Go Back   Digit Technology Discussion Forum > Hardware > CPU / Motherboards
CPU / Motherboards News, discussions, queries and problems related to CPUs and motherboards. Section Thread Index
Old 05-07-2005, 03:21 PM   #1 (permalink)
Default Difference between Motherboard and Chipset
hi,
can any one explain me the exact differnece between a MOTHERBOARD AND CHIPSET.
as both are used interchangebly, i just can'f figure out the right definition for this thing.
i hve gone through online disctionary also but i need a practicle anwer rather then predefined dictionary styled definition. any help...
reg
taken is offline
Old 05-07-2005, 04:12 PM   #2 (permalink)
busyanuj's Avatar
A chipset is a group of chips that are used together to power a motherboard. The chipset is built into the design of the motherboard and is responsible for its working.
while a motherboard is the mainboard of the computer which forms a platform for housing the processor and has various ICs, slots etc on it.
busyanuj is offline
Old 05-07-2005, 04:44 PM   #3 (permalink)
hey Taken chipset and motherboard both are different parts.
The motherboard controlled the function of ur whole PC. that mean it controlled the fuction of ur various hardware in ur PC. It enable them to communicate between them.
On the other hand chipset controlled the function of ur motherboard.A set of chips attached to the motherboard that control how some system hardware interacts with the CPU and motherboard. Memory(RAM) is one component which is controlled by the chipset.
I Hope u get ur answer
below link will further help u to solve ur doubt
http://www.faqfarm.com/Q/What_is_mai...al_motherboard
\"As soon as you trust yourself, you will know how to live.\"
- Goethe
bendre123 is offline
Old 05-07-2005, 04:54 PM   #4 (permalink)
wow!! thats great.
i hoped and your answer cleared all the doubts.
hats off to you. thanks.
taken is offline
