| Forum |
| CPU / Motherboards News, discussions, queries and problems related to CPUs and motherboards. Section Thread Index |
#1 (permalink) |
my motherboard - intel d815eea, even on the box they have'nt mentioned there is hardware sensor. so is there any way i can see the temperature without changing the motherboard? |
#5 (permalink) | |
You can use external sensors for CPU, but you'll need to get them from overseas, and it's cheaper to get a new motherboard and CPU. Keith
[ THIS SPACE HAS BEEN RESERVED FOR FUTURE USE IN CASE I WANT TO BOAST ABOUT MY PC'S, HOUSE, CAR, GIRLFRIENDS OR OTHER STUFF THAT I KNOW YOU DON'T REALLY CARE ABOUT ] |
#6 (permalink) |
Wire muncher!
dude is that the original intel manufactured board? if yes then it has a sensor chip.
"The true measure of a man is how he treats someone who can do him absolutely no good." http://phoenix-ani.blogspot.com |
#7 (permalink) |
New CPU's also have built in sensors and also the hard disks. I am not sure where they put in the mother board sensor. In the old days of P2/P3 you had this clip you stuck onto something and that was the mother board sensor.
#8 (permalink) | |
#9 (permalink) |
Who stole my Alpaca!
Hmm interesting .. Try these steps out.
1. Download Motherboard Monitor. 2. The Motherboard is supported ( Check out http://mbm.livewiredev.com/ and go to the Motherboard List section Intel D815 EEAL is supported, Although Im not sure if it is the same as an Intel D815 EEA) 3. Read the following articles. Endless FAQS on MBM Check this out also Hope this helps .
The Ultimate Chess Strategy : "Hit Hard, Hit Fast and Hit Often" |
#10 (permalink) |
intel d815eea? Hey thats a P3 MB, same as mine. it has no sensor. I plugged in a bigger fan and now that fan slot dont work either. Expensive but an average board. Also has some weird stuff in it like has 3 slots but you can only get 512megs on it and such. Its gathering dust somewhere here. But I like it better than P4 celeron stuff.
#13 (permalink) |
You might be correct I have the D815EEA2 which does.
There is no temperature sensor but the other stuff show up. I was using it with the Intel monitor. You can download the specifications here. http://www.intel.com/support/motherb.../cs-013053.htm |
#14 (permalink) | |
Not all Intel original motherboards have sensors .I have 845GLLY mobo and it has no sensors onboard and shows bo info in the bios. I have used many software in vain. Only hard disk temp. can be measured. No need to measure the temp. if not overclocking. No use using any software. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
