM
LinkBack URL
About LinkBacks
