help me to buy "Washing Machine" :)
Results 1 to 17 of 17
Thread: help me to buy "Washing Machine" :)
  1. #1
    Wise Old Owl kool's Avatar
    Oct 2004
    Question help me to buy "Washing Machine" :)
    Hi friends,
    i want to buy a semi-automatic washing machine for my home use for 5 family member. Before this I've never used washing machine. I don't know which brand is good in quality & service.
    So plz guide me some good models with good feature, service, warranty & quality. My budget is Rs.10,000
    Any online shop that deliver to Patna
    Popular Gadget Deals
  2. #2
    Apprentice SeenuGuddu's Avatar
    Apr 2011
    Chennai
    Default Re: help me to buy "Washing Machine" :)
    @ kool
    better go for Top-loading washing machine and spend some 5 k bucks, its cost 15k and try it from IFB , no one beats that and servicing tooo.....
  3. #3
    Oct 2004
    Quote Originally Posted by SeenuGuddu View Post
    @ kool
    But my problem is that frequent power cut in my area, and i've heard that it consumes lots of power & water.
    So kindly help me to choose good BRAND for washing machine.
  4. #4
    Apr 2011
    Chennai
    @ kool
    i guess you wont be having the issues in Top load when you have the frequent power cut and easy to handle
    the only issue with the Front load , its consumes water and problem in the frequent power cut
    go for IFB and wait for the experts to share the information
  5. #5
    Oct 2004
    @ kool
    Thnx guddu, any specific model?
    u mean TOP loading = fully automatic ?
    What are these terms: Impeller & agitator ?
    just now i read pros, cons and i found this:
    TOP LOADING WASHING MACHINE
    This is the most common type of washing machine. Clothes are placed into the top of the washer, and a lid closed over the top. There are two types, an agitator and an impeller. First, here are general points about top loaders:
    Pros
    Generally cheaper than front loaders.
    No fuss to throw more clothes in the wash midway through cycle.
    Faster wash cycle.
    Lighter weight.
    Biggest range available - especially large capacity washing machines.
    It can be moved easily from one place to another.
    Cons
    Water hungry
    Rougher on clothes
    Need extra space to open lid - not suitable for every laundry
    Not all Top loading washing machines come with a built in heater.
  6. #6
    Apr 2011
    Chennai
    @ kool
    its seems a bit cost and having the less in Top load and they are focusing in Frond load.
    just try any reputed brand(Samsung or Whirpool) and that works fine
    you check the below link
    Compare and Buy Top Loader Washing Machine with Best Offer
  7. #7
    Wise Old Owl ajayritik's Avatar
    Aug 2007
    Hyderabad
    @Kool. Earlier IFB was the leader when it comes to Washing Machines but now we find good ones from brands like Whirlpool, Samsung and LG. I currently have LG which has been working well for almost 3 years now. Top Loading consumes more water as compared to Front Loading. but I think Front Loaading sometimes has an issue with it's outlet getting bad. Considering your budget it's better to go for Front Loading.
  8. #8
    Oct 2004
    Quote Originally Posted by ajayritik View Post
    My budget is Rs.10,000 only (but i can increase 2k extra) No, i dont wanna spend on front loading. So tell me abt only semi-automatic or fully automatic.
    What are bad side of SEMI AUTOMATIC ? I want to place washing machine in my balcony only.
  9. #9
    Aug 2007
    Hyderabad
    Quote Originally Posted by kool View Post
    One thing I can think of right away is in Semi-Automatic you have two sections. One is for washing and the other for drying. So midway you need to manually transfer the clothes to the other section for drying.
  10. #10
    Oct 2004
    Price is less because of that one "manual process" ?
  11. #11
    In The Zone lm2k's Avatar
    Mar 2011
    Automatic washing washing machienes hav digital timers and control so more cost of its control ckt, semi automatic ones hav simple spring timers.
    Buy automatic machiene only if u hav plenty of softwater supply.
  12. #12
    Oct 2004
    Quote Originally Posted by lm2k View Post
    In PATNA, its soft water only. OK guys, i think u all are right. I should go for Automatic WM. so Now tell me some best brand with 2-3year warranty & sales service.
    By d way, what should i choose: Agitator or Impeller?
  13. #13
    Aug 2007
    Hyderabad
  14. #14
    Oct 2004
    By d way, is there any major problem or cons of fully automatic? if yes, plz tell me. and which feature should i keep in my mind while buying WM. ?
  15. #15
    Apr 2011
    Chennai
    @ kool
    i agree with ajayritik, but my opinion, don't go for LG instead go for Whirlpool or Samsung.
  16. #16
    as Sam Fisher rider's Avatar
    Aug 2011
    ThinkDigit Forum
    My budget is 18k, there is no problem with water in my area, so top load fully automatic. Please suggest me Urgent!! Preferable brands are Whirlpool and LG.
    Google Nexus 4 16GB running 4.4 KitKat with noise isolated SoundMAGIC PL11
    Nikon D5100 DSLR with 18-55mm VR Kit Lens
    hp pavilion dv6-6165tx powered by Intel Core i7-2670QM 2.2Ghz-3.0GHz | Radeon HD 6770M 2GB GDDR5 | 8 GB DDR3 RAM | 1TB WD Blue HDD | 1TB USB 3.0 Seagate Backup Plus | Edifier M3200 2.1 Surround Sound
  17. #17
    In The Zone Thor's Avatar
    Jun 2004
    Bangalore
    Dear OP ( kool ) , did you come to any sort of conclusion as to which one to buy ?I am in the market looking for same too ....
    Beware of my Wrath Mortals, Thou hast no choice.
    Laptop: Lenovo IdeaPad Y510P (i7 4700MQ, 8GB DDR3, 2 GB DDR5 Nvidia GT755M, 15.6" FHD)
  1. Replies: 2
    Last Post: 23-07-2012, 04:17 PM
  2. Suggestions needed for 32" LED and Washing Machine
    By shantam2005 in forum Consumer electronics and everything else
    Last Post: 04-01-2012, 12:50 PM
  3. Replies: 9
    Last Post: 03-08-2011, 04:21 PM
  4. Apple's "Time Machine" Now For Linux...
    By praka123 in forum Open Source
    Last Post: 13-11-2007, 02:02 PM
  5. Replies: 7
    Last Post: 27-06-2007, 10:46 PM
