Go Back   Digit Technology Discussion Forum > Hardware > CPU / Motherboards
CPU / Motherboards News, discussions, queries and problems related to CPUs and motherboards. Section Thread Index
Old 04-07-2005, 02:55 AM   #1 (permalink)
doom_marine's Avatar
Default Motherboard
I decided to change to an AMD system and would like to know which is the best motherboard in terms of performance.
I plan to change to dual core later on when it is available. Also could some one tell me when the dual core amd will be available in india and where i can buy it??
Which is the best power supply for me to invest
AMD Athlon X2 4200+
2GB DDR 400 RAM
nVIDIA 7800GTX 512MB x 2 SLI
Creative X-Fi Fatal1ty Sound Card
400+160+74GB HDD SPACE
doom_marine is offline
Old 04-07-2005, 10:38 AM   #2 (permalink)
Anyone help??
AMD Athlon X2 4200+
2GB DDR 400 RAM
Old 04-07-2005, 11:52 AM   #3 (permalink)
siriusb's Avatar
I don't know if it is the king of performance, but Asus A8ne SLi/non-Sli edition should satisfy you. If u can get it, go for DFI LANParty NF4 SLI-DR. But I doubt u could in India.
AFAIK, all NForce4 motherboards support dual core processors, atleast after a simple bios flash.
You probably have wait for the power related query, but antec 400w shud satisfy most desktops.
Everything comes down to paper, really. How much can u shell out?
siriusb is offline
