Results 1 to 7 of 7
  1. #1
    Apprentice SeenuGuddu's Avatar
    Apr 2011
    Chennai
    Default Bluetooth in desktop computer and Bluetooth headphones?
    Hi all,
    i have a assembled desktop pc(not a laptop) with Windows XP Prof. I know that desktops doesn't support or carry bluetooth hardware in them.
    i am planning to opt the Bluetooth to my PC and Bluetooth headphones, main purpose of this is to watch movies, reason is don't want to disturb my neighbours.
    before buying i have few questions in my mind.
    1) after installing the Bluetooth in my PC, Can i watch the movies with Bluetooth headphones..?
    2) will it be audio able(quality audio) ..?
    if so then please suggest the Bluetooth on my PC and Bluetooth headphones
    please share the information, thanks in advance
  2. #2
    Manchester United <3 Ishu Gupta's Avatar
    Oct 2010
    Noida
    Default Re: Bluetooth in desktop computer and Bluetooth headphones?
    Yes and yes
    i5 2500k 4.4GHz @ 1.26v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
    GSkill RipjawsX 2x4GB 1600MHz CL9 | 160GB 7200 + WD Black 2TB | W7 + ArchLinux
    CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
    Razer DA Black + Razer Goliathus | XBox360 wired x2
    Senns HD201 | PSP Slim 8GB MSPD | Xperia U StockICS[Rooted] | Speedtest
  3. #3
    iDota Sarath's Avatar
    Apr 2011
    Bangalore, Visakhapatnam, Abu Dhabi
    Well you can go wireless by two options:
    Buy a bluetooth headphone
    Buy a wireless HP that uses radio frequency
    Which one is it that you would want? And budget and I will be able to help.
    ◊ Online Shopping guidePS3™ master guidePS3™ vs PC ◊
    Gaming:♦ PS3 ♣ i5|HD6970 Gaming RIG | Dell U2311H review iΡod & iPhone 4 ♥ Xperia™ Arc review
    Audio gear: Logitech Z623 | Klipsch X10 | Siberia V1 | M1 | M2 | CX180
  4. #4
    Apr 2011
    Chennai
    Quote Originally Posted by Sarath View Post
    Thanks to Ishu Gupta & Sarath
    @Sarath
    always wireless and my budget is 3k to 4k
    and also specify for Bluetooth on my PC(Desktop)
  5. #5
    Apr 2011
    Get this > Logitech® Wireless Headset ? Logitech.com 3000 rs
    available on infibeam, Golchha it to name a few.
    Any bluetooth dongle will do. Sells for a few hundred bucks.
  6. #6
    Apr 2011
    Chennai
    Thanks sarath
    the one which you have specified is Logitech Wireless Headset for iPad and also you can check the specifications.
    does it work for Windows XP(Desktop)...........?
    Logitech I-Pad-Headset 0GB Price India, Logitech I-Pad-Headset Review, Logitech Headphone India - Infibeam.com
    System Requirements
    For stereo audio playback : iPad 2, iPad, iPhone (3G and later), iPod touch (2nd generation and later)
    Tablets, smartphones and other devices that support Bluetooth wireless audio profile [Advanced Audio Distribution Profile (A2DP)]
    For FaceTime calls : iPad 2, iPhone 4, iPod touch (4th generation)
    For voice calls : iPhone (all generations)
    Other phones that support Bluetooth Hands-Free Profile (HFP 1.5)
  7. #7
    Undead!!! Sujeet's Avatar
    Dec 2011
    India
    Any. Bluetooth Headset Supporting A2DP Profile will work with PC. And as a matter of fact all of them do.
    HCL ME | Intel i3 310M | 320 GB | 2 GB DDR3 1333 MHz |
    HP ENVYM6 | Intel i5 3210M 2.5 GHz | 8GB DDR3 1600 Mhz | AMD Radeon 7670M | 1TB
    Samsung Galaxy Tab 2 |7.0 P31000
  1. Bluetooth 2.1 vs Bluetooth 3.0
    By cool_kals9 in forum Laptops and Netbooks
    Last Post: 12-04-2012, 12:00 AM
  2. bluetooth headphones 2000
    By rohit18rs in forum Mobiles and Tablets
    Last Post: 12-12-2011, 10:01 PM
  3. How to set up bluetooth in desktop
    By sushan in forum Buying Advice
    Last Post: 26-11-2008, 03:40 PM
  4. connect desktop pc and laptop by bluetooth
    By bkpeerless in forum Laptops and Netbooks
    Last Post: 17-03-2008, 10:40 AM
