Go Back   Digit Technology Discussion Forum > Hardware > CPU / Motherboards
CPU / Motherboards News, discussions, queries and problems related to CPUs and motherboards. Section Thread Index
Old 11-08-2005, 10:34 PM   #1 (permalink)
Dark Overlord !!!
rockthegod's Avatar
Default Plzz Help Regarding Motherboard !!! Its Urgent !!
Hi all,
I know that there's a lot of posts asking for the best motherboard. So this may seem to be a repetition. I am goin 2 buy a new Athlon 64 FX based system. So can ne 1 suggest the best motherboard for around Rs 7000 (preferably available in Kolkata). It must be "the best bang for the buck" !!
Onboard Graphics is highly required !!!!!
Thanx in advance !!!!
C2Q6600@3.2G; eVGA nforce 780i; eVGA 8800 GT 512 MB (650/1900/1620) in SLi; 2 GB OCZ EPP DDR2 8500@1066M; PP&C Silencer 750W; Antec 900
AT&T Tilt WM 6.1 Pro Running Android
Sony PSP 2000 5.0-m33
rockthegod is offline
Old 11-08-2005, 10:38 PM   #2 (permalink)
siriusb's Avatar
Hmmm...your choice of onboard grafx for an FX processor is highly ...irregular, to say the least, because an FX system is primarily for gamers.
But, any way, get an msi rs480 m2 il mobo. I guess that is the only decent one with onboard and s939.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 11-08-2005, 10:44 PM   #3 (permalink)
hey rock
ASUS A8N-E gives the best performance due to the Nforce 4 chipset it has and also the board has pretty good features for overclocking .
It may be around Rs 8000
But no onboard video
The best buy for below Rs 7000 will be MSI-Rs480M2-IL which has got good onboard graphics but with no overclocking options.
So u decide ...
Mahesh Babu is offline
Old 11-08-2005, 11:23 PM   #4 (permalink)
sidewinder's Avatar
MSI 480S M2 ------ Rs 5150
Asus Rs 6750
Bombina rocks
sidewinder is offline
Old 11-08-2005, 11:41 PM   #5 (permalink)
Dark Overlord !!!
rockthegod's Avatar
I will go for the MSI model...... but sidewinder, what ASUS model did u propose ?
Old 12-08-2005, 12:23 AM   #6 (permalink)
siriusb's Avatar
rockthegod,
U are aware FX systems are pretty costly and high performance processors? And that they deserve a better mobo like asus a8ne? If u are going to use the pc mainly as a gaming platform, then ur gpu would be one big bottle-neck here. Try opting for a pci ex video card.
siriusb is offline
Old 12-08-2005, 01:43 AM   #7 (permalink)
Originally Posted by Mahesh Babu
hey rock
So u decide ...
You can over clock the MSI 10-15%.
But dont upgrade your WIN XP SP2 since there seems to some major compatability problems here that spontaneously reboots the machien for one, network access problems and all kinds of other stuff. But its not just this mother board but a lot of them out there. Microsoft seems to be putting out more and more security updates and removing ones which causes problems. I never seen microsoft pull updates before. They have always made a new update which is better.
AlienTech is offline
Old 12-08-2005, 06:32 AM   #8 (permalink)
sidewinder's Avatar
Asus A8N E.But it doesnt hav ond=board gfx.But the performance u get is stupendous.Also recently it added Soundstorm 8 channel high definition audio.So i will go for thid=s board .when clubbed with a 6600gt it will blow any competition
Bombina rocks
Old 12-08-2005, 09:22 AM   #9 (permalink)
MVP in VC++
Yup for a processor like Fx better go for ASUS A8N-E and try for some graphic card...it will boost up u senses
cvvikram is offline
Old 12-08-2005, 11:25 AM   #10 (permalink)
Dark Overlord !!!
rockthegod's Avatar
Hearty thanx to all of u for ur good advices and suggestions !!!! Just 1 thing ..eager 2 kno.. is Athlon 64 FX is neway optimised 4 the purpose of playing games..?? My new system will be primarily used for extensive Video and sound processing !!!!!!
Old 14-08-2005, 05:48 PM   #11 (permalink)
sidewinder's Avatar
go for a64.it rocks concerning ur purpore
Bombina rocks
- by kool
- by Jripper
- by kool
