Go Back   Digit Technology Discussion Forum > Hardware > CPU / Motherboards
CPU / Motherboards News, discussions, queries and problems related to CPUs and motherboards. Section Thread Index
Old 14-06-2005, 05:26 PM   #1 (permalink)
Default Audio Problem on Intel 845GVSR Motherboard need urgent help!
My pc Configuration:
Intel P4 2.4Ghz 1MB Cache Processor
Intel 845GVSR Original Motherboard
512DDR Ram Hynix
LG 52X Cd Writer
Intex 2000W Woofers
I bought this system recently a week before.
My Problem is related to the Audio playback.If i am playing some songs on winamp, it will run for a while and suddenly stops.the period of running varies.I hear to devotional songs in the morning everyday. one day when i started playing the song it played for 56secs exactly and has just gone silent. i tried to play song on windows media player also but of no use. i tried reinstalling the audio drivers. but even that doesnt help. on reporting the problem to my vendor he tried to reinstall the audio drivers and the songs played continuously for 2 hours. i thought the problem was finally solved. next day in the morning as usual i started playing the devotional songs and the problem suddenly appeared again. we have even tried by reformatting the system. but still the problem continues.
Now i have no idea what to do ? is there anybody who can help me on this i will be very thankful if somebody can.
Ramireddy
IM Me at ramireddy_y on yahoo
ramireddy_y is offline
Old 14-06-2005, 06:49 PM   #2 (permalink)
expertno.1's Avatar
the problem seems of the sound card which cannot continuously play as was with my internel modem which was unable to run continuously
so u have formatted ur system even
u should check the power supply aslo
and the latest drivers should be present there suitable with the hardware
aslo get codec packs fromm www.free-codecs.com
first try all the above and then contact ur vendor and let him do the trcik agian and see what happens
expertno.1 is offline
Old 15-06-2005, 11:44 AM   #3 (permalink)
Thanks expertno.1 for ur suggestion. but that doesnt solve my problem. my power supply was perfectly ok. and i dont think the problem is because of the codecs . because in office also i use the same config system it has not got this problem ever.
sorry i have not mentioned the operating system earlier its windows xp professional with service pack 2 , directx 9.0c and has got he latest sound drivers and the chipset drivers.
Old 12-07-2005, 01:03 PM   #4 (permalink)
Finally the problem was solved after we got the mother board replaced by a new one.
Old 12-07-2005, 05:13 PM   #5 (permalink)
expertno.1's Avatar
yes becoz it was ur mobo problem.indeed
@mods
lock the topic
- by kool
- by Jripper
- by kool
