Results 1 to 21 of 21
  1. #1
    as Sam Fisher rider's Avatar
    Aug 2011
    ThinkDigit Forum
    Default Buying a 2.0 Ton Split AC
    hello guys,
    I need a Split AC to plug it in the room that is of 7 X 2.8m = 19.6sq metre (214sq feet) area and 10 feet high in dimension. The room is full of windows and a balcony door on one side of 7m length. So full of sunlight comes direct to the room. Also, suggest me which wall I should plug it.
    The price should less than 35,000 because I can't exceed my budget. Star rating doesn't matter in my case, you know what I mean so hells yeah! for even 1 star. The main point is it should have an awesome cooling performance and decent service because last time I used Onida split AC which blow away due to poor service.
    Google Nexus 4 16GB running 4.2.2 Jelly Bean | Antutu Score: 17552 | GeekBench 2 Score: 2151 | SoundMAGIC PL11
    hp pavilion dv6-6165tx powered by Intel Core i7-2670QM 2.2Ghz-3.0GHz | Radeon HD 6770M 2GB GDDR5 | 8 GB DDR3 RAM | 750GB HDD | GeekBench Score: 12022 | Windows 8 Pro x64 | 1TB Seagate Backup Plus USB 3.0 HDD | Edifier M3200 Speakers | CoolerMaster Notepal L1 |
  2. #2
    Wise Old Owl pulkitpopli2004's Avatar
    Jul 2010
    D!ll!
    Default Re: Buying a 2.0 Ton Split AC
    go for Ogeneral for best performance and above average power consumption
    or Hitachi for good performance and low power consumption..
    I'd explain it to you, but your brain would explode... Trust me
    i5 760, Asus P7P55D-EVO, Zotac GTX 460, VX550, Win7 64bit,4GB RAM @1600MHz, WD 500GB+1.5TB Caviar Black, NZXT Phantom
  3. #3
    Spectre Anish's Avatar
    Jul 2008
    வேலூர் (Vellore)
    Hitachi sounds good.
    Though I would suggest you the General for quiet and best performance. But it may cost above your budget and sure its worth it.
    Canon Powershot SX130IS
    Thinkpad SL400C
    Arch linux + dwm = World Domination !
  4. #4
    Aug 2011
    ThinkDigit Forum
    What about Carrier Durakool 2.0 ton AC coz my uncle can get me in the cost price ??
  5. #5
    Section Moderator gopi_vbboy's Avatar
    Mar 2007
    Hyderabad
    Default Re: Suggest 2.0 Ton Split AC
    i have godrej,works pretty well
  6. #6
    eUREKA... techbulb's Avatar
    Nov 2011
    Jaipur
    Best performance ogeneral a/c
    MAY THE GOD BE WITH YOU
  7. #7
    sam
    sam is offline
    Forum Moderator sam's Avatar
    Jan 2010
    Guwahati
    posting same thing twice won't help. and that also in wrong section won't help at all. have patience
  8. #8
    Aug 2011
    ThinkDigit Forum
    Quote Originally Posted by Sam View Post
    alright
    Quote Originally Posted by techbulb View Post
    O-General is out of my budget
    I repeat the room that is of 7 X 2.8m = 19.6sq metre (214sq feet) area and 10 feet high in dimension. The room is full of windows and a balcony door on one side of 7m length. So full of sunlight comes direct to the room. Also, suggest me which wall I should plug it.
    The price should less than 35,000 because I can't exceed my budget. Star rating doesn't matter in my case.
    How is Carrier 2.0ton performance in comparison to hitachi 2.0 ton ??
  9. #9
    Nov 2010
    Dude i have been using blue star split ac..its really awesome..gives great cooling..and service is slightly expensive (950 for one visit) but really great..i think carrier are also great and even try voltas..
  10. #10
    Aug 2011
    ThinkDigit Forum
    Post Re: Buying a 2.0 Ton Split AC
    Quote Originally Posted by imrocking_since92 View Post
    What's the name of the model and how much it costs?
