Go Back   Digit Technology Discussion Forum > Hardware > CPU / Motherboards
CPU / Motherboards News, discussions, queries and problems related to CPUs and motherboards. Section Thread Index
Old 25-07-2005, 12:25 AM   #1 (permalink)
Default does intel 915 chipset based mobo supports hardware T&L
does the onboard graphics chip of intel 915 chipset based mobo supports hardware T&L
arunbj is offline
Old 25-07-2005, 03:08 PM   #2 (permalink)
rohanbee's Avatar
Well i am not very sure about the T& L part but most games would work which have that requirement on a 915 board.
Quote by Garfield'
rohanbee is offline
Old 25-07-2005, 03:22 PM   #3 (permalink)
royal's Avatar
I think it does
royal is offline
Old 26-07-2005, 09:35 AM   #4 (permalink)
deathvirus_me's Avatar
it has HT@L support .. also i think it features pixel/vertex shaders .....
deathvirus_me is offline
Old 26-07-2005, 12:16 PM   #5 (permalink)
gxsaurav
Posts: n/a
Intel 915 G Chipsets supprt DirectX 9b in hardware that means Pixel Shaders 2.0 in Hardware, but vertex shader or Hardware transform & lightning is calculated by the CPU in the software as it can be emulated in software
in other words, 915 doesn't support hardware T&L, although games will work, but if there is a game which checks for a T&L compatible card, then it won't work, one examples is Bloodryane
Old 26-07-2005, 07:25 PM   #6 (permalink)
hardware tnl is present on geforce and radeon series atleast should be
even 865 may have tnl but 865 may not have pixel shaders
asko thers about 915,can you run price of persia:sands of time if you can't then you might not be having it or something
akshayt is offline
- by kool
- by Jripper
- by kool
