Page 1 of 9 1 2 3 4 5 6 7 8 9 LastLast
Results 1 to 30 of 267
  1. #1
    Project Halcyon V2.1 tkin's Avatar
    Aug 2008
    Hyderabad, India
    Default CPU Cooler Guide For Sandy / Ivy Bridge Cpus !!
    This post has an update long overdue, I will update this over the next week(I need to read up a bit), I urge you to contribute what you can, reviews, prices, links, articles(written by you), pics(800x600).
    Recently I'm seeing lots of people asking questions about whether they need an after market cooler for Sandy system, this small report is intended for them.
    Q: Do I Need an after market cooler for Sandy CPU?
    Ans: Depends on the CPU:
    1. 2600k: Yes, even with stock.
    2. 2500K and the else: No, needed only for Oc'ing.
    Coolers Preferred:
    Upto 2k:
    Cooler Master Hyper 212+:
    Comes with 1 FAN
    Cooler Master Hyper 212 plus review
    Cooler Master Hyper 212 PLUS CPU Cooler Review | Hardware Canucks
    Cooler Master Hyper 212 Plus Review - Overclockers Club
    2-3k: Cooler Master N620
    Comes with 2 FANs
    Cooler Master Hyper N620 Review - Overclockers Club
    Coolermaster Hyper N620 Review - Page 1 - Introduction
    Cooler Master Hyper N620 CPU Cooler Review | Hardware Secrets
    Cooler Master Hyper TX3 and N620 Review | AlienBabelTech
    OR:
    Hyper 212+ and 1x Cooler Master Blademaster Xtraflow fan for 600/-
    3-4K:
    Noctua U12P SE2
    Comes with 2 FANs
    Noctua NH-U12P SE2 CPU Cooler Review - The Noctua NH-U12P SE2 - Legit Reviews
    Noctua NH-U12P SE2 CPU Cooler | Overclockers Online
    Noctua NH-U12P SE2 CPU Cooler Review | Reviews - Clunk.org.uk
    Noctua NH-U12P SE2 CPU Cooler Reviewed
    OR:
    Thermalright TRUE Rev. c
    (installed fan will block first ram slot, 2nd, 3rd and 4th slot can be populated), does not come with fan, also 1156(sandy bridge) bracket needs to be bought separately.
    Pics by digit member(Faun): http://www.thinkdigit.com/forum/cpu-...ml#post1428596
    Reviews:
    TRUE Rev. C - Thermalright Ultra Extreme 120 Revision B & C Review | [H]ard|OCP
    Thermalright Ultra 120 eXtreme Rev.C Review - Overclockers Club
    4-5K: Noctua NH-D14
    Comes with 2 FANs
    Digit member Review: Noctua NH D14 Review [Re posted]
    Noctua NH-D14 review
    Noctua NH-D14 CPU Cooler Review
    Noctua NH-D14 Review - Overclockers Club
    Noctua NH-D14 HSF Review - The Best CPU Cooler Ever? - The Massive Noctua NH-D14 - Legit Reviews
    Now, The Horror that is Intel Stock cooler that comes with Sandy Bridge:
    The baseplate is anything but mirror:
    That's a 2/- coin:
    The other side of the cooler, no heatpipe, nothing, its just a hollow metal container:
    Hmm, that's 1.5cm
    The fans happens to be a delta though, surprise, surprise:
    Important: Now, the compatibility, most coolers have 42mm+ clearance underside, so Gskill rams will fit, but the likes of corsair vengeance will not, if the cooler heatsink clears the ram slot or have fans that can be raised, it can fit vengeance rams, 212+, U12PSE2, N620 falls in this category, D14 does not, D14 goes over ram slot(the heatsink), so you need to buy Gskill RAMs.
    If you want to know the compatibility of any rams with any cooler, post here, I'll get back to you as fast as I can.
    Thermal Interface Material Guide:
    TIM is a substance that forms a layer between the grooves of the cooler baseplate and CPU HSF, it is needed because air trapped in the grooves acts as insulator and decreases thermal conductivity, thereby increasing the temperature of the CPU.
    There are two basic types of TIMs;
    1.Electro conductive: These tims have metal particles in them, as you know metal is very good thermal conductor but they are also electro conductive, one drop falling on your mobo or cpu socket will fry it, these tims are best but with better performance comes higher risks, I'd suggest users to not buy these types of TIM, Eg: Arctic Silver 5
    2.Non electro conductive: These do not conduct electricity, so it will cause no issues if it falls on your mobo, they have good performance, a balance between performance and risk.