  11. #11
    iDota Sarath's Avatar
    Apr 2011
    Bangalore, Visakhapatnam, Abu Dhabi
    Sorry not much info about ACs atm. I live in Bangalore
    ◊ Online Shopping guidePS3™ master guidePS3™ vs PC ◊
    Gaming:♦ PS3 ♣ i5|HD6970 Gaming RIG | Dell U2311H review iΡod & iPhone 4 ♥ Xperia™ Arc review
    Audio gear: Logitech Z623 | Klipsch X10 | Siberia V1 | M1 | M2 | CX180
  12. #12
    make.believe Ayuclack's Avatar
    Jul 2011
    Ahmedabad
    I have a LG 2 Ton Don't remember The Model But The External unit Would Be Verry Large So Be Prepared For It :grim:
  13. #13
    Aug 2011
    ThinkDigit Forum
    Finally, after knowing so much about split ACs I concluded two Models of 2.0 ton of my budget:
    Samsung Max AS241UBJ 2.0 TR (22200 Btu/hr)
    Carrier Durakool Hi-wall Split 2.0 ton (23100 Btu/hr)
    Which one should I go for and why??
  14. #14
    Out of Stock manoj_299's Avatar
    Sep 2006
    Heart
    I'll advice u to go for 2 ton Hitachi, O general and Bluestar. But I think ur budget is issue. I'll recommend u to go for assemble/customize one. I'm sure it will come in your budget. And I bet u will not regret by investing on this.
  15. #15
    Aug 2011
    ThinkDigit Forum
    Quote Originally Posted by manoj_299 View Post
    What about Carrier?
  16. #16
    Jul 2010
    D!ll!
    what about the power consumption?
    No doubt these assembled one are lil cheaper and cooling is very good.. but they are nt more than 2 star..
  17. #17
    Aug 2011
    ThinkDigit Forum
    Quote Originally Posted by pulkitpopli2004 View Post
    I already told you, that power consumption deoesn't matter for me. I am okay, with even 1 star. I just need performance.
  18. #18
    Sep 2006
    Heart
    Power consumption depend on the heat/temperature outside the room where outdoor unit is running. Star rating are given in standard running condition like some 2 wheeler bike claim to give 100 kmpl. But in real road condition it fail to do so. So power consumption by AC depend on some factors such as: Indoor+Outdoor temperature, room size etc. If outdoor temperature is 45 and you want AC to achieve 22º C then it will utilize Max current if it is 2 Ton AC it may consume 13 to 14 Amps in that peak time and non stop. My Windows AC was fitted in 210 Aqft room earlier and there it was taking 11-12 Amps but now I shifted it to 100 Sqft flat and I check current is 8-9 AMPS. Not much difference by star rating if you invest and dont get cooling according to you and saving only electricity. If compressor is well enough to transfer hear effieiently and quickly then it will achieve the targeted temperature much earlier and shut compressor to save electricity.
  19. #19
    Jan 2012
    hey guy can you help me too? i wanna buy two ac's on 0.75/0.9 and on 1.5/2 ton ac what ac's would you recommend ? i'm buying them together so not very pricey ac's. but do not sacrifice performance wise.
  20. #20
    Jul 2010
    D!ll!
    ^^whatz your budget?
  21. #21
    May 2011
    Kolkata
    my freind bought a 2 ton split ac for voltas(2 star), it cost his rs 33,500 from great eastern, kolkata. You can check that out too, the carrier was coming for 38500.
  1. split second bsod
    By jones in forum Graphic cards
    Last Post: 07-04-2011, 10:59 AM
  2. Which Split AC ?
    By bajaj151 in forum Chit-Chat
    Last Post: 15-03-2010, 09:36 AM
  3. Split in Apple maybe!!!
    By iMav in forum Technology News
    Last Post: 29-10-2007, 10:44 PM
  4. Suggest a Split AC
    By planetcall in forum QnA (read only)
    Last Post: 03-04-2007, 10:17 AM
