Results 1 to 2 of 2
Thread: Hard Disk
  1. #1
    Feb 2011
    Default Hard Disk
    I am using an Intel D945GCPE Motherboard. I have recently bought a 500 GB hard disk. The BIOS shows it as 500 GB. But when I tried to load Win XP OS, the unpartitioned space was shown as 126 GB. Can any one solve my problem?
    Ravi Goparaju
  2. #2
    Fast 'N' Furious topgear's Avatar
    Jul 2006
    Geek's Heaven
    Default Re: Hard Disk
    I think you are using a XP intallation disc without any service pack slipstreamed into it and that's the reason it's unable to recognize your HDD sapce properly.
    Use a XP disk with Sp2 or Sp3 slip streamed or else create a small partition to install XP - after XP is installed install service pack 3 - Install all necessary drivers - open disk manager - it's under control panel > admin tools. - now it should show you the unpartitioned space correctly - create partitions using disk manager.
    Who Dares Wins
    Avenging Angel !
    Phenom II 955BEAsus M5a97 R2.0Corsair 2x 4GB RAMHD6850Corsair GS600CM Hyper 212CM 430 Elite
    My Blog : http://topgeartopspeed.wordpress.com/
    BlackListed : Viewsonic, Gigabyte
  1. Hard disk Question(Which hard disk to install the OS)
    By guru_urug in forum Hardware Q&A
    Last Post: 01-09-2011, 01:48 AM
  2. Replies: 8
    Last Post: 10-04-2007, 11:08 AM
  3. can i install new hard disk with old disk's XP oem
    By tech_lover in forum Software Q&A
    Last Post: 24-02-2007, 07:40 PM
  4. compaq deskpro ep/sb series not detecting hard disk disk
    By aditya169 in forum QnA (read only)
    Last Post: 22-05-2005, 07:14 PM
  5. 80GB hard disk converted into 10780 MB hard disk
    By ssingha in forum QnA (read only)
    Last Post: 24-08-2004, 11:57 AM
