Page 2 of 2 FirstFirst 1 2
Results 31 to 37 of 37
Thread: Need AC
  1. #31
    Broken In audiophilic's Avatar
    Mar 2012
    India
    Default Re: Need AC
    Quote Originally Posted by rider View Post
    I recommend you to get O-general its the coolest brand with fine service in delhi.
    Thanks for suggestion. I was thinking of buying one too.
  2. #32
    in the kaya gmg9's Avatar
    Nov 2008
    india
    hi guys....
    budget increased to 32k-35k. can u suggest a good 1.5 ton split ac within this budget.
    also if u can, suggest some window ac model.
    is a 5 star split ac possible within dis budget?
    how is carrier company ac?
    thx....
    Device: LG OptimusOne P500
    ROM: ICS CM9-TINYLIGHT by HepHappy
    Kernel: stock (no oc)
    CR: Amon_Ra Thunderg v3.0.6
    Kolkata Android Users Group
  3. #33
    Nov 2011
    Chennai
    Default Re: Need AC
    1. electricity bill for window ac is more than split ac
    2. No 5 star is too costly and hardly u see a difference of 200-400 rupees per month.
    If u r using it for about 18 hours u can see the more price difference
    3. Carrier AC's is the first brand in heating, ventilating and air conditioning (HVAC) systems, but they are costly [my frd said so]
    My suggestion is Daikin, My other frd using it for 10 years no problem so far [so i also bought it].
    I think ur budget ll fit, not sure cause Daikin price's gone up
  4. #34
    as Sam Fisher rider's Avatar
    Aug 2011
    ThinkDigit Forum
    Default Re: Need AC
    VOLTAS PLATINUM 5S window AC consume just 1607W power.
    It costs 28k in market.
    Google Nexus 4 16GB running 4.2.2 Jelly Bean | Antutu Score: 17552 | GeekBench 2 Score: 2151 | SoundMAGIC PL11
    hp pavilion dv6-6165tx powered by Intel Core i7-2670QM 2.2Ghz-3.0GHz | Radeon HD 6770M 2GB GDDR5 | 8 GB DDR3 RAM | 750GB HDD | GeekBench Score: 12022 | Windows 8 Pro x64 | 1TB Seagate Backup Plus USB 3.0 HDD | Edifier M3200 Speakers | CoolerMaster Notepal L1 |
  5. #35
    Nov 2008
    india
    Default Re: Need AC
    Quote Originally Posted by amjath View Post
    thx a lot for ur suggestions...
    no way, i need to use ac for 18 hours. i just need on those annoying heat days.
    got a quote for voltas and carrier window ac.
    thx for da model n info. i prefer split ac. bt its my dad pushing me for window.
    to setup a window ac in a room where u dont hav any pre-organised space for ac, cost another few bucks. so its always better to setup split. and for window ac u hav setup a iron cage for it, to prevent it from thief.
    can u plz chk voltas gold 1.5t sac. its a 5 star split ac. price within 32k. i chked it online.
  6. #36
    Nov 2011
    Chennai
    Default Re: Need AC
    @gmg9: then 3 star ac is a way to go dude
  7. #37
    Nov 2008
    india
    noted.. thx..
