Go Back   Digit Technology Discussion Forum > Hardware > CPU / Motherboards
CPU / Motherboards News, discussions, queries and problems related to CPUs and motherboards. Section Thread Index
Old 01-08-2005, 10:33 PM   #1 (permalink)
Good Boy
george101's Avatar
Default Help! Motherboard for P4 2.4GHz
I have an intel P4 2.4 Ghz processor and i want to buy a motherboard with AGP 8x for playing games. I had already bought a Geforce Fx 5200 256mb graphics card but it is 8x and my current motherboard is only 4x.
Can you guys please recommend a motherboard with AGP 8x and can be used on P4 2.4. My budjet is only 2000-3000.
george101 is offline
Old 02-08-2005, 07:10 AM   #2 (permalink)
sidewinder's Avatar
msi 865pzr. Rs.2700
Bombina rocks
sidewinder is offline
Old 02-08-2005, 07:24 AM   #3 (permalink)
i think u can use ur GFX card on ur current mobo also since 8x is backward compatible wih 4x
Shwetanshu Srivastava
shwetanshu is offline
Old 02-08-2005, 04:18 PM   #4 (permalink)
Good Boy
george101's Avatar
Hey guys why dont you help me! Plz give an answer.........
Old 02-08-2005, 10:49 PM   #5 (permalink)
The Hardware Labs
mohit's Avatar
u can use your 8x card on a 4x mobo and since its a 5200 it will perform almost the same ... so why do u wanna upgrade simply ?? anyways if u still wanna buy a new mobo then go for the Asus P4P800-VM ... its a very very good baord and i have personally used it. it will cost u around 3-3.5 k .
mohit is offline
Old 07-08-2005, 09:02 AM   #6 (permalink)
i'm also having same prob but difference is that i have p-4 2.26 ghz processor can this processor be used in above mentioned motherboards?
paul_007 is offline
Old 07-08-2005, 03:28 PM   #7 (permalink)
Commander in Chief
QwertyManiac's Avatar
yes it can be used paul - its an s478 mobo...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 08-08-2005, 08:09 PM   #8 (permalink)
hi qwerty thnx 4 reply
one more ques, according 2 u which is the best grafix card(agp 8x) within the budget 5K
paul_007 is offline
Old 11-08-2005, 12:51 PM   #9 (permalink)
You can go for a nice Asus or MSI mother board!!!
Asus P4P800S Deluxe Motherboard
P4 (Hyper-Threading), 2GB DDR400, 2xDIMMs, Intel 848P chipset, 800/533/400MHz FSB, 5xPCI, 1xAGP 8X, SoundMAX Digital 6-CH Audio, USB 2.0, 2xSATA + 2xATA100, Realtek 8100C LAN
PROCESSOR--
Socket 478 for Intel Pentium 4/ Celeron up to 3.6GHz+
Intel Hyper-Threading Technology ready
New power design supports Intel next generation Prescott CPU!
CHIPSET Intel 848P MCH Intel ICH5
SYSTEM MEMORY 2 x 184-pin DIMM DDR400 Sockets support max. 2GB
PC3200/PC2700/PC2100 non-ECC DDR SDRAM memory
ON BOARD I/O 1 x Parallel
1 x Serial
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x Audio I/O
1 x SPDIF out
1 x RJ45
4 x USB 2.0
ON BOARD IDE 2 x UltraDMA 100/66/33
Built-in ICH5 supports 2 x Serial ATA
ON BOARD LAN Realtek RTL8100C 10/100 Mbps LAN PCI controller
FEATURES
Support S/PDIF out Interface
ASUS C.P.R. (CPU Parameter Recall)
ASUS MyLogo2
ASUS EZ Flash
ASUS Instant Music~Lite
ASUS CrashFree BIOS 2
ASUS JumperFree
CPU, Memory, and AGP voltage adjustable
SFS (Stepless Frequency Selection)
Adjustable FSB/DDR ratio. Fixed AGP/PCI frequencies.
BIOS
4Mb Flash ROM, AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, ACPI, ASUS EZ Flash, CrashFree BIOS 2, ASUS MyLogo2
EXPANSION SLOTS 1 x AGP 8X (0.8V, 1.5V only)
5 x PCI
1 x ASUS WIFI Connector for optional wireless LAN upgrade
BOARD SIZE
ATX Form Factor 12.0" x 8.6" (30.5cm x 21.9cm)
Manav Mohanty
Uniservze
Calcutta
manavmohanty is offline