    Eg: Arctic Cooling MX2, MX4, Noctua NTH1(free with noctua coolers), Tuniq TX4, Coolermaster thermal fusion.
    TIM Properties that are the measure of its bleeding and performance capabilities:
    Viscosity: Higher this value is, the more "Sticky" the paste will be, lower viscosity means its easier to spread, higher means you have to spread with finger.
    Thermal conductivity(Fourier's Law of conduction, Unit: W/mK): The higher this value, the better the cooling performance of the tim.
    Detailed Analysis of Some Popular TIMs
    by mukherjee
    A. Non Electro-conductive
    1. Tuniq TX-3
    Specifications:
    Available @395/- +shipping @ The IT Depot
    Reviews: Tuniq TX3 Review
    2. Tuniq TX-4
    Specifications:
    Available @440/- +shipping @ The IT Depot
    Currently,the TX-4 is the best TIM available,but its viscous and a bit more difficult to spread than others...it is non electro conductive though...
    Reviews: Tuniq TX-4 Thermal Grease Review » Page 3 - Specifications & Features - Overclockers Club
    3. Arctic Silver Matrix
    Specifications:
    At a layer 0.003" thick, one syringe will cover about 20 square inches.
    Available @230/- +shipping @ The IT Depot
    4. ARCTIC MX-2
    Specifications:
    Available @ Mediahome.in(390/-+Shipping)
    Review: Bay Reviews: ARCTIC MX-2
    5. ARCTIC MX-4
    Specifications:
    Presently the best TIM available for money...but as always...unavailable in India....will cost ~900/- to get a 4gm tube shipped to India from Hong Kong presently
    Reviews of MX-4:
    OverclockersHQ: ARCTIC MX-4
    OCC: ARCTIC MX-4
    MADSHRIMPS: ARCTIC MX-4
    B. Electro-Conductive
    1. Arctic Silver 5
    Specifications:
    Warning: These are electro conductive TIMs. Inadvertent spillage on electrical components WILL harm them
    Available @530/- +shipping @ The IT Depot
    Comparison of some Thermal Interface Materials
    http://benchmarkreviews.com/index.ph...=150&Itemid=62
    How to apply TIM for HDT Coolers like Hyper 212+
    http://benchmarkreviews.com/index.ph...1&limitstart=5
    Contributers: Tkin, mukherjee, Faun, asingh
    2600k/Z68VPro/Vengeance/U12PSE2/TX750v2/1TB.Black/DRWB5ST/HAF912+A
    M35/PortaPro/E30/Optimus.L9/Siberia/5800XM/FZ150/SH14/FiiO.E6
    Dell.15R/Ci3.3110m/7670m/ALVS4621/Funbook/Ferox
  2. #2
    Treatment in progress... mukherjee's Avatar
    Apr 2005
    Amar shohor Kolkata
    Default re: CPU Cooler Guide For Sandy / Ivy Bridge Cpus !!
    A very informative thread and it comes at the nick of time!
    PC: Core i7 2600K||Z68V Pro||Noctua U12P SE2||Vengeance 1600Mhz 8GB||GTX560Ti HAWK||CM Elite 430||1TB+300GB||VX550||G110||G1 mouse||Razer Goliathus
    Photography: Nikon D5100||Nikon 55-300 VRII||Canon Powershot SX220HS||Tamrac Velocity 9x
    Audio:Brainwavz M4,B2,R1||Meelec A151||PX100 II||Fiio E5||AudioTechnica ATH-T500
  3. #3
    May 2011
    excellent work.
  4. #4
    I am the night...I am... vickybat's Avatar
    Aug 2009
    Gotham City
    @ tkin
    Nice post buddy. Intel stock coolers are really pathetic. Btw have you ever tried fitting your stock cooler? How did you do it?
    I think my stock cooler is not fitting properly. Do you have to press all the four pillars simultaneously?
    Core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book ,Seagate freeagent ext hdd 1tb , hp dvd writer,Apc 650 va, logitech z313 , Micromax Funbook , Klipsch image S3 (IEM).
  5. #5
    Digit Squad Member techking_dinesh's Avatar
    Aug 2008
    Nashik
    So i m gng with i72600k , cm hyper 212plus .. Enough ??
    ll be using cm690ii cabby with 3 fans..
