04-07-2005, 02:38 PM
AMD pc required
I just wanted a config for a AMD sys...no monitor,no keyboard and mouse and no speakers bcoz i already have them...my buget is say 50-55k so just help me out with my config and the prices:
AMD athlon 64 3200+(or 3500+ if in buget)
Motherboard: MSI NEO4 PLATINUM or Asus A8N-E?
Ram: 1gb DDR 400mhz(kingston or zion?)
Graphic card: geforce 6600GT PCI-E
Hard disk: 120gb or 160gb SATA
Sony dvd writer
A cabinet
A good SMPS according to the power requirement
Anything else that i am missing?
I will be going to delhi this month...will be getting everything from there itself,so just let me know the prices of these components.
Any other config are welcome but only AMD.
NOBODY is PERFECT and i am NOBODY
04-07-2005, 03:08 PM
Did I get u right? 50K just for the processor?
Wow. If u can, would you mind telling us what is your prupose. I would so like to hear it.
AMD Dual-Core Opteron 265 Italy or AMD Athlon 64 FX57 San Diego should be pretty good for your money. Although, I am not sure they are available in india. Wait for someone's reply too.
04-07-2005, 03:14 PM
50k not just for the processor its for the components i have mentioned above...seems like the topic subject is something different from what i mean so will edit it
04-07-2005, 03:58 PM
get a good UPS. One from APC will do. How much u need is upto u. I have a APC 500 which gives me abt 15 mins back up. The main aim is for me to be switch off my system normally. The rest seems fine. I am assuming since you did not mention a monitor that u already have one ? Also go for a higher capacity HDD. You will find it useful. As for RAM go for Corsair. Better performing RAMs. If it is not available then Kingston. Hynix generic RAMs are also good.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
05-07-2005, 02:14 PM
Hey guys,i spoke to some of my friends about my pc but then they said that AMD gets heated up much more than intel...so whats ur opinion?is it true?
1. Is intel pentium4 3.2ghz better than AMD 64 3200+?
2. If i choose AMD then which mobo should i go for?MSI NEO 4 PLATINUM or ASUS A8N-E?
pls help out guy its urgent
05-07-2005, 02:39 PM
Dude, Intel botched their 90nm processors, but AMD didn't. So your 3200+ should run nice and warm than sizzle like the intel.
1. The intel one bests the Amd one in almost all the benchmarks by a large margin. The 3200+ compares well to Intel 2.6GHz. I suggest you go for a faster amd or the 3.2 intel.
2. go for Asus A8N-E if you chose the Amd one and have the money (around 8K).
3. You cannot go for 3400+ if using A8N-E coz 3400+ is socket754.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
05-07-2005, 02:42 PM
05-07-2005, 02:57 PM
Originally Posted by siriusb
dude did u take care to read what those reviews says?
have thay compared P4 with AMD Athlon64 conterparts?
All links u gave compares P4 with AMD AthlonXP not Athlon64.
AMD Athlon64 beats P4 in almost every test.
1 aadi + 1 aadi = 1 full ;)
05-07-2005, 03:27 PM
Sorry. My bad, my bad. Thanks for pointing it out politely. I must really take that nap now.
P4 3.2 and A64 3200+ seems to compares well. It even beats p3.4 in some games. If u are using your pc for games, then go for amd by all means. The remaining points remain.
http://www.xbitlabs.com/articles/cpu...on64-90nm.html
05-07-2005, 03:39 PM
Can u just tell me about the prices/performance difference between AMD Athlon 64 3200+ and 3500+?
My main pupose for this pc is gaming and wanna buy a pc that can play the latest games even after 2-3 years
05-07-2005, 03:51 PM
3200+ and 3400+ won't make gr8 difference after 2-3 years, but the graphic card will sure do.
So instead of 3400+, get a higher graphic card, also u can invest in SATA RAID and better PSU from Antec
05-07-2005, 03:58 PM
Hey aadipa,i made a mistake actually i wanted to know price/performance difference between 3200+ and 3500+ :roll: i will edit my previous reply and delete this one later on
05-07-2005, 06:36 PM
Price difference between 3200+ and 3500+ is around Rs.4400.
The performance difference is almost as great as the price difference too.
Also, if you are interested in overclocking, a 3500+ cpu allows you to use the multiplier upwards. But a 3200+ will only allow downward multipliers.
Take a look in here:
http://www.sharkyextreme.com/hardwar...261_3453401__1
06-07-2005, 01:14 AM
Go for 3200+ @9000
ASUS SLI mobo @9200
2*512DDR @5000
160 SATA@4200
400WPSU@1500
6600GT128@9500
1000VA ups@3500
I think going for an SLI board is better future proof. SLI board offers unparreled perfomance even if on single card.After 1 or 2 year U can get 2 6800 or even 7800 in SLI nd sell of this 6600GT. Then 6800 would be cheaper enough to get 2 of them.
U can also opt for a better 450 or above PSU from better brands but would set U back with almost 5000/-.
U can also go for an X800 card as it permormrs more or less than a 6800GT.After 2 yrs U can sell it nd set SLI with nvidia cards.
08-07-2005, 06:36 PM
take sata ncq seagate or sata II
also,amd 3200 winnie shd may beat 3.4ghz in games but otherwise overall compete with 2.8-3ghz in many thing sometimes may be ...less(if that is)
08-07-2005, 11:29 PM
bang bang!
Lite-on DVD writer
Antec cabinat
