Go Back   Digit Technology Discussion Forum > Hardware > CPU / Motherboards
CPU / Motherboards News, discussions, queries and problems related to CPUs and motherboards. Section Thread Index
Old 17-06-2005, 12:44 PM   #1 (permalink)
Default upgrade from intel celeron
The intel celeron 1.2 ghz system I had crashed due to a motherboard problem. I want now to upgrade to either intel p4 or AMD athlon.
Can someone who has experience in dealing with both intel and AMD systems to suggest which processor and matching motherboard I should go in for? I am using the computer only for home office use.
pscraja is offline
Old 17-06-2005, 01:18 PM   #2 (permalink)
Aniruddh's Avatar
@pscraja
Man wats ur budget dats important as u can get a rig from 15k to more then 1lakh so betta tell us ur budget.and u juz wanna mobo and proc or the whole system?
Aniruddh is offline
Old 18-06-2005, 12:05 AM   #3 (permalink)
it is also important to know that what will u be using the computer for
Happy Computing :lol:
krishnathelord is offline
Old 18-06-2005, 01:25 AM   #4 (permalink)
Geforce's Avatar
Welcome "pscraja" to the digit forum.
Try looking at other threads to get a feel of some current computer configurations doing the rounds in this forum.
Happy hunting !!
Also above 2 questions are very important
1) Your budget
2) Applications u will be using on new pc
AMD Athlon64 2800+, MSI K8N Neo3(NForce4), 1GB Kingston DDR400, MSI Geforce 7600GT PCIe, Viewsonic VA702b 17" LCD, Creative SB Live! 5.1, Logitech Z-5300 5.1 THX Speakers, Seagate 200GB SATA HDD
Geforce is offline
Old 21-06-2005, 03:28 AM   #5 (permalink)
U have specified that u will use the system for office use.
And haven't specified the budget!
PROCESSORS:
1)AMD Sempron 2200+ 32-bit Rs 2300
2)AMD Sempron 2400+ 32-bit Rs 2800
3)AMD Sempron 2600+ 32-bit Rs 3800
MOTHERBOARDS:
1)ASUS A7V400-MX SE Rs 2500
2)ASUS A7N8X-VM Rs 4750
3)Gigabyte GA7VM400-M Rs 2100
I would suggest AMD Sempron 2400+ and ASUS A7V400-MX SE (Rs 5300)
..And also if u dont have DDR-RAM get Two sticks of Hynix 256MB 400Mhz DDR RAM for Rs 2500(Two sticks to implement dual channel)(Ram Prices are really low today)
If u have more budget u can get latest AMD 64-bit Processors.
Mahesh Babu is offline
Old 25-08-2005, 02:21 AM   #6 (permalink)
Default Re: upgrade from intel celeron
Assembled The Following on August 16th 2005 All Prices Nehru Place New Delhi as on this Date.
Intel Celeron 2.53 Ghz Rs 3750.00 socket 478 533 Mhz FSB 256kb/L2
Intel genuine d865gbf Mother Board rs 4700/-
Transcend DDR 400 Mhz 512 Mb Ram 256*2 Rs 3000/-
XFX NVidia geforce 4 Mx 4000 AGP Card Rs 1690/-
Pixel View TV TUner Card Internal 1500/-
Asus DVD Rom Drive Rs 1400/-
Samsung CD RW Rs 1300
Cabinet Navtech Temperature Series HT 2688 B 4 Fans Type Rs 1000/-
Without Original Power Supply
Power Supply Antec Smart Power 400 Watts Rs 3500/-
D Link Internal Modem 56.60 Kbps Rs 450/-
TVS Key Board 1100/-
Logitech Scroll Mouse 250/-
Microtek Monitor 17" 4370 OSD Rs 5000/-
microtek ups 600 va max power Rs 2000/-
The Above Configuration can satisfy the most of basic pc users neds but not high end gaming in which i do not believe.You Can Change the Celeron Processor to a P4 2.40 Ghz For Rs 6350/- But The Factor of Heat Will also Increase.Please Note that a TV Tuner Inside a PC Can be used only for short time and not as a complete replacement as a tv as in my own pc while watching tv in pixel view tuner card in Windows Me Upon Changing the Channel The OS Got Jammed and Upon Hot Restart the Mother Boards Main Chipset 845 got burnt.hence please use TV in a PC Judiciously.
Fate Will be that of King's and Counsellors of earth who built for themselves palaces now Lying In ruins!
Zaysen is offline
Old 25-08-2005, 06:25 AM   #7 (permalink)
Dont forget the new AMD Sempron 2500+ IS 64-bit IE you can run WIn XP 64... (AMD Sempron 64 - 2500 RS2525 )
http://www.deltapage.com/
AlienTech is offline
- by kool
- by Jripper
- by kool