    Will corsair and gskill , both fit properly ??
    i m gonna use single stick of 4gb for nw
  6. #6
    Aug 2008
    Hyderabad, India
    Quote Originally Posted by vickybat View Post
    @ tkin
    Put the cooler on top of CPU, now gently push the pins in so that they go through the hole, but do not tighten it yet, now push down on the cooler and keeping the pressure, use a screw driver to tighten two diagonally opposite screws, be careful or the screw driver will slip and hit the motherboard.
    Quote Originally Posted by techking_dinesh View Post
    Yes, its good enough, even for moderate oc, make sure to buy one more fan for 212+(it comes with one fan) for push pull.
    Yes, both rams will fit, without any issue.
  7. #7
    Aug 2008
    Nashik
    Can u elaborate d detail of extra fan plz ?
    i live in a very small city , wnt get it here ,
    so how much mm , wat kinda extra fan ??
  8. #8
    Aug 2008
    Hyderabad, India
    This fan:
    Cooler Master Blade Master Xtraflo 120MM Computer Fan | eBay
    This is an exact copy of the fan that comes free with 212+(well not exact as it has leds etc, but speed, air pressure etc are same), so you should try to get it, two fans used as push pull must be very close to each other in specs for optimal performance.
    The above listing has ended, wait a few days and it will be relisted in ebay again.
  9. #9
    Wahahaha~! Faun's Avatar
    Dec 2006
    Pune/there
    Can I use my stock cooler's fan as cabinet fan. Any way ?
    Steam | Flickr | Battlelog
    Asus Z68 V-Pro|i5 2500k|TRUE Black|Ripjaws X|U2311H|N560GTX Ti|D7000|Classic Vibe 50 Strat|XONAR STX|RE272|UM Miracle|Optimus G
    Aug 2008
    Hyderabad, India
    Quote Originally Posted by Faun View Post
    Well, not in basic form, you can try to hard mod it, but I'm not sure if it will void warranty from intel(manual says you need to return item in exact condition, not sure if it needs the fans for rma as well).
  11. #11
    Super Moderator Skud's Avatar
    Jun 2004
    10 light years away
    Nice and very informative posts. Pics are very good too.
    Gaming Rig:i7 2600K | N620 | P8Z68 Deluxe | 2x4GB RipjawsX DDR3 1600 | Vertex 3 120GB | Logitech G510 | Logitech G400 | Sapphire 6950 1GB | BenQ G2420HD | Corsair HX750 | Lancool K62
    HTPC Rig: C2D E7400 | EP45-DS3R | 2x2GB DDR2 800 | MS Wireless Desktop 2000 | Gigabyte 5770 | Samsung 32" | Seasonic SII 520W | Silverstone LC10
    Audio Gear: Altec Lansing VS2421 | ASUS Vulcan ANC | HiFiMan RE-0
    Storage: 2x250GB | 3x500GB | 3x1TB | 3x2TB
    Android: Galaxy R | Galaxy Y
  12. #12
    Super Moderator asingh's Avatar
    May 2008
    New Delhi
    Really nice and informative.
    Stuck'ed.
  13. #13
    Aug 2008
    Hyderabad, India
    ^^ I'll update this guide with tims and optional coolers, right now researching price of other coolers.
  14. #14
    Jun 2004
    10 light years away
    That's nice addition, mukherjee.
  15. #15
    Aug 2008
    Hyderabad, India
    I'm adding this to first post, with credits to mukherjee, other members please help out, those who have after market coolers, please post here, I'll add your post to first post with due credits.
  16. #16
    May 2008
    New Delhi
    Mukherjee, removed your original content. Since Tkin merged it. He gave you credit -- which is honorable.
  17. #17
    Apr 2005
    Amar shohor Kolkata
    Quote Originally Posted by asingh View Post
    Yea..he's a nice guy
    Quote Originally Posted by tkin View Post
    Thanks
    Quote Originally Posted by Skud View Post
    Thanks a lot bro
    Sheesh...all the review links I put up...went for a walk...
    @ tkin...if u can...please add the Tx3 and Tx4 review links...also update the price of Mx2 @390+shipping @ Mediahome.in.....I cant modify those...
  18. #18
    Aug 2008
    Hyderabad, India
    No worries bro, I'm doing it, you should think about me, I had to put the top post in part by part, it was painfully slow.
  19. #19
    Human Spambot The Sorcerer's Avatar
    May 2008
    D14 should come with a disclaimer as it can be obstacle for certain memory kits with taller heatspreaders. Its a good thing you mentioned it . Good findings.
    Truth be told, we should get thermal pastes like X23-7783D. Those MX2 aren't like the older ones when they used to come in older black packs. Some say OCZ freeze is a better option but I'll guess I'll give it a shot.
