Which Motherboard has best built-in graphics?
Results 1 to 11 of 11
Thread: Which Motherboard has best built-in graphics?
  1. #1
    Addicted
    Jun 2010
    Khardah,Kolkata
    Question Which Motherboard has best built-in graphics?
    I am looking for a Motherboard that has best built-in graphics within rs. 6000 for both amd and intel.Can I get a sandybridge?
    Popular Gadget Deals
  2. #2
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    Default Re: Which Motherboard has best inbuilt graphics?
    Sandy bridge motherboards don't have on-board graphics, the GPU die is fused inside the Sandy bridge processor itself. You can get a H67 chipset based Sandy bridge motherboard within 6K. But let us know what is your budget for the CPU motherboard combo. Then we can suggest u in better way.
    In case of AMD, the best onboard graphucs within 6K will be any 880/870 chipset based mobo. They have ATI HD 4250 graphics card with dedicated 128 MB of DDR3 memory.
    AMD FX 8350 @ 4.5 GHz|16 GB RipjawX 1873 MHz CL10 @ 1.6V|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus with CM 10.1 JB 4.1|HCL Me Y2 Tab (rooted)] XOLO Q800 with Ultimate V2 JB 4.2.1| Galaxy Tab 2 P3100
  3. #3
    Goodbye, TDF!! The Sorcerer's Avatar
    May 2008
    Define "best"? Gaming? Dual digital display? Good enough for 720p/1080p? If you're not being specific about your requirements then you can't get any proper advice. Don't expect any near decent gaming on an onboard.
    Say about your requirements rather than asking what's best or else you'll simply end up in a world of confusion.
    [URL="http://hardwarebbq.com"][B]Hardware BBQ[/B][/URL]
  4. #4
    Addicted
    Jun 2010
    Khardah,Kolkata
    Processor must not exit 6000 rupees. By the way another question , buying a cheap motherboard with a mid end graphics card would be a good option? Sorcerer ,I meant best as a benchmark which fulfills little bit of all of those.
  5. #5
    sam
    sam is online now
    Forum Moderator
    Jan 2010
    Guwahati
    Quote Originally Posted by Cilus View Post
    870X = no IGP.
    880G = HD4250
    890GX = HD4290 so definitely the last one has the best graphics solution but slower than HD3000 found on Intel Core i7 2500k & 2600k's.
  6. #6
    Dec 2003
    Buy a Core i3 SB + H67 motherboard from Gigabyte
  7. #7
    Right Off the Assembly Line shruti's Avatar
    Apr 2011
    Default Re: Which Motherboard has best built-in graphics?
    intel core i3-2100 + intel dh67bl
    both for 12k.
    if u want to wait, then wait for AMD fusion Llano processors. these are going to have really good integrated graphics.
  8. #8
    May 2008
    Quote Originally Posted by the_souvik View Post
    Certain Cheap boards eventually start giving issues in long term.
    Read my questions properly and do answer them. Can't give proper reply if you're not doing the needful. If you're looking for answers that suits you rather than what fulfills your requirements, you can do "Eeenie Meenie Miney moe11' among on the random advices being given.
  9. #9
    Day walker..Night Stalker Piyush's Avatar
    Feb 2010
    GZB.
    @souvik
    please mention your combined budget for processor and motherboard
    and do mention your requirement:will you be using your system for gaming or other stuff like video editing, etc.....
    Steam Id- Alien007
    Gamertag - White Fang
  10. #10
    Addicted
    Jun 2010
    Khardah,Kolkata
    ok let me make it clear. Primarily i am looking for a motherboard, i didn't mention proceesor price as i thought it should be flexible. Another point is gaming can be hardcore or amature. A motherboard can't support hardcore gaming. Right? So somethings are to be understand. Thanks to all those who answered positively.
  11. #11
    sam
    sam is online now
    Forum Moderator
    Jan 2010
    Guwahati
    ^^ how can it be flexible? how can you install a LGA1136 processor on a LGA1155 socket or AM3+ socket?
  1. Help me buy a graphics card and a motherboard !
    By Anandparker in forum Graphic cards
    Last Post: 09-06-2011, 08:21 PM
  2. motherboard and graphics card
    By milind in forum PC Components / Configurations
    Last Post: 10-04-2011, 06:55 AM
  3. Asus motherboard with built-In DDR3 Memory Modules
    By john_the_ultimate in forum Technology News
    Last Post: 10-07-2007, 10:33 PM
  4. Motherboard 'n' Graphics
    By sourishzzz1234 in forum Graphic cards
    Last Post: 22-03-2007, 02:15 AM
  5. Motherboard ,graphics card and ram within 12k
    By executioner in forum CPU / Motherboards
    Last Post: 07-08-2006, 01:18 PM
