Results 1 to 10 of 10
  1. #1
    Apr 2012
    Default Air Conditioner Suggestions
    I am looking forward to buying an AC for my home. I have never bought an AC before this so I would like some suggestions on what kind of AC to buy. I would be using it for around 6-10 hours probably just in summer months.
    Here are some points that I would like to be clarified on :
    1) Is there any benfit of a split AC over window AC?
    2) Is going for an AC with higher energy really worth the extra premium? I compared the energy usage for a 3 star AC(assuming usage of 6 hrs/day and for 150 days a year) using this site(I want to save electricity) , according to it my Annual bill would be Rs 7254 and if it were a 5 star AC , it would save me Rs 4275 over the span of 5 years(thats long!).
    3) It would be nice if you can post what kind of AC you have at your home and your approximate energy bill due to it.
  2. #2
    Neo
    Neo is offline
    Bird of Hermes Neo's Avatar
    Jun 2011
    Near my Computer.
    Default Re: Air Conditioner Suggestions
    Yea, split > window AC. A Split AC provides better cooling and takes less space , looks good as well.
    Avd if you have the budget, get a 5 Star rated AC. Save Energy.
    Twitter | Steam | MyAnimeList
    Intel Pentium E5400 @2.7 Ghz | Intel DG41RQ | 2 GB A-Data DDR2 | WD Caviar Green 1TB | nVidia Geforce 8400GS 512 MB
    LG Optimus One P500 | Windows 8 x86 | Arch Linux x86_64
  3. #3
    Apprentice navpreetsingh459's Avatar
    Sep 2012
    Bangalore
    Quote Originally Posted by rosemarie View Post
    Hallo @mcguire999. I am Rose.
    So there are many online shops who provide best and easy facilities to buying any thing. And For many homeowners, a split air conditioner is a great option for keeping their home cooled off during the hot summer days. Not only is the split air conditioner an efficient way to keep rooms cooled down, they are also a cost effective air conditioner.
    I agree with you rosemarie..mcguire,You should go for Split AC as they provide better cooling...
    Have you selected any brand till date??
  4. #4
    Wise Old Owl The Incinerator's Avatar
    Sep 2012
    Windows AC always cool better and faster. Since they are not split between two units indoor and outdoor. But Split ACs are convenient because they are silent. A window AC will cool a hot room much faster than a split AC from as soon as you press start. Split ACs are easy to install as they require very less intrusion because of its design. Inverter ACs are better.
    Good Brands - Daikin , Hitachi, Mitsibishi , General , Toshiba , Sharp.
  5. #5
    Rusted... dashing.sujay's Avatar
    Nov 2009
    Bhopal
    The answer lies in "Unity". If all do it, then a power plant can be closed down without effecting anything, but if only one does it, I even can't get my full pocket money.
    FAQ + answers for new members (Read before asking / messaging any moderator for any query)
    Drop Box: Get 500MB free
    Quote Originally Posted by axes2t2 View Post
    Before working on a master piece you have to first master the pieces.
    Sony Vaio CB35 Asus U32U ATH M20 Fiio E6
    Sony Vaio CB35 UnBoxing & Review
    How fast can you type?
  6. #6
    Broken In clickclick's Avatar
    Nov 2012
    I would suggest u to buy a window ac. Because in split ac, the charges are a lot to uninstall and install. For example, if u have a rented house or plan to buy a new one, the technician will charge for both. Here in mumbai they charge 3000 to uninstall and reinstall plus the copper wires, water outlet pipe etc is extra.
    Where as in a window ac u have to get ur windows altered but that doesnt cost much, 800-1000 here in mumbai with labor and installation.
    I have a split in my drawing room and had to bear all those expenses when i renovated my house cause we extended the drawing room. Where as in the bedroom there were no such expenses as i have a window ac installed.
    Buy onida split ac, its the best and if u choose window the samsung or onida, do not buy LG.
    Canon 1100D | EF-S 18-55 IS II | Olympus FE310
    Acer Aspire 5738G | Seagate 500 GB Goflex 2.5 | Blackberry Playbook 16GB | Sony PS2 | Nokia E71 | Apple iPod Touch 32GB 3G | JBL Tempo On Ear Headphones
  7. #7
    Apprentice Lalit Kishore's Avatar
    Jul 2012
    Bangalore
    First make up your mind on where you're planning to use it. Just for a room or the whole apartment. Now, look at the room allocations. If its in a straight line structure, split AC would be good. But for rooms interconnected by a lobby, it's always beneficial to go for a window ac. I have been using a Carrier 1.5 ton Window AC in my master bedroom (even though it's not required most of the time here!) for a good 8-10 hrs everyday and my monthly bills get jacked up by 1000-1200 bucks.
  8. #8
    Apprentice Ankit Omar's Avatar
    Jul 2012
    Pune
    Split ACs are silent, plus more efficient (since the heat outlet is much separated from the rest of the body). They are more aesthetic.
    But they are more expensive , and may need further civil work if you want to put the inlet/outlet pipes inside the wall.
    If you need multiple units, you may try the 1+1 split ACs that Hitachi and LG are offering - the per unit cost comes lower than a window AC of the same reading - civil work excluded.
  9. #9
    Wise Cold Ghoul Piyush's Avatar
    Feb 2010
    GZB.
    O'General Window AC= No worries + better cooling than most brands (except Western House and Blue star)
  10. #10
    Sep 2012
    General = Bad After Sales Service but good ac.
  1. Need suggestion for air-conditioner
    By abhijit_reddevil in forum Consumer electronics and everything else
    Last Post: 07-06-2012, 05:50 PM
  2. Need Suggestion on Choosing Air Conditioner
    By kpmfazal in forum Consumer electronics and everything else
    Last Post: 29-05-2012, 06:25 PM
  3. Air conditioner or Air cooler ?
    By GamerKP in forum Chit-Chat
    Last Post: 30-03-2012, 07:51 PM
  4. [URGENT Help Required] Best Air Conditioner?
    By kyldeepbhardwaj in forum Consumer electronics and everything else
    Last Post: 21-05-2011, 10:33 AM
  5. Suggest me an Air Conditioner
    By ithehappy in forum Consumer electronics and everything else
    Last Post: 04-05-2011, 01:12 AM