  20. #20
    Dec 2006
    Pune/there
    Thermalright TRUE Black didn't pose any hindrance to Vengeance. Though one migh require slim version of fan as the Scythe Ultra Kaze I received are humungous. This fan literally blows the wind out of your system like a jet engine, sound like one too
    May 2008
    New Delhi
    Tkin, I will dig up my NHD14 review. You can update it on the link...! I think it got purged from TDF. Will copy it over from TE. Hope that will help. It has detailed stuff about RAM deltas to the fans.
  22. #22
    Fast 'N' Furious topgear's Avatar
    Jul 2006
    Geek's Heaven
    great guide - bookmarked it.
    Who Dares Wins
    Avenging Angel !
    Phenom II 955BEAsus M5a97 R2.0Corsair 2x 4GB RAMHD6850Corsair GS600CM Hyper 212CM 430 Elite
    My Blog : http://topgeartopspeed.wordpress.com/
    BlackListed : Viewsonic, Gigabyte
  23. #23
    Apr 2005
    Amar shohor Kolkata
    Have a look at this Sandy Bridge Buyer’s Guide
  24. #24
    Dec 2006
    Pune/there
    Here are the pics of Thermalright TRUE Black to give an idea about clearance and other issues
    Will be moving to 25mm width fans and back to dual channel later.
    PS: You need to buy fan and 1156 (compatible with 1155) socket bracket separately for it.
    Aug 2010
    Nice Guide .. Just what I needed ... I will buy aftermarket HSF soon ... Stock Cooler sux Bigtime ...
    Thank God !!! I didnt buy arctic silver 5 ... was gonna buy that b4 I got the matrix ....
    Intel i5 760 || Asus P7P55D-E || Corsair 2X2 Gb DDR3Kit || Corsair GS 600 || WD Green 1 TB || XFX 4350 || CM 430 Elite || Samsung B2230
  26. #26
    Aug 2008
    Hyderabad, India
    @ Faun, merged your post on top, let me know if I need to modify anything.
  27. #27
    Aug 2010
    @faun : Adding another fan will block ur RAM slot ???
    @tkin : What should I buy ???
    N620 or Hyper 212 + ???
    Coz N620 looks more bling bling !!!!
  28. #28
    Aug 2008
    Hyderabad, India
    Quote Originally Posted by vizkid2005 View Post
    N620, if you can find it, very vfm cooler, I would've bought it if it was available at 2.5k(the actual market price)
  29. #29
    Aug 2010
    @tkin : Will fit in my Cabby ?? I guess so ... Wat say ???
  30. #30
    Aug 2008
    Hyderabad, India
    Not a problem.
  1. 19-10-2012, 04:18 PM
  2. 31-07-2012, 04:08 PM
  3. 12-07-2012, 02:26 AM
  4. 02-07-2012, 03:33 PM
  5. 05-06-2012, 05:26 AM
  6. 10-05-2012, 12:57 PM
  7. 14-04-2012, 03:07 PM
  8. 13-04-2012, 07:40 PM
  9. 07-03-2012, 09:40 PM
  10. 07-03-2012, 07:21 PM
  11. 07-03-2012, 06:47 PM
  12. 02-03-2012, 10:10 PM
  13. 02-03-2012, 10:26 AM
  14. 27-02-2012, 08:43 PM
  15. 01-02-2012, 04:41 PM
  16. 29-01-2012, 10:00 PM
  17. 28-01-2012, 05:42 AM
  18. 05-11-2011, 02:56 PM
  19. 04-11-2011, 09:46 AM
  20. 24-10-2011, 10:26 PM
  21. 12-08-2011, 12:38 PM
  22. 07-08-2011, 11:38 PM
  1. New pc build. Sandy bridge or wait for ivy bridge?
    By Vishnupg45 in forum CPU / Motherboards
    Last Post: 16-03-2012, 08:06 PM
  2. Intel Fixes VT-d Bug in Sandy Bridge-E CPUs
    By singh1982 in forum CPU / Motherboards
    Last Post: 19-12-2011, 07:21 PM
  3. Help me to buy sandy bridge...
    By a2mn2002 in forum PC Components / Configurations
    Last Post: 23-04-2011, 11:27 PM
  4. Sandy Bridge Processors
    By CHALLENGER in forum PC Components / Configurations
    Last Post: 07-02-2011, 11:35 AM
  5. Don't Buy Sandy Bridge now...
    By anikahead2010 in forum PC Components / Configurations
    Last Post: 02-02-2011, 10:09 PM
