Results 1 to 24 of 24
  1. #1
    * bajaj151's Avatar
    May 2006
    India
    Default VFM Ups for my rig
    Config :
    MSI 890GXm G65
    1055T (3.75 Ghz)
    Corsiar 4*2 DDR3 1600
    Sapphire 7850 OC
    1*500G HDD
    Corsair VX 550W
    DVDRW
    Haf 922 (2*200MM + 2*120MM )
    Hyper 212 EVO (2*120MM)
    Requirement : Atleast 15 Min. Backup
    Budget : Minimum possible
    Alternative : If available, please suggest
    It's urgent....waiting for the replies..
    Phenom x6 1055T 3.36 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 500GB | Seagate GoFlex 3.0 2TB | WD My Book Essential 3.0 1TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC | APC 1kVA | Razer Goliathus Control | Logitech C270H | Hyper 212EVO (Push Pull) | Asus RT N13U on DD-WRT |
  2. #2
    * bajaj151's Avatar
    May 2006
    India
    Default Re: VFM Ups for my rig
  3. #3
    Wise Old Owl pulkitpopli2004's Avatar
    Jul 2010
    D!ll!
    APC BE700Y-IN .cost arnd 3.7k
    I'd explain it to you, but your brain would explode... Trust me
    i5 760, Asus P7P55D-EVO, Zotac GTX 460, VX550, Win7 64bit,4GB RAM @1600MHz, WD 500GB+1.5TB Caviar Black, NZXT Phantom
  4. #4
    * bajaj151's Avatar
    May 2006
    India
    700VA enough for my configuration ?
  5. #5
    Jul 2010
    D!ll!
    yeah.. absolutely.. we have similar config.. i have the same UPS
  6. #6
    * bajaj151's Avatar
    May 2006
    India
    What's the next best option ?
    Where can I find APC or Microtek UPS in delhi ?
    Which oneis more VFM, Microtek or APC ?
  7. #7
    In The Zone havoknation's Avatar
    Aug 2012
    Pune (Koregaon Park)
    even APC600VA would be sufficient
    Havok Rig : Core i7 950 4Ghz on H100i, MSI X58 ProE, 24GB Gskill ripjaws 1600Mhz ram, Zotac GTX680 OC, Phantom820, Creative Xfi titanium, Seagate 10tb HDD, Roccat Isku FX, Razer Death adder on goliathus, BenQ GW2750HM, Tagan BZ800W Modular, JVC HA-RX900, M6
    Gadgets : Motorola Xoom 32GB Wifi, HTC Titan, Galaxy Nexus, Sony DSC HX20V, Swift Lxi
    www.havoknation.in
  8. #8
    Jul 2010
    D!ll!
    Quote Originally Posted by bajaj151 View Post
    purchase APC600VA from cost2cost Nehru place..
    or APC 700VA from smc..
  9. #9
    * bajaj151's Avatar
    May 2006
    India
    If I upgrade my PSU from 550W to 850W...Should 700VA suffice for 10-15min backup ?
  10. #10
    Jul 2010
    D!ll!
    yes its ok.. bt it depends to what all components that PSU is giving current.
    so if your config goin to be same and only PSU will be changed.. 700VA wud suffice your need of 10-15min maximum..
  11. #11
    * bajaj151's Avatar
    May 2006
    India
    I just gonna add 2 or 3 SATA HDD & sound card...thats it
  12. #12
    Jul 2010
    D!ll!
    not an issue in that case.. coz HDD take only 10-15watts usually..
  13. #13
    * bajaj151's Avatar
    May 2006
    India
    Why is APC 1kVA costlier than 1.1kVA ??
  14. #14
    Jul 2010
    D!ll!
    ^^ because
    1. 1kVA has auto shutdown feature which lacks in 1.1kVa
    2. battery rating in 1kvA is better than 1.1KVa
    3. so better back up with 1kVA rather than 1.1KVA
  15. #15
    * bajaj151's Avatar
    May 2006
    India
    Is it worth buying 1kVA (around 7.3k) ?
  16. #16
    Jul 2010
    D!ll!
    Do u have back up requirement of around 15min on full load?
    and need features like
  17. #17
    * bajaj151's Avatar
    May 2006
    India
    No..I can't able to find APC 1.1kVA in District Center, Janakpuri...Will search in Nehru place...SMC also suggesting 1kVA....(SMC said : 1.1kVA wala ups bakwas h... )
    Offtopic question : How laptop battery provides 3 hr backup costing just 4-5k whereas UPS can't for the same price ?
  18. #18
    Jul 2010
    D!ll!
    ^^ In Nehru place it would be easily available. or you can try online also.. but buy only Indian version..
    Laptop battery provides 3hrs backup becoz laptop consumes only a 20-80W but in desktop 200 to 800W is required depending upon the configuration.
  19. #19
    * bajaj151's Avatar
    May 2006
    India
    How to check, whether India version or not ?
    Is 5.3k for 1.1KVA ok ?
  20. #20
    Jul 2010
    D!ll!
    by its socket only.. it should similar to ur power sockets at home.
  21. #21
    * bajaj151's Avatar
    May 2006
    India
    I came across this post : APC Back-UPS Pro 1000VA (BR1000G-IN) Review
    UPS + Extra Battery : Gives around 2+ hr backup but costing around 7.3K + 6.3k = 13.6k (UPS alone can give MAX. 30 min backup)
    But Microtek 800VA Inverter gives around 3+ hr backup on same computer + supply to other equipments at home as well ....costing around 5K + 10K = 15K
    Which one is the better option for long backup : UPS or Inverter ?
  22. #22
    Jul 2010
    D!ll!
    long backup would be better in case of inverter but it cannot provide the uninterrupted power which would be the case in UPS.
    using inverter is more risky for PC than UPS.
    PS has a much shorter switching time than an Inverter.
    Typically, changeover time in inverters is 500 milliseconds & Offline UPS has changeover time of 3-8 milliseconds.
  23. #23
    * bajaj151's Avatar
    May 2006
    India
    Bought APC 1kva : 7.2k
    Thanks you all
  24. #24
    Gamer
    Mar 2009
    Chennai
    Have you tried the auto-shutdown feature. How good is it?
